End of charge voltage
Posted: 24 Aug 2022, 08:45
Hello all,
I have some issue with my new OSTC4. Although it is always indicating a high % regarding battery (always >80%), it shut down usually after 1h (of dive) or few hour of idle mode.
I did the firmware update v1.6 but the behavior stays the same.
When I check in Reset->Maintenance Mode the voltage indicates 3.55V (maximum i have ever seen) which is probably very low.
Could you confirm that i should see something higher?
Thx you a lot,
Tingsten
Thx you a lot,
Tingsten
