new firmware v2.20 cf#43
Posted: 29 Jan 2012, 08:48
by fortunato lodari
Hi!
The cf#43 calculation it's not correct, it's evaluated with 1000 units minus.
IE: if I set 5000 the colour must change at 40mt, but it change colour at 50mt
[fox]
ostc 2n
#3733
Re: new firmware v2.20 cf#43
Posted: 29 Jan 2012, 17:33
by TBS
Hi fortunato lodari..
CF43:Depth warning (Color change)
Depth reading is color coded when diving deeper then this value.
1) Recommend range: 2000 ... 13000 (20m ... 120m)
2) Default setting: 12000mBar (120m)
3) Example: CF43=2000 (10m) - When diving in more 10m the Depth reading will be colored with Color# Warnings (Default: Red)
here is a bug.
1) Here is 2000 = 20m, so this must be 5000 = 50m:)
2) And here is 12000mBar = 120m:)
3) But here is 2000 = 10m, so here it must be 5000 = 40m:(
I think if you change it to 4000, colour change at 40m;)
Mojn
O==II=====> OSTC 2N 3564 <=====II==O
Posted: 30 Jan 2012, 06:26
by foxlox
> 40m;)
TBS, it's clear that if I change to 4000 the colour will change at 40m, but I'm signalling a discordance (that should generate an error associated with other values) between the description (2000=10m) and the effective work (2000=20m). The right value should be 2000mbar=10m perhaps?
[fox]
ostc 2n
#3733
Posted: 30 Jan 2012, 08:28
The documentation is wrong here, it's the relative pressure:
For a warning of 20m, you need to set it to 2000mbar.
We'll update the documentation, of course.
Posted: 30 Jan 2012, 15:05
by foxlox
thx a lot Matthias.
[fox]
ostc 2n
#3733
