New 1.91 beta available for the OSTC 2N/Mk.2
Posted: 21 Jun 2011, 19:32
Diesmal nur in Englisch, dafür etwas ausführlicher. Ich denke, es ist aber für alle Verständlich.
Today, the new 1.91 beta has been released.
Most important:
1) When downgrading again from 1.91 to 1.90 you may loose your dive profiles!
2) After installation of 1.91 the internal logbook will be converted into the new format. This takes about eight minutes and can't be interrupted.
3) Right now, only the newest alpha from Diving Log supports the new format, so as a Diving Log user you'll need to update. Most likely, the link to the update will be published on the Diving Log Blog soon: http://www.divinglog.de/blog/
Important new Features/Bugfixes:
- The spurious stops when CF55 was >0 and diving with more then two gases were fixed
- The OSTC now records some extra data during the dive and you can see them in the logbook (Average depth, GF and Deco Settings, CNS)
- We have doubled the logbook capacity. Yes, with the default settings for sampling rate and divisors you can now have ~40 instead of ~20 dives (1h) in the internal logbook! As usual, you don't have to pay for the extra memory
- The clock is now accurate - as discussed here intensively, this turned out to be a bug and not an inaccurate oscillator.
- For our Nordic friends, the OSTC now records all negative water temperatures correctly.
Details about the upgrade process: http://www.heinrichsweikamp.com/read.php?2,4071
The link to the firmware: http://www.heinrichsweikamp.com/en/ostc_2n/firmware/
The new bootloader PC application (That downloads the firmware and installs it with two mouse clicks) will be available for the next stable. Due to the "CF55 Bug" we may publish the new stable 2.0 faster this time.
If there are any questions and/or comments, please post them here.
Most important:
