Deco information suddenly disappears during dive in CCR mode
Posted: 20 Jun 2023, 06:07
by chrisrms
First to let you know, that I do have the latest firmware installed.
This problem did happen several times now, so I think there must be something wrong.
I experienced the problem, that the deco information suddenly disappears during the the dive, OSTC 4 is in CCR mode. The OSTC 4 is used as the backup computer.
Here an example what happened during last dive, deco information was counting down, all ok, from 15 meters, 12, 9, 6, to 3 meters where 12 minutes of deco where left.
So then at a moment during dive there where 12 minutes at 3 meters deco, but suddenly this info disappeared and I had an NDL of 240 minutes stated. For sure there where 12 minutes of deco at 3 meters left, the main computer of the JJ-CCR stated this 12 minutes.
Then at a later moment during the dive I manually changed back from 1.3 to 0.7 on the OSTC 4 and suddenly, after that change, the deco information was back to normal.
Perhaps this can be corrected/fixed please.
Re: Deco information suddenly disappears during dive in CCR mode
Posted: 20 Jun 2023, 07:37
Can you post the configuration of your ostc4 please.
I've been using the ostc 4 as ccr primary and backup. Having done over 150h of dives and never observed that issue.
Posted: 20 Jun 2023, 08:41
The displayed decompression information is logged. Can you download the dive with divinglog or subsurface and email us this dive, please? info@heinrichsweikamp.com
Also the deco mode, settings and firmware version would be of interest, of course.
Posted: 20 Jun 2023, 12:27
by chrisrms
Ok, I downloaded the dive to subsurface, but as i don't know this application, neither use it, what to i need to do, Export the dive? In which format? Would it be Subsurface XML format?
Other infos you need:
- deco mode = VPM +3
- firmware = 1.6.2 with RTE 3.10
Posted: 20 Jun 2023, 17:53
You can email me the subsurface XML file.
Posted: 21 Jun 2023, 05:46
by chrisrms
Ok, have sent it.
Thanks for looking into this.
Christoph
