Jdivelog on Mac
Posted: 01 May 2010, 13:19
by Djeeker
Somehow I cannot connect my OSTC to my Mac to have the updates and transfer my logbooks.
I installed (i think) the USB drivers software and I am running Jdivelog vers 13 but somehow he does not allow me to select the OSTC (or any other device) in the settings menu?
Anybody experienced this before?
Any suggestions?
Re: Jdivelog on Mac
Posted: 02 May 2010, 19:37
by plauzer
hey... what elese did you do before you encountered that problem? btw what OSTC (mk I /II)? e.g. Mac(model) OS version do you run? my Settings for Jdivelog are: Com Port: /dev/tty.usbserial-A4004nSK (RXTX-2.1) Protocollversion: OSTC 1.19-1.25 G5 OS 10.5 one more question, can you also ask in German?
best regards Plauzer
Re: Jdivelog on Mac
Posted: 05 May 2010, 00:23
by Divingschnorbitz
Hi I have managed to connect my ostc2 to JdiveLog on my mac to use as a logbook and it's great but please can someone explain how to use it to download the latest firmware 1.6. Thanks!
Re: Jdivelog on Mac
Posted: 05 May 2010, 14:40
Updating the firmware with Jdivelog is actually not more complicated then with the Windows-Bootloader:
- Download firmware hex file for the correct unit (OSTC1 or Mk.2!)
- Select Tab "OSTC Firmware Update"
- Choose correct COM port
- open hex file in file dialog
- Power-on OSTC Mk.2 and go into 'Menu->Reset menu'
- Click "write flash" in jdivelog
- select and confirm "Reboot OSTC" in 'Reset Menu' within 10 seconds
Wait about one minute.
Re: Jdivelog on Mac
Posted: 15 May 2010, 16:19
by tacks
@DjeekerTry this:
http://www.tecdivers.co.uk/index.php?showtopic=49
I installed it this way on a MacBook Pro
cu
tacks
Re: Jdivelog on Mac
Posted: 15 May 2010, 16:50
by Divingschnorbitz
Worked beautifully, first time, Thanks!
Re: Jdivelog on Mac
Posted: 28 May 2010, 23:38
by Djeeker
I tried the method of tecdivers..
I have even tested the manual mode and writing the code.
I have a Mac Book Pro, running Snow Leopard 10.6
I seem to have the USB RXTX files
When I connect the OSTC MK2 version 1.50 to the USB port it is charging but still in JDivelog I cannot select him from the list..
Should I try ALL the USB ports on the Macbook or is it not important which port I take..?
Getting desparate,
Re: Jdivelog on Mac
Posted: 29 May 2010, 18:03
by Djeeker
I actually can select the OSTC as the computer but all the COM settings remain unselectable?
Re: Jdivelog on Mac
Posted: 29 May 2010, 23:22
by Djeeker
Hello to all,
Finally it works..I did the stuff again and believe I must have done something wrong while setting up JDivelog..
Thanks for all of your help..
Djeeker
