can't seem to connect my 2N, only port COM3 is in the list, searching does not help.
Next message if I check connection.
Could not connect to com3 at 115200
ERROR!
2n was switched on.
Thx for information.
Ilja 2N 2564
connecting 2n to bootloader
Re: connecting 2n to bootloader
Have u had a look at this post?
http://www.heinrichsweikamp.com/read.php?2,6723,6803#msg-6803
ibiets
Hi Hansjoerg,
Thanks for the post, but it does not help.
Now i get following message:
Could not connect to com3 at 19200
ERROR!
So it isn't fixed yet.
Someone another idea?
Greetings,
Ilja
ERROR!
Greetings,
Ilja
Check our step-by-step instructions: http://www.heinrichsweikamp.com/read.php?2,4071
Most likely you did not reset the unit before clicking check: "- In the OSTC Mk.2 Reset Menu, choose "Reboot OSTC" and confirm"
ibiets
problem solved !!
@ Matthias, I have the 2N.
I contacted a friend who deals a lot with computers and he helped me making the connection between pc and 2N.
Once the connection was established no problem installing the new firmware.
Thans everyone.
problem solved !!
Thans everyone.
