pb compil since changeset 415 (solved)
Posted: 18 Jul 2011, 21:33
Hello
did you change something in the way to compil from source since rev 415, because since this changeset, I get some errors when I compil with mplab:
here is the errors I get:
thank you for your help
Error[105] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DEFINITIONS.ASM 95 : Cannot open file (Include File "shared_definitions.h" not found)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\ISR.ASM 43 : Symbol not previously defined (int_I_pres_respiration)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\ISR.ASM 44 : Symbol not previously defined (int_I_pres_respiration)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 152 : Symbol not previously defined (char_O_first_deco_depth)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 193 : Symbol not previously defined (char_O_CNS_fraction)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 205 : Symbol not previously defined (char_O_gradient_factor)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 442 : Symbol not previously defined (char_O_nullzeit)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 471 : Symbol not previously defined (char_O_first_deco_depth)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 474 : Symbol not previously defined (char_O_first_deco_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 489 : Symbol not previously defined (int_O_ascenttime)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 490 : Symbol not previously defined (int_O_ascenttime)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 496 : Symbol not previously defined (char_O_gradient_factor)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 512 : Symbol not previously defined (char_O_gradient_factor)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 532 : Symbol not previously defined (char_I_dive_interval)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1142 : Symbol not previously defined (char_I_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1145 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1149 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1193 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1475 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1484 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1490 : Symbol not previously defined (char_I_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1493 : Symbol not previously defined (char_I_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1496 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1500 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1517 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1731 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 1732 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 2601 : Symbol not previously defined (char_O_first_deco_depth)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 2612 : Symbol not previously defined (char_O_deco_depth)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 2613 : Symbol not previously defined (char_O_deco_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 2944 : Symbol not previously defined (char_O_tissue_N2_saturation)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 2990 : Symbol not previously defined (char_O_tissue_He_saturation)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3048 : Symbol not previously defined (char_O_gtissue_no)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3050 : Symbol not previously defined (char_O_tissue_N2_saturation)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3122 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3152 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3188 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3198 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3202 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3249 : Symbol not previously defined (char_O_EAD)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3256 : Symbol not previously defined (char_O_END)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3273 : Symbol not previously defined (char_O_flush_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3282 : Symbol not previously defined (char_O_flush_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3325 : Symbol not previously defined (int_O_extra_ascenttime)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3326 : Symbol not previously defined (int_O_extra_ascenttime)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3356 : Symbol not previously defined (char_O_gtissue_no)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3357 : Symbol not previously defined (char_O_gtissue_no)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3379 : Symbol not previously defined (char_O_tissue_N2_saturation)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3421 : Symbol not previously defined (char_O_CNS_fraction)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3430 : Symbol not previously defined (char_O_CNS_fraction)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\PLED_OUTPUTS.ASM 3446 : Symbol not previously defined (char_O_CNS_fraction)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\INTERFACE.ASM 106 : Symbol not previously defined (char_O_hash)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 29 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 38 : Symbol not previously defined (int_I_pres_respiration)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 39 : Symbol not previously defined (int_I_pres_respiration)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 40 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 41 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 103 : Symbol not previously defined (char_I_desaturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 252 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 253 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 279 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 280 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 282 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 284 : Symbol not previously defined (char_I_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 288 : Symbol not previously defined (char_I_saturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 290 : Symbol not previously defined (char_I_desaturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 296 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SURFMODE.ASM 297 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 250 : Symbol not previously defined (char_O_gradient_factor)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 256 : Symbol not previously defined (char_I_deco_model)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 260 : Symbol not previously defined (char_O_relative_gradient_GF)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 286 : Symbol not previously defined (char_I_step_is_1min)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 292 : Symbol not previously defined (char_O_CNS_fraction)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 309 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 311 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 316 : Symbol not previously defined (char_I_deco_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 319 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 321 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 326 : Symbol not previously defined (char_I_deco_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 329 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 331 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 336 : Symbol not previously defined (char_I_deco_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 339 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 341 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 346 : Symbol not previously defined (char_I_deco_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 349 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 351 : Symbol not previously defined (char_I_deco_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 356 : Symbol not previously defined (char_I_deco_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 365 : Symbol not previously defined (char_I_deco_gas_change)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 370 : Symbol not previously defined (char_I_deco_gas_change)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 375 : Symbol not previously defined (char_I_deco_gas_change)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 380 : Symbol not previously defined (char_I_deco_gas_change)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 385 : Symbol not previously defined (char_I_deco_gas_change)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 412 : Symbol not previously defined (char_I_actual_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 414 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 414 : Symbol not previously defined (char_I_actual_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 419 : Symbol not previously defined (char_I_deco_gas_change)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 437 : Symbol not previously defined (char_O_deco_status)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 443 : Symbol not previously defined (char_I_step_is_1min)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 482 : Symbol not previously defined (char_O_deco_status)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 488 : Symbol not previously defined (char_O_first_deco_depth)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 497 : Symbol not previously defined (char_O_nullzeit)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 510 : Symbol not previously defined (char_O_deco_status)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 521 : Symbol not previously defined (char_O_first_deco_depth)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 522 : Symbol not previously defined (char_O_first_deco_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 533 : Symbol not previously defined (char_I_saturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 535 : Symbol not previously defined (char_I_desaturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 537 : Symbol not previously defined (char_I_deco_distance)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 539 : Symbol not previously defined (char_I_depth_last_deco)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 540 : Symbol not previously defined (int_I_divemins)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 541 : Symbol not previously defined (int_I_divemins)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 717 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 726 : Symbol not previously defined (char_O_CNS_fraction)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 734 : Symbol not previously defined (int_O_DBS_bitfield)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 769 : Symbol not previously defined (char_O_gradient_factor)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1053 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1054 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1072 : Symbol not previously defined (int_I_temp)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1073 : Symbol not previously defined (int_I_temp)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1075 : Symbol not previously defined (char_I_temp)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1080 : Symbol not previously defined (int_I_temp)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1081 : Symbol not previously defined (int_I_temp)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1110 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1111 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1114 : Symbol not previously defined (char_I_desaturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1192 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1193 : Symbol not previously defined (int_O_desaturation_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1305 : Symbol not previously defined (char_O_CNS_fraction)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1319 : Symbol not previously defined (char_I_deco_model)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1326 : Symbol not previously defined (char_I_deco_model)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1747 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1748 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1754 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1756 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1786 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1802 : Symbol not previously defined (char_I_current_gas)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1810 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1816 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE.ASM 1822 : Symbol not previously defined (char_I_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 318 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 559 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 563 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 568 : Symbol not previously defined (char_I_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 573 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 575 : Symbol not previously defined (char_I_current_gas)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 627 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 648 : Symbol not previously defined (char_I_const_ppO2)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 658 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 667 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 672 : Symbol not previously defined (char_I_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 676 : Symbol not previously defined (char_I_current_gas)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\DIVEMODE_MENU.ASM 738 : Symbol not previously defined (char_O_deco_status)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SLEEPMODE.ASM 21 : Symbol not previously defined (char_O_hash)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SLEEPMODE.ASM 105 : Symbol not previously defined (char_I_saturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SLEEPMODE.ASM 107 : Symbol not previously defined (char_I_desaturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 78 : Symbol not previously defined (char_I_N2_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 80 : Symbol not previously defined (char_I_He_ratio)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 81 : Symbol not previously defined (char_I_step_is_1min)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 83 : Symbol not previously defined (char_I_saturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 85 : Symbol not previously defined (char_I_desaturation_multiplier)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 87 : Symbol not previously defined (int_I_pres_respiration)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 87 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 88 : Symbol not previously defined (int_I_pres_respiration)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 88 : Symbol not previously defined (int_I_pres_surface)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 271 : Symbol not previously defined (char_I_deco_model)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 274 : Symbol not previously defined (char_I_GF_Low_percentage)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 275 : Symbol not previously defined (char_I_GF_High_percentage)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 302 : Symbol not previously defined (char_I_deco_model)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 305 : Symbol not previously defined (char_I_GF_Low_percentage)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 307 : Symbol not previously defined (char_I_GF_High_percentage)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 315 : Symbol not previously defined (char_I_deco_model)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 318 : Symbol not previously defined (char_I_GF_Low_percentage)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\START.ASM 320 : Symbol not previously defined (char_I_GF_High_percentage)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 34 : Symbol not previously defined (char_I_dive_interval)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 98 : Symbol not previously defined (char_I_dive_interval)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 104 : Symbol not previously defined (char_I_dive_interval)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 167 : Symbol not previously defined (char_I_dive_interval)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 174 : Symbol not previously defined (char_O_deco_status)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 192 : Symbol not previously defined (int_O_ascenttime)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 193 : Symbol not previously defined (int_O_ascenttime)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 209 : Symbol not previously defined (char_O_CNS_fraction)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 274 : Symbol not previously defined (char_I_first_gas)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 286 : Symbol not previously defined (int_O_gas_volumes)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 339 : Symbol not previously defined (char_I_dive_interval)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 355 : Symbol not previously defined (char_I_bottom_depth)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 356 : Symbol not previously defined (char_I_bottom_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 389 : Symbol not previously defined (char_O_deco_status)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 392 : Symbol not previously defined (char_I_step_is_1min)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 414 : Symbol not previously defined (char_I_step_is_1min)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 417 : Symbol not previously defined (char_I_bottom_depth)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 417 : Symbol not previously defined (char_O_deco_last_stop)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 423 : Symbol not previously defined (char_O_deco_last_stop)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 429 : Symbol not previously defined (char_O_deco_status)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 435 : Symbol not previously defined (char_O_CNS_fraction)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 448 : Symbol not previously defined (char_I_bottom_time)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\SIMULATOR.ASM 449 : Symbol not previously defined (char_I_bottom_depth)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\CUSTOMVIEW.ASM 264 : Symbol not previously defined (int_O_extra_ascenttime)
Error[113] OSTC 2N\SOURCES\OSTC2_CODE\CODE_PART1\OSTC_CODE_ASM_PART1\CUSTOMVIEW.ASM 265 : Symbol not previously defined (int_O_extra_ascenttime)
