Gauge Mode - Stopwatch & Average Depth
Mark Emery
Post by Mark Emery »
would it be possible for a slight change to be made to the stopwatch function when the OSTC MK2/N is in gauge mode?
I would like the stopwatch to be displayed right below 'Dive Time' in the same font size and for the right button to reset the stopwatch with a single press. 'Stopwatch' should be permanently displayed under 'Dive Time' while in Gauge Mode (during a dive).
Average Depth display is ok where it is but it should be displayed at all times in gauge mode (during a dive). I normally only reset the average depth once on a dive so using the current method of 'Menu' then 'Reset Average Depth' is ok.
I only use my unit in gauge mode for ratio deco. These updates would make it perfect.
Many thanks in advance.
Mark.
pem
Re: Gauge Mode - Stopwatch & Average Depth
Post by pem »
+1
There is a shortcut to reset the stopwatch: Left - Left - Right
The right button toggles the different custom views, so a single click reset is not possible.
A stopwatch with big letters has been added and will be available in the coming 1.91 firmware.
Here's a screenshot of how we implemented this in Gauge mode now:
[img]http://www.heinrichsweikamp.com/file.ph ... e=OSTC.jpg[/img]
What do you think?
