Simulator operation question
Posted: 31 May 2011, 12:02
by david tobin
Am I correct that when the simulator/decoplanner is run it is not affected by any diving history.
Therefore if I run it after the first dive of the day with the info for a second dive, the info from the first dive does not affect the output.
Re: Simulator operation question
Posted: 31 May 2011, 23:49
by peppe.marsala
mmmm... it sholud be affected by the desaturation time...
Posted: 01 Jun 2011, 07:27
Assuming you have 1.8 or later installed, the tissue load from real dives is taken into account for the simulation, of course.
Posted: 01 Jun 2011, 07:52
by peppe.marsala
Which is the way it has to work ;) David, if you want to use a plain simulator then you have to reset your deco data before (but don't go for a ripetive dive :))
Posted: 01 Jun 2011, 09:54
by david tobin
Yes I have 1.9 installed.
Thank you for the quick response
