Memory Map
Posted: 28 May 2011, 13:24
by Rob
Hallo zusammen,
ich bin auf der Suche nach einer Beschreibung der Speichermap des OSTC für
-die custom Settings
-die gespeicherten Tauchgangsdaten
Gibt es irgendwo so eine Beschreibung für die unterschiedlichen OSTC Firmware-Versionen?
Ich habe schon im repository und im v1.90er Code gesucht aber nicht wirklich etwas gefunden.
Robert
i'm searching for a description of the memory map for
-custom settings
-the saved dives
is there a description for the different OSTC firmware versions?
i-ve looked in the repository and in the v1.90 code but i coudn't find something.
Robert
Re: Memory Map
Posted: 28 May 2011, 18:24
Attached is the description for the interface with a PC. It includes the dive profile format and the commands to access the data via the USB port.
Re: Memory Map
Posted: 28 May 2011, 18:32
by wrobell
as well, if you are looking for parsers
1. Java: jdivelog has one (sorry for lack of url)
2. Python: kenozooid has one (sorry for self ad): http://git.savannah.gnu.org/cgit/kenozo ... /parser.py
3. C: libdivecomputer has one: http://libdivecomputer.git.sourceforge. ... .c;hb=HEAD
Re: Memory Map
Posted: 25 Jun 2011, 12:16
by Brabbel
is there an update for V1.91 of the ostc_interface description document included in the post above available?
I would like to update my logbook program to the new logbook format.
Maybe the interface specification could be put into the repository, so everybody can access the most recent version instantly.
Brabbel
Re: Memory Map
Posted: 25 Jun 2011, 13:03
by Rob
Hi Brabbel,
MAtthias posted one here
in the thread Logbook memory map - is this normal
But i think he has a newer one.
Re: Memory Map
Posted: 25 Jun 2011, 14:14
Attached is the latest one.
Re: Memory Map
Posted: 25 Jun 2011, 22:07
by brabbel
thanks for the document. Fortunately there are only minor changes and the profile data is unchanged.
Brabbel
