Simulator in OC mode
Posted: 11 Jan 2011, 01:19
Hello, i have a question about the simulator.
I noticed that it calculates some different deco plans for the same dive.
Here are comparisons of deco plans calculated by the OSTC according to several scenarios.
the file is located here:
http://lbardass.free.fr/images/plongee/Deco% 20OSTC.htm
two tabs are used.
* Variation OSTC: provides various simulations by OSTC using various actions (back to previous menu, return home, reset ...)
* Déco algo : compares deco plans by OSTC with plans generated by different programs : MV-MAP, GAP, HLP, SUUNTO.
I only used the OC algorithms.
The parameters used are provided in the header tabs.
Versions of the firmware used were 1.70, 1.74 and 1.75.
The three versions provided the same results.
* Algorithm with the ZH-L16 (GF11 and 12 default), the total length of stops is the same : 7 minutes.
Only duration varies for the stop at 6 and 5m.
* Algorithm with the L16-GF, the differences are more important.
When no parameter is changed between each simulation, the stop duration is between 10 and 13 minutes with stop at 12m canceled according to the simulations
* If i compare OSTC L16-GF (10 to 13 minutes), the results are almost the same with MV-PLAN (11 min) and GAP Buhlman mode (B or C at 10 min) : the deco plans are very close.
I still do not understand why and how the simulator by OSTC calculates some differents plans Deco for the same dive. This goes against the principle of an algorithm : for a given set of parameters, it should provide identical results.
Maybe the simulator uses other parameters such as pressure, temperature ...
I don't think that successive and consecutive simulations can explain différences : times total tier vary downward or upward so that the simulations are strung one after another.
Returns to the menu, reset deco : those actions had no effect on the stability of deco plans.
Any ideas ?
two tabs are used.
Any ideas ?
