Simulator
Posted: 06 Dec 2010, 07:32
by dmainou
Over the past month or so there has been a number of posts involving the simulator. One of the outcomes of the posts has been that it has become apparent that the user requires to exit the simulator and all menus before running the simulator a second time in order to obtain consistent results.
A couple of posters have indicated that if the simulator is run a second time without exiting the menus first then the OSTC implies that it is a repetitive dive and therefore it adds more deco to the calculation.
Would you please be so kind to explain what is the actual behaviour? Furthermore, if the OSTC is actually calculating the "second" run as a repetitive dive then what is the expected surface time, etc.
Thanks,
D
