problem to connect OSTC mk 2 to PC
Posted: 19 Jan 2011, 20:22
by jean-michel
Hello
I have a curious problem
after installing the OSTC mk 2 to my PC :
the PC correctly reconize the OSTC
I can correctly download from divinglog 5.0 and even change some settings of the OSTC from divinglog
but it is impossible to connect to the OSTC with the tiny bootloader
here is the message I got
Connected to \\.\COM20 at 19200
ERROR!
running my PC under win7 64bits
and already change the com port to try to fix the bug ....
please help
thank you in advance
Re: problem to connect OSTC mk 2 to PC
Posted: 19 Jan 2011, 20:24
by jean-michel
I forgot to mention : yes I do wake the OSTC and connect it to the pc before running bootloader
Posted: 19 Jan 2011, 21:39
by jean-michel
I also tried JDivelog tonight
it is possible to download dive profiles and change some settings, but as soon as I try to make the firmware update I got the message
"communication impossible did you press reset ?"
so may be I have not understand something : how to "reset" for making the firmware update ?
Posted: 19 Jan 2011, 21:54
by darran taylor
Mine is doing this too, tried it on win 7 64 bit and 32bit. It wont connect to jdive log either
Posted: 19 Jan 2011, 22:05
by jean-michel
solve the problem : I have done a reset (in the ostc menu) just after launching jdivelog
Posted: 19 Jan 2011, 22:16
by Darran Taylor
got mine updated now, i wasn't doing it correctly. i was waiting for it to find the ostc before resetting it
