				ERR Showing in hpa and celsius
				Posted: 29 Apr 2023, 20:38
				by TDR
Computer glitched with large numbers in top left. Now shows err in hpa and celsius
				Re: ERR Showing in hpa and celsius
				Posted: 29 Apr 2023, 21:00
				by TDR
				Also cannot calibrate compass
				Posted: 29 Apr 2023, 22:07
				by TDR
				It’s pretty much bricked. I’ve updated the firmware. But it won’t let me access any menus.
				Posted: 30 Apr 2023, 08:17
				by TDR
				Left it overnight. Now the unit will not switch on
				Posted: 30 Apr 2023, 11:13
				When did you update FW, before or after error?
Was the FW upgrade successful?
To which FW?
Is it fully charged?
Did you restart it with a magnet?
				Posted: 01 May 2023, 11:24
				by TDR
				Hi, updated after error. Latest FW and it was successful. How to reset with magnet
				by TDR
				Yes it is fully charged
				Posted: 01 May 2023, 20:10
				Put the  OSTC4 on the charger and touch the left side with a strong magnet. That restarts the OSTC.
				Posted: 02 May 2023, 11:39
				by TDR
				Mmmm, dosent seem to do anything.
				Posted: 02 May 2023, 23:57
				by mikeller
				TDR wrote: 02 May 2023, 11:39
You should see the device power cycle and then start up when it's done the right way:
- the dive computer needs to be on the charger, and actually charging;
- touch the magnet to the metal casing of the dive computer, on the side where the circular opening for the battery compartment is, next to the compartment (or slide it over the entire side, to get the right spot);
- when it's working you should see the 'Heinrichs Weikamp' boot logo, and then the surface screen.
				Posted: 03 May 2023, 06:01
				- and the magnet has to be strong enough.
				Posted: 08 May 2023, 17:52
				TDR wrote: 29 Apr 2023, 20:38
"ERR" is short for "Error" and indicates a hard-defect at the pressure sensor. Since you are in contact with us already we'll have this fixed soon.
