airplane and dive mode
Posted: 27 Jun 2008, 21:47
Hey,
Returning from work/holiday, I was bored and playing a little with the ostc (checking logbook etc). The plane started to land, and the ostc went in dive mode. Now, since I couldn't ask the pilot to go up and depressurize the cabin a little bit for a few minutes, the ostc is in dive mode ever since. I'm now already diving 231 minutes on 2,5m depth
. It's solved now by connecting the interface and pushing the reset-button. I just wonder two things:
1/ Would an 'airplane mode'-feature make any sense? This means, in this mode, the computer cannot go in dive mode. Just to prevent this happens again...
2/ The ppO2 was 'too low', which makes perfectly sense. However, I was thinking: imagine a go on a dive in a lake on 3000 meter - I do not intend to do this - the oxygen pressure there is low. Whenever I would be diving with air, at shallow depths, the I would have the ppO2-warning on shallow depths (unless I put the treshold lower, but in that case, the computer would give continuous warning that the treshold is set to low).
Well, just some thoughts...
Kurt
Kurt
