allarm at 6m
Posted: 24 May 2011, 10:23
by maxtosca69
Ciao a tutti,
In two consecutive dives my computer showed a red alarm (21m - 1') when I was at my last 6m Decostop.
Can someone explain why?
The firmware is the new 1.90
Re: allarm at 6m
Posted: 24 May 2011, 10:51
by tiefunten
as far as i understand, this is the same issue already being dicussed in this Thread: Gasverlust bei V. 1.90
So far, nobody knows what's going wrong there, but nobody from heinrichsweikamp answered yet.
Re: allarm at 6m
Posted: 24 May 2011, 11:14
by maxtosca69
I know, but I don't speack german
Re: allarm at 6m
Posted: 24 May 2011, 15:29
by JeanDo
I did investigated this, but found nothing yet..
* Can you tell us what are the parameters used (Full gas list, gas switch, etc...) ?
* Did you change active gas during dive (Lost gas menu) ?
* Anything else special ?
Many thanks !
Re: allarm at 6m
Posted: 24 May 2011, 16:01
by maxtosca69
Hi JeanDo, this is the answer I was waiting for.
Max depth: 52-53m
Bottom time: between 24 and 25min
First stop: 27m - 1'
first gas switch: 21m (EAN 50) - 5'
Then 12m -1'; 9m - 3'
second gas switch: 6m (OX) - less than 9' (3' at 6m plus 6' at 3m that I don't respect).
Sorry for my "spaghetti" english!
Re: allarm at 6m
Posted: 24 May 2011, 16:50
by JeanDo
I suppose you are using GF 30/90. Air as first mix. And CF55 = 5' (gas switch delay).
Correct ?
[quote]
maxtosca69:... 6m (OX) - less than 9' (3' at 6m plus 6' at 3m that I don't respect).
Just a question about your reply
Why don't you set CF29 to 6m, so the OSTC will predict the right TTS from the beginning ?
Thanks !
Re: allarm at 6m
Posted: 24 May 2011, 18:05
by maxtosca69
actually I don't setup CF55 as you have told me (so 0'); I set CF 29 at 3m (maybe for the last time); my GF are 15/80, but the allarm appears only with the new firmware.
Also I don't understand yet how Cf55 works, I mean if i put 5' on the switch gas stop at 21m (which have normally 1' stop) I obtain 6' or it maintain 5'? Boh!
In any case with the last firmware I didn't have those prolems
Re: allarm at 6m
Posted: 24 May 2011, 18:08
by Uwe S.
Hello JeanDo,
Settings: GF 30/85 Last Stop 6m, Gas switch delay 3 min, Gas1 Air, Gas2 21/35, Gas3 17/50, Gas4 50, Gas5 O2
Bug in Simulator: It happens only with Gas switch delay and the 2 deco gases (4 and 5). Change to 50@21 everything is ok, no change to O2@6 in red 21m for 3min and loop. Change to 50@21 everything is ok, change to O2@6 short in red 21m for 3min and then normal deco and count down is ok.
This happens with Air, 21/35 and 17/50 as first gas with the 2 deko gases (4and5)
I don`t now if the bug is also in a real time dive.
Hop this helps. Regards Uwe
Re: allarm at 6m
Posted: 24 May 2011, 18:11
by maxtosca69
18.08
Actually what i don't understand about the cf55 is :on default it gave me 1 min,if i do set it up 5min these would it be added to the 1 min default?
Or is it just 5 min?
Re: allarm at 6m
Posted: 27 May 2011, 01:40
by peppe.marsala
maxtosca69 Wrote:
> 18.08
> default?
It goes from 1 min to 5 min total, no adding.
spero di essere stato chiaro
Re: allarm at 6m
Posted: 31 May 2011, 11:11
by JeanDo
CF55 sets the minimum decostop time at switch depth. Because you spend some time there, it does changes the remaining part of the decoplan (shortening and/or enlarging them).
This spurious stop do appear for a few seconds sometimes during the dive, but only with 3 or more gases. I am currently testing a patch to correct that.
Thanks for the detailed reports.
Re: allarm at 6m
Posted: 31 May 2011, 14:32
by wrobell
> that.
Actually, I am noticing the similar behaviour with
one gas and OC/GF, too. This bug exists for at least
2 years.
Basically it is triggered when you dive to at least
30-40 meters. Then go slowly up (i.e. reef dive)
and keep yourself within NDL. At some stage you
will get suprising deco stops, which get cleared
after minute or two (or three
). The deco stops
are suprising because you expect your NDL to be
at least 10 minutes or more at that time (in other
words you have 10 minutes NDL, then in a second
deco stops and then 10 minutes of NDL again).
I can provide binary data, which contain dive data
on which I experienced above if you wish.
Re: allarm at 6m
Posted: 11 Jun 2011, 23:36
by Boefst
Hi all...
I got the same behaviour today. At 6m, warning for missed deco at 21m. Came on and off a couple of times. Similar depth, time and settings as "maxtosca69".
V1.90
First dive 49,5m BT30min, OC GF:25/85
G5: Tx20/30 (First gas)
G2: O2 100
G3: NX50
Switch to G3 at 21m, G2 at 6m, Last stop 6m
Second dive 46,9m BT25min, OC GF:25/85
G5: Tx20/12 (First gas)
G2: O2 100
G3: NX50
Switch to G3 at 21m, G2 at 6m, Last stop 3m
OSTC 1673
Re: alarm at 6m
Posted: 12 Jun 2011, 09:15
Thanks for reporting. Did you change CF55, as well? We'll have an update for this issue available soon.
Re: alarm at 6m
Posted: 12 Jun 2011, 09:35
by Boefst
Yes, CF55 set to 1
Re: alarm at 6m
Posted: 15 Jun 2011, 21:35
by maxtosca69
I also set CF55 to 1
Re: allarm at 6m
Posted: 15 Jun 2011, 22:19
by sailor
In my case CF55 was set to default and it happened aswell.
Re: allarm at 6m
Posted: 19 Jun 2011, 21:01
by maxtosca69
Another way!
44m in air
First deco stop at 21 in ean50 for 5 min
15m for 1min in ean50
9m for 1 min in ean50
6m for 10min in ox ... and the red allarm: 21m for 3min!!!
Re: allarm at 6m
Posted: 20 Jun 2011, 11:13
by Gucky
Hallo maxtosca69,
das Problem ist offensichtlich in Bearbeitung.
Schalte einfach CF55 so lange auf 0 und mache den Stop trotzdem 5 min. wenn Du magst.
Die Deko wird richtig berechnet ...
Re: allarm at 6m
Posted: 21 Jun 2011, 15:45
by JeanDo
Hi all,
I corrected a typo this weekend, and make 2 test dives: I think I got that bug... Will be on next beta (1.91beta) due soon.
Thanks for all the reports.
Re: allarm at 6m
Posted: 30 Jun 2011, 06:14
by maxtosca69
Caro Gucky,
mi fa piacere constatare che il tuo elevato grado di intelligenza e il tuo spiccato amor di patria ti porti a credere che il tedesco sia la lingua mondiale e che quindi la maggior parte delle persone lo parli, ma ti assicuro che non è così!
Piuttosto è Roma che ha conquistato il mondo quindi mi aspetto che tu capisca al volo ciò che ho scritto.
Auf Wiedersehen
Re: allarm at 6m
by maxtosca69
Thanks so much
