Time setting changed during FW update?
PeterK
Post by PeterK »
I've updated my unit to the latest FW recently. Yesterday I've notice that the clock was about 14 hours behind the true time.
It's quite some time ago that I last checked the time on my unit but was pretty much OK by that time. I was surpriced that the setting was that much wrong. I have no idea if this is in some way correlated to the FW update. Has any one of you noticed anything similar?
Peter
OSTC 2N #2338
JeanDo
Re: Time setting changed during FW update?
Post by JeanDo »
Hi Peter,
I might well be:
* What version did you upgrade from/to ?
* What is the CF48 value ?
PeterK
Post by PeterK »
Hi JeanDo,
I've upgraded from 2.00 to 2.01. Default is used for CF48. Any ideas on that?
Peter
OSTC 2N #2338
Iglooz
Post by Iglooz »
As far as I have observed, the time is reset to 0, each time I upgrade to a new firmware ...
Have you upgraded your OSTC around 14h just after your nap ??? ;)
OSTC 2N #2755
Hi all,
The clock is completely made out of software. Sorry, but the time must be set again after the bootloader/reboot process.
PeterK
Post by PeterK »
Thanks for the clarification Matthias. Now that I know it's not a problem. I just have to keep it in mind.
Peter
OSTC 2N #2338
knl
Post by knl »
BTW clock, how can I switch between the european and american data standard:
American: mmddyy
European: ddmmyy
thx Lukas
Post by Bardass »
did you read user manual ?
setup menu 2 page 25
