Two question/sugestion on CC mode
Posted: 27 Jan 2011, 17:56
by Tybo
I'm now using the MK2 for a full week of diving in rebreather. And have two question/suggestion.
1° Why when we switch to BailOut and back to CCR, the computer didn't select by himself the gas 1 (the diluent) ? Can be a good thing I think. As it is one manipulation less to do while going back from OC to CCR.
2° why the SetGas menu isn't available in the L16-GF CC mode ? Even after switched to BailOut. I think it can be useful to be able to modify the gas underwater as it is possible in OC.
See You
Tybo
Re: Two question/sugestion on CC mode
Posted: 27 Jan 2011, 21:53
by sailor
#1 - this way you can switch diluent, that was'nt possible before
#2 - you can do that the same way you do in OC, just select the 6th gas and alter it
Posted: 28 Jan 2011, 19:36
by Tybo
Thanks for such a rapid answer !
I'll try to do that... actually I'm using the 1.70 version and apparently I don't have access to the 6th gas... I try to Upgrade to the 1.8 version... I'll see.
See You
Tybo
Posted: 28 Jan 2011, 20:14
by Tybo
I switched to 1.80 and it works perfectly !!!!
thanks !!!
