Beta 1.12 available
Posted: 19 May 2008, 09:45
Die neue beta 1.12 ist nun verf?gbar. Es gibt ein neues Untermen? "Battery Information", das Startgas wird im Oberfl?chenmodus nun permanent angezeigt, einige Fehler wurden behoben und ein neues UW-Men? hinzugef?gt in dem jetzt ein 6. Gas w?hrend des TG konfiguriert werden kann.
Eine neue stabile Version folgt in ca. 2 Wochen, Kommentare zur Beta sind wie immer sehr gerne gesehen.
http://www.heinrichsweikamp.net/ostc/de/details.htm
Viele Gr?sse,
Matthias Heinrichs
The new beta 1.12 is now available. It has a new submenu "Battery Information", shows the start gas in the surfacemode, some bugfixes and a new underwater menu where a sixth gas can be configured during the dive.
A new stable version will follow in about 2 weeks, comments to this beta are very welcome.
http://www.heinrichsweikamp.net/ostc/en/details.htm
Matthias Heinrichs
Re: Beta 1.12 available
Posted: 20 May 2008, 15:21
by greenforce
I installed firmware 1.12
As result:
Added Battery Information Menu
OK
Battery LED blinks two times when battery is >90%
Not tested
Start Gas is Displayed in Surfacemode
OK
Removed Gradient Graph in Surfacemode
Graph still appears in surface mode...?
Renamed underwater Menu "Set Gas" to "Gaslist" (Select gas from the Gaslist)
OK
Added Underwater Menu "Set Gas" (Configure a Gas manually during the dive)
OK, good idea!
Added Event "Manual Gas change" in profile routine
OK
Fixed bug in deco forecast
I don't think the bug is fixed. I tried with the simulator:
TX 18/20
Nx 75 as deco gas (set to 11m)
The given deco time is the assumed deco time with bottom gas. It changes (reduces) only when I switch gas (to Nx 75) at 10m.
Is it not supposed to give total deco time considering all activated gasses?
Posted: 20 May 2008, 20:42
by Nikolas
No, it does not appear any more. The start gas is displayed instead.
Posted: 20 May 2008, 21:08
by greenforce
Sorry but on my display, the graph still appears in surface mode, above the start gas. ;)
Posted: 20 May 2008, 23:04
Actually, the graph for the tissue saturation (N2 and He) are still there. You can also select them underwater (Underwater menu "Display"). The combined third graph (showing the GF state) is removed. It was not very helpful.
We have to do some test with the other issue....
