V1.8 to 2.01 problems
Posted: 16 Oct 2011, 15:26
by Lee Hatton
Hi All,
Trying to upgrade from V1.9 to V2.01 using bootloader 1 am and getting the following error:
Could not connect to at 19200
Any ideas ?
(Windows 7 by the way)
Lee
Re: V1.8 to 2.01 problems
Posted: 16 Oct 2011, 18:59
Port not set. Check the Windows-Device manager for the correct COM port number. Enter this number, e.g. "COM3" into the "Comm" field.
Make sure to follow these instructions step-by-step: http://www.heinrichsweikamp.com/read.php?2,4071
Posted: 17 Oct 2011, 17:13
by Lee Hatton
Hi Matthias.
I have Coms 1,2, & 4 available for selection, but all give me a:
Connected to \\.\COM1 at 115200
ERROR!
Any ideas ?
Lee
Posted: 17 Oct 2011, 17:55
Most likely three issues here:
1. You need to find out which port is the right one:
- Unplug OSTC
- Open the device manager, expand COM port section.
- Connect OSTC -> A new port should be visible. THIS port is the right one.
2. Now you have "115200" - which means you're using the v2 bootloader. This will only work if you have 1.90 or later.
3. If you have v1 -> you need to follow the instructions correctly. Most likely you're missing the "Reboot OSTC" section here...
Posted: 17 Oct 2011, 19:59
by Lee Hatton
Again, thanks for your reply.
With bootloader V1 I am getting somewhere in that the process appeared to be working. But I have been stuck on an orange 'please wait' screen with both blue and red blinking LED's for about 15 minutes.
Is it safe to unplug or have I frozen ?
Lee
Posted: 17 Oct 2011, 20:03
by Lee Hatton
Panic over. The 'please wait' lasted about 17 mins.
Matthias, thank you for your help and assistance.
Lee
Posted: 17 Oct 2011, 22:19
The logbook conversion - With the "Please Wait" - always causes some panic ;) Btw., it is safe to disconnect USB when "Bootloader" disappears.
Posted: 18 Oct 2011, 18:37
by Jan_Arild
I will need to opgrade from ver 1.7
From what I understand I need to first upgrade to ver1.8, where is this avelible for download?
Second, I will be able to upgrade directly from ver 1.8 to ver2.01 by using Botloader V2.
Posted: 18 Oct 2011, 18:46
by tiefunten
No, upgrade using Bootloader V2 is only possible from V1.9 upwards. Bootloader V1 should work directly from V1.7 to V2.01.
Posted: 18 Oct 2011, 18:56
Correct, you can go in one step to the 2.01 with the v1 bootloader.
Posted: 18 Oct 2011, 20:12
by Jan_Arild
Great, I will give it a go :-)
Posted: 18 Oct 2011, 20:24
by Jan_Arild
I did the following:
-Installed bootloader V1
-Downloaded HEX file ver 2.01 to lockal directory
-Choose HEX file ver 2.01 in the bootloader file dialog: "Browse"
-Choose COM-Port 3 in the bootloader
-OSTC Mk.2 Reset Menu, choose "Reboot OSTC"
-Pressed "write" at the bootloader
OSTC returned to surface screen within 3 sec. and the following error apared in the Bootloader.
"Connected to \\.\COM3 at 115200
could not understand HEX file
ERROR!"
Please advice :-)
Posted: 18 Oct 2011, 20:45
Are you sure you selected the HEX file - and not the .zip archive?
Posted: 18 Oct 2011, 22:57
by Jan_Arild
Hi Matthias, you are correct.
Now new error
HEX: 0 min old, INHX32,18Fcode+cfg, total=81556 bytes.
ERROR!
Posted: 18 Oct 2011, 23:03
by Jan_Arild
Nope, still no go.. the OSTC screen says
Buliding MD2 harse
Please wait....
Then black screen and orange led blinking only
Posted: 19 Oct 2011, 08:34
> Buliding MD2 harse
> Please wait....
-> Normal after every reboot - no matter if a new firmware was installed or not.
-> Normal sleep mode (Charging)
The "115200" indicates your using the v2 bootloader. You need the v1 (Screenshot attached)!
Posted: 20 Oct 2011, 23:09
by Jan_Arild
Hi Matthias
From what I'm understand I use Bootloader V1.9.5
But when checking PIC I got error, see attach
Posted: 20 Oct 2011, 23:31
by Jan_Arild
When checking my PC for correct com, OSTC is com9, in the Bootloader I can only choose form com1-4.
Is there a way around this?
