Can not change color on the battery indicator
Posted: 25 Jan 2012, 15:05
by TBS
Hello H.W
Why can“t I change the color of the battery indicator.
I use CF34 to change color, but it is just standing on the yellow.
Thank you
OSTC 2N #3564
Re: Can not change color on the battery indicator
Posted: 25 Jan 2012, 15:15
by scubatinoo
Is your OSTC still pluged to the USB of your computer? Just unplug it...
Posted: 25 Jan 2012, 15:18
by Bardass
Yellow is the color when OSTC is pluged with usb
Posted: 25 Jan 2012, 15:38
by swissdiving
I suspect the reason for this is, that you can only change the color for the full charge and if the battery is discharging it turns yellow.
So charge you OSTC until its full, then you'll see if the colour changes. How do you update the CF's?
Posted: 25 Jan 2012, 16:46
by TBS
Thanks for your help ..
Have solved the problem, I had it set to the usb ....
swissdiving I use OSTC planner to update my CF ...
O==II=====> OSTC 2N 3564 <=====II==O
