Compass Indications with v3.27
Posted: 01 Sep 2025, 16:13
by ClaudeDive
Hello Matthias
I updated my OSTC 3 #2430 to 327_FR_3_cr_ostc3_firmware.hex. Thanks for the update.
I calibrated the compass twice in all three axes in open fields on the grass.
I noticed significant instability when placing the compass on the ground in the grass, facing due north.
Once stabilized, the reading for due north varies between 45° and 135° after repositioning it several times.
Is this a problem compared to v3.27, or is it something else?
Thanks for your reply,
Sincerely, Claude
Re: Compass Indications with v3.27
Posted: 15 Sep 2025, 19:57
We have posted an easy to reproduce calibration method in the forum:
viewtopic.php?t=22618
Translated to the OSTC sport or OSTC plus/+:
Hold the OSTC in both hands and look to north more or less (Makes the calibration quicker)
Pitch axis: Rotate the OSTC slowly for 15 to 20 seconds while the screen is always facing to the right
Roll axis: Rotate the OSTC slowly for 15 to 20 seconds with the battery compartment always in the right hand
Yaw axis: Rotate the OSTC slowly for 15 to 20 seconds with the screen always facing up
Posted: 15 Sep 2025, 21:59
by ClaudeDive
I've recalibrated the compass facing north several times, exactly as you described.
Still the same problem on OSTC 3 #2430 with v.327_FR_3_cr_ostc3_firmware.hex!!!
- Hardware: 0E80-7205
- Sensor: 08F5-74B0
Will this compass issue be resolved with a future update?
Thanks for your help.
Posted: 16 Sep 2025, 17:36
by Motardplongeur
I don't know if it can help to find / solve this issue :
Same behavior w/ my OSTC 2 #11150 (built in 2015 or late in 2014 ?), since updated to 3.27 (was OK w/ 3.26) + calibration following your requirement
HW : 9181-3206
Sensor : 089C-6FC0
Posted: 07 Oct 2025, 15:29
by Motardplongeur
Any idea about time schedule to solve this issue ? (for both versions 3.27 & 10.85).
Did you already found the root cause ?
Not wanting to bother you, but to know if I need to recover my old compass in my diving stuff mess, for my next dives !!!
Posted: 09 Oct 2025, 10:38
The 3.28 with this bug fixed is now available. If you have 3.27 already and NOT using an old OSTC 3 the update is not required.
Posted: 09 Oct 2025, 15:43
by Motardplongeur
Oups, I missed it ; thanks.
Posted: 10 Oct 2025, 01:15
by ClaudeDive
Thank you, Matthias.
The compass is working perfectly again
Sincerely, Claude
