OSTC 2n Ascent rate display ?
Posted: 22 Jun 2011, 19:11
by Dahab Boris
Hi All,
I have looked at the 2n .pdf manual and list of custom functions..
CF05 seems to say it will display the ascent rate if exceeded ? Is there normally an assent rate display as I can't see one.. How is the alert displayed ? I know stated in another post there is no audible alarm..
This link seems to say there is an ascent rate display:
http://deep-ideas.co.uk/Store/index.php ... cts_id=251
Any tips appreciated
CF05:threshold in m/min for display of vertical velocity
This value sets the threshold of the vertical velocity. When reaching this value, the OSTC displays the velocity in the divemode.
Recommend range: 5 ... 15 (5m/min...15m/min)
Default setting: 7 (7m/min)
Example: CF05=10 - When the OSTC detects 10m/min or more vertical velocity the velocity is displayed in the divemode
Re: OSTC 2n Ascent rate display ?
Posted: 22 Jun 2011, 19:52
by nakatomi
Hi DB,
there is no permanent display of the ascent rate.
Once the ascent range exceeds the rate configured in CF05 (default = 7m/min), it is displayed below the current depth.
Once it exceeds the maximum defined in CF47 (default = 15m/min), it is also displayed below the current depth, but in that case in the "warning" color (default is red).
Posted: 22 Jun 2011, 21:23
by Dahab Boris
Oliver,
Sounds perfect, thanks for the info.
