OSTC 5 Compass not working and has never worked
Posted: 09 Sep 2025, 04:54
by Divert
The compass of my OSTC 5 is still not working and has never worked, I thought a firmware update would take care of this but no. I can't seem to calibrate it, and therefore the reading is wrong and inconsistent to pitch angle.
Here is the video of me trying to calibrate which does not pass from half the pitch portion. And the inconsistent result of the compass after the calibration process.
https://youtu.be/7iBTmYR54ho
Please advice.
Humberto.
Re: OSTC 5 Compass not working and has never worked
Posted: 09 Sep 2025, 09:31
In your Video you're rotating every other axis then the pitch axis. That will not work like this. The manual describes this in more detail and we have a video for the old OSTC sport (Which we emailed you already) and will make a video for the OSTC 5 sometime in the future.
Posted: 15 Sep 2025, 17:02
by Divert
Thank you, I guess I don't have. A clear understanding of which is the pitch axis, I will check the video and keep trying.
Posted: 15 Sep 2025, 17:40
How to calibrate the OSTC 4 or 5 in less then 15 seconds:
Hold the OSTC in both hands and look to north more or less (Makes the calibration quicker)
Pitch axis: Rotate the OSTC slowly while the screen is always facing to the right
Roll axis: Rotate the OSTC slowly while the buttons are always facing to the right
Yaw axis: Rotate the OSTC slowly with the screen always facing up
You'll see all graphics will turn green quickly.
Posted: 18 Oct 2025, 13:49
by UrsiGill
Ugh, compass calibration is always the worst part of a new dive computer setup. 😖
Matthias is spot-on—it totally looks like you're trying to roll it instead of pitching it during that part of the sequence.
The easiest way to visualize the pitch rotation is to hold the OSTC flat like you're reading it on the surface, and then slowly tilt it forward and backward (like nodding your head) so the screen faces the sky, then the horizon, then the seabed.
It's super counter-intuitive, but once you get that motion right, it usually flies through the rest of the calibration!
You can also try this tool for free. https://123compass.org/
Posted: 02 Nov 2025, 02:35
by Divert
I does not work no matter what I do. I have tried so many times. There's only 3 possible axes of rotation I have tried every one of them with no luck.
Here is yet another video of my trying what @heinrichsweikamp (matthias) suggested and also what @UrsiGill suggests. Nothing works.
https://youtu.be/SZM0XC9ZAKs
Matthias could this be related to the ostc4 battery inserted into the ostc5 ?
Is this hardware issue, software? I am running #1517 V1.7.3 firmware.
Humberto
Posted: 07 Nov 2025, 08:09
by Thorsten
Hi Humberto,
I had a look at the video and it looks like you missed one direction while turning the OSTC (only half turn) you see that the pitch is 50%.
You can do it by try and error => start turning the OSTC and check if the bars are changing to green. If they do it is the correct axis. If not try another one.
Posted: 12 Nov 2025, 00:31
by Divert
Thorsten wrote: 07 Nov 2025, 08:09 Hi Humberto,
I have done this litteraly a hundred different times! every possible way, even spend the whole time in each one of the only 3 possible axis, nothing works, it never gets past 50%. I can tell you. It is not me doing it wrong. I can assure you. What else can it be? Hardware? Software?
Please help me, I want to use my OSTC5 But without a compass it is not very useful.
Humberto.
Posted: 12 Nov 2025, 05:29
email HW to have the unit looked at...
Posted: 13 Nov 2025, 21:24
by Divert
swissdiving wrote: 12 Nov 2025, 05:29 email HW to have the unit looked at...
Posted: 14 Nov 2025, 08:56
Rotate slower, point the unit to north, skip to the next axis ONLY when the first is done. Only rotate one axis at a time (In your last video you're mixing the axis in random order). This post viewtopic.php?p=25123#p25123 clearly describes what to do.
Posted: 16 Nov 2025, 11:28
by Thorsten
Hi Humberto,
I tried to reproduce it with my OSTC5 and have to agree. Even if you missed one half turn with all your movements the measurement points of the axis should be matched. By the way: The visualization is just a guide to support the calibration. In the background the OSTC is measuring all axis and doing the calibration stuff => The result of the video should be a usable calibration.
The sensor seems to be working because a part of the curve is green. Is it green from the beginning or changing while you start moving?
Could you restart the RTE (there is a menu item in the reset menu) or do a poweron reset (by removing the battery or with the magnet while charging) and check if the behavior changes?
Kind regards,
Posted: 04 Dec 2025, 19:39
by Divert
Thank you a lot for looking into this. Of course I will do in this order:
  • RTE Reset
  • Magnet Reset
  • Battery poweron reset.
And report back.
Actually, I found a way to get past the first half. By swinging the DC, very hard ¡like a roller coaster! but still have not been able to finish all three in the minute given.
Posted: 05 Dec 2025, 20:40
by Divert
Thorsten wrote: 16 Nov 2025, 11:28 Is it green from the beginning or changing while you start moving?
Kind regards,
It gets green as I move it, first halve gets green almost imediately, the rest is quite difficult.
Posted: 01 Jun 2026, 12:51
by UrsiGill
Reading through the videos and replies, it honestly sounds less like a calibration technique issue and more like the sensor is struggling to register the full motion range consistently. The fact that it always stalls around the same point after so many attempts is what stands out to me.
One thing that helped me understand pitch/roll/yaw movement better was comparing the rotations against a simple compass/orientation reference like https://123compass.org/. Not saying that fixes the OSTC itself, but it made it easier to verify I was actually rotating around the intended axis. If the behavior still stays identical after the resets, I'd definitely lean toward having HW inspect the unit.
