hwOS Sport: New Firmware 10.73
The new hwOS sport firmware 10.73 is now available for download:
[10.73]
[10.72]
[10.71]
[10.70]
[10.68]
[10.67]
CHANGE: French language fixes
[10.66]
[10.64]
[10.63]
How to install: viewtopic.php?f=6&t=14509&sid=523868e80 ... 5f630b93c2
Die neue hwOS sport Firmware 10.73 ist jetzt zum kostenlosen Download verfügbar:
[10.73]
[10.72]
[10.71]
[10.70]
NEU: Sprachupdates
[10.68]
[10.67]
[10.66]
[10.64]
[10.63]
