OSTC 2 (Mod. 2015) does not charge anymore
Posted: 01 Aug 2025, 12:51
by Motardplongeur
Having an issue w/ my OSTC 2 (#11150, last OS), which does not charge anymore. Battery was 63% and as I will dive at least 6 times, I decided to charge it. Arriving at 75%, it stopped to charge. I tried several chargers, using a new USC C --> A interface (limited to 18 W), the battery does not charge and its temperature is ambiant one. Even w/ a 96W charger (Apple one), nothing !
I put the charging pad on my iPhone 15 and it works (w/ a message "40 min from 56% to 80%) --> I guess the pad is OK.
On the information menu, battery is now 3.87 V (T0) & 2 cycles (even if I tried to charge it several times
Any idea about what to do / test ?
Thx for your attention.
Re: OSTC 2 does not charge anymore
Posted: 01 Aug 2025, 14:09
T0 is the wrong battery type for this OSTC 2 (Mod. 2015). Go to Menu -> Configuration -> Reset menu -> Reset Battery -> T3 and the charging will work again.
Posted: 01 Aug 2025, 19:18
by Motardplongeur
OK, done and now "T3" on the main screen (and now screen is showing 80% of battery).
Unfortunately, not charging more, still testing w/ several chargers. The OSTC is still at ambiant temp. and the charging pad led is approx 1 Hz flashing green. OSTC "on", I cannot find any position making the battery % being w/ a yellow rectangle.
Posted: 04 Aug 2025, 12:51
by Motardplongeur
For information, I bought this charging pad : https://www.amazon.fr/dp/B0F48DK57P?ref ... asin_title
Charge is now OK, even w/ the yellow rectangle w/o searching for the good position as it is more or less "blocked" by the bungee around.
Once more, Matthias, thanks.
Posted: 04 Aug 2025, 14:25
Thanks for the feedback!
Re: OSTC 2 (Mod. 2015) does not charge anymore
Posted: 29 Aug 2025, 18:07
We ordered one of these to test: https://www.amazon.de/dp/B0FGW4Z7ZX and can confirm that this charger actually supports the older Qi-Standard in the OSTC 2 Mod. 2015.
It requires an USB-C Power Adapter that supports 9V/1,5A (Most do).
Posted: 08 Dec 2025, 11:58
The "Goobay 59877" (The number is important) also still supports the old OSTC 2 (Mod. 2015) and is available via Online sellers.
