Ploywatch? Remove Scratches
Posted: 02 Jan 2025, 12:32
by Satyre
Hi
My screen is extremely scratched.
Does any of you have tried Polywatch that is used to restore minreal glass from vintage watches on their OSTC ?
Re: Ploywatch? Remove Scratches
Posted: 02 Jan 2025, 14:52
by Ralph
Have you checked that there is no screen protector attached to the glas? Sometimes it is hard to see, look at the outer edges of the screen for a jump in "screen hight".
Posted: 02 Jan 2025, 18:13
by Motardplongeur
Before trying "Polywatch" (which normally do not work so much w/ mineral glass ; only on plastic), you can test w/ toothpaste (the lowest price is the best one !) or what we call in France "Miror" (for silver or copper) ; or "pierre d'argent" (this is a paste).
Something to know : if you feel clearly scratches w/ your nail, no one product will solve your issue ; only small ones can be removed.
Posted: 03 Jan 2025, 11:13
by Satyre
Motardplongeur wrote: 02 Jan 2025, 18:13
Merci beaucoup je vais essayer d,abord avec le dentifrice puis le Miror
Posted: 03 Jan 2025, 11:14
by Satyre
Ralph wrote: 02 Jan 2025, 14:52
Good point on one of the OSTC there is such screen protecteor on the oldest one unfortunately no
Posted: 03 Jan 2025, 12:12
I doubt that you can remove the scratches properly from the glass. I think you should leave it as it is rather than trying to polish it with questionable means. A protective film may even help to fill these scratches. This will make them barely visible (Same refractive index then the glass).
Posted: 03 Jan 2025, 12:47
by Satyre
Well noted.
Thanks Matthias
Posted: 04 Jan 2025, 11:37
by Motardplongeur
Satyre wrote: 03 Jan 2025, 11:13
Tiens nous au courant !
