Deco planning and gas switches
Posted: 23 Jul 2011, 16:33
by Colin Manders
Hi I have just bought an OSTC 2N. Great display. I have searched the forum, I am sure this must have been covered but I cannot find the answer, treat me gently if this is an old question.
The VR3 locks in gasses for the dive and for dive planning so it looks ahead and anticipates one or more switches.The TTS is therefore what is expected.
The OSTC plans on only one gas and does not anticipate any switches. So the TTS is always going to be too long and unhelpful. Yes plan the dive and dive the plan but depth varies and multilevel is supposed to be part of the gain for a computer . I can plan on VR3 and Vplanner but then what is the point of the OSTC?
What have I missed?
Re: Deco planning and gas switches
Posted: 23 Jul 2011, 16:57
by Gucky
Hallo Colin Manders, willkommen im Forum.
Du kannst Dir im Gas Setup (Menue-> Gas Setup) veschiedene Gase eintragen.
Das Bottom Gas kennzeichnest Du als First Gas, die Dekogase werden mit der geplanten Wechseltiefe angegeben.
Aktivierst Du die Dekogase (Aktiv Gas? - Yes) dann wird Dein Plan mit Dekogasen berechnet.
Stellst Du CF55 > 0min. (zusätzliche Zeit für den Gaswechsel) werden die Gaswechsel im Simulator - Dekoplan gelb dargestellt.
Zum Angleichen der Dekopläne an den V-Planner (+2) haben sich GF Faktoren (CF32 / 33) um die 15-20 low und 80-95 hi als tauglich erwiesen.
Ich hoffe das hilft.
by google ...
welcome ..
You are in the gas you can setup (menu-> Setup gas) enter different gases.
The Bottom gas mark you draw as a first gas, the deco gas will be given to the proposed change of depth.
You activate the deco gas (active gas - Yes), then your plan is calculated with deco gas.
Make sure you CF55> 0min. (additional time for gas exchange) in the gas exchange simulator - Dekoplan yellow.
To adapt the Dekopläne to the V-Planner (+2) have GFfactors (CF32 / 33) for the 15-20 low and 80-95 hi proved to be suitable.
I hope that helps.
Posted: 23 Jul 2011, 20:13
by PeterK
As Gucky said, the TTS includes all gases that have been set to "active".
Posted: 23 Jul 2011, 22:57
by Solodiver
AFAIR they also have a change depth set/defined...
HTH,
Jan
Posted: 24 Jul 2011, 09:36
by Colin Manders
Thanks guys both the the advice and speed of reply. I had tried to turn the gas on, my mistake was not resetting the active depth for the gas, too much use of a VR3. It all works just fine now. Happy diving!
Colin
