OSTC 3 only USB no BT
Posted: 16 Jul 2023, 12:49
by TUC
my OSTC 3 allows BT data transmission but only USB. this happens with all the firmware that I have
3.17
3.19
3.20
3.21
Furthermore, if the companion SW works perfectly, Planner does not see the machine and does not allow me to change the settings (version 2.7.5 for mac) how can I fix it?
Re: OSTC 3 only USB no BT
Posted: 16 Jul 2023, 14:05
by dadefay
"my OSTC 3 allows BT data transmission but only USB" : could you clarify ?
"Planner does not see the machine and does not allow me to change the settings (version 2.7.5 for mac)" : you should better post this on a Planner forum.
Posted: 18 Jul 2023, 10:37
by TUC
sorry for my english. I try again to explain the problem:
when I access the menu where the BT function should be activated this is not displayed
the problems i have with planner are secondary to the BT not working.
Posted: 19 Jul 2023, 23:28
by TUC
help :roll:
Posted: 23 Jul 2023, 15:37
by heinrichsweikamp3
Just ignore the naming, this menu will start bluetooth just fine.
Posted: 24 Jul 2023, 11:26
by TUC
even if I can't find any trace on the manuals I think there are two versions of ostc3. One that connects via USB (only) and one that connects with BT. My USB menu if the cable is not connected does not open any submenus. what my OSTC2 did instead, this:
Posted: 27 Jul 2023, 09:26
by dadefay
I replied to your other post on July 16th : viewtopic.php?p=24336#p24336.
Regards.
