Blue flashing light and tissue loading graph
Posted: 08 Aug 2010, 17:40
by Manxdiver
Hi Guys
This is my first post after receiving my OSTC 2 yesterday (v1.70 software). I've searched the wiki and forum, but have 2 questions which are puzzling me.
I dived the computer this morning with a gas switch and all went well. After surfacing now:
1 There's a blue flashing LED on the left hand side - what does this mean (computer is still desaturating)
2. In between the He and N graphs, there's a number (in my case 80) - is this referring to the battery capacity ?
Really impressed with the computer by the way.
Dave
Re: Blue flashing light and tissue loading graph
Posted: 09 Aug 2010, 13:24
by David Boileau
The blue LED flashes until no-fly time comes to zero - you have also the no-fly time displayed in surface mode.
For question 2, I don't know
David
Posted: 09 Aug 2010, 15:51
by Manxdiver
Thanks David - that makes sense and the blue LED stopped flashing late last night.
Dave
Posted: 11 Aug 2010, 13:03
The number indicated the current saturation load of your leading tissue. Depending on the tissue this can be a value between 80 and 200%.
Posted: 11 Aug 2010, 17:31
by Manxdiver
Hi Matthias
Thanks for the answer. I presume the lead tissue is at 80% (N2) saturation long after a dive due to the pp of N2 in air being 80% ?
Best wishes
Dave
Posted: 12 Aug 2010, 12:07
Yes, it's because of that. Nevertheless the number only gives a rough estimation. NoFly and Remaining saturation time should be used to give an orientation about tissue load.
Christian
Posted: 12 Aug 2010, 20:07
by step
Ist es möglich die Graphenanzeige dauerhaft zu unterdrücken und stattdessen nur die Gase anzeigen zu lassen?
Posted: 15 Aug 2010, 16:50
by oscar
i am an italian diver and i speak so and so english
Yesterday I made a dive to 80 meters in tx, this morning gave me as MANXDIVER th
and I had no fly O and desat time 0.
Is correct or not? is possible have after 8 our and afterm my dive at 80 meters no fly 0 and desat 0???
thank you
Posted: 16 Aug 2010, 08:24
by Steve
I think 8hrs is very fast
did you change the desat and no fly CF's? Can you give the numbers for these CF's?
Posted: 16 Aug 2010, 10:18
by j.thummel
Can be possible depending on your back and deco gas.
Posted: 16 Aug 2010, 10:26
by OSCAR
the tx are 15/40 and the deco gas ean 32 and ean 50.
the number of this cf. is:
cf 11 saturate 110
cf 12 desaturate 90
cf 13 nofly ratio 70
thank you....
