pb with temperature
jujube
pb with temperature
Post by jujube »
the temperature given by my MK2 is + 4° than "real" compare with 3 other sensors
Re: pb with temperature
Are you charging the unit while reading the temperature? This causes some degrees difference because of losses in the charging circuit. If the unit is not attached to USB and temperature has stabilized with the room temperature you won't see much difference to other sensors.
jujube
Post by jujube »
the difference is during the dives... not in my room... strange
Mike
Post by Mike »
Hallo, Ich habe das gleiche problem, letzte grosse Tauchgang, 35' zwiechen 35 und 47m, und hatte 12° als anzeige in einem See wo die Températur bei 4-6° ist.
Mike
Post by Mike »
Hat jemanden info über wie man die Temperatur richtig einstellen kann ?
Habe immer noch 3-4° mehr als das richtige asser oder Raum températur ?
MFG
Mike
