Button sensitivity OSTC2 fw 3.18
Posted: 09 Jun 2022, 08:59
I'm struggling with the buttons in cold (~4°C) water. Navigating the menu with heated dry gloves is actually not easy, even though the sensitivity is set to 20%, which seems to be the most sensitive setting.
In warm conditions at the surface this is way too sensitive. The computer turns on all the time when moved or touched.
Here are my two questions
1) Is the 20% setting really the maximum sensitivity? 20% somehow suggest that it could be increased further, if firmware allows....
2) Given the temperature-dependence of the sensitivity, do you think it is possible to automatically adjust the sensitivity with temperature? (Maybe with a user-adjustable range: 20°: 80%, 4°C: maximum)
