Having just upgraded my firmware from 1.8 to V2.00, my front screen has a red box in the Top RH of the screen showing alternately, CF56! and CF57!
When I go to the configure screen on Diving Log 5.0, I can only see CF 1 - 31?
How do I fix this?
CF56 &CF57 Message
JeanDo
Re: CF56 &CF57 Message
Directly on the OSTC, go to menu setup 2, and reset CF56 & CF57 to default values.
Hi Yogi,
Its a bug with Diving Log. Read this forum thread at Diving Log.
OSTC 2N V2.0 Custome Functions
There you will find a patch to make CFII visible again in Diving Log.
As for the actual "problem" with CF56 & CF57 follow JD's advice.
Regthing
Yogi
Sure have Scott!;)
On another note, is it possible to delete a dive from the OSTC? I was playing with it on the plane and set the altimeter to ON. When the pressure rose on landing it logged a 2 hour dive at 1.6M until I managed to reset it again on the 2nd flight. (Then said I couldn't fly for 24 hours!)
I know I can delete it from Diving Log 5.0 but it would be better to remove it completely.
Steve
Steve
Jean-François
Sadly you cannot delete only 1 dive. You can reset the whole logbook though.
OSTC Mk2N 2287
