Page 1 of 2
OSTC Tools - Beta testers wanted.
Posted: 29 Mar 2012, 21:59
by Rob
Hi there,
@heinrichsweikamp, if this post is not allowed here, delete it.
I have developed three programs for the OSTC.
OSTC Dump
OSTC Config
OSTC Profile
Here is a short description of the Programs:
OSTC Dump
Dumps all the availible data out of the OSTC and saves them into binary files as backup.
OSTC Config
-Read the OSTC configuration
-Save the configuration data in Settings Files
-Import and export binary files.
-Change nearly every setting.
-Write the changed data to the OSTC
-Synchronize date and time with your PC
-Set date and time to any other value
-Export dive profile data (the Logbook) into separate dive files.
-List settings and custom functions
-List settings and custom functions technical (the data were shown normally and as number, hex
and binary)
-Compare two Settings Files (settings and custom functions) value by value.
-Differ two Settings Files (settings and custom functions) only differences are shown.
-Create a dump of the binary data.
-Compare the dump of two files.
-Differ the dump of two files
OSTC Profile
Shows one dive of the logbook.
If you like to betatest the software here is the downloadlink.
http://www.angermayr.net/download/ostctools-beta3.zip
There is a PDF with more detailed information about the programs and the installation included.
Please send any bug report to the emailadress shown in the aboutboxes of the programs.
If you have any question, send me a email.
best regards
Re: OSTC Tools - Beta testers wanted.
Posted: 29 Mar 2012, 22:49
by Solodiver
if there would be a chance to get the source or a release for a proper operating system I'd be happy to test it...
Posted: 31 Mar 2012, 19:28
by Dahab Boris
Nice one Rob, I'm taking a look..
edit.. Seem to work. The clock set reset the clock to zero and then reset it to the correct time..
Posted: 12 Apr 2012, 00:14
by Iglooz
Really nice job !!
It works fine for me (2n with Win7).
Iglooz
Posted: 12 Apr 2012, 00:48
by Rob
Thanks Iglooz,
the next Beta Version is availible Beta 4
Your can find the software here: http://www.angermayr.net/download/ostctools.htm
The OSTCTools are in English but the Website is in German ... sorry for that.
Currently im working on the german translation of the OSTC Tools.
The german Custom Functions are included in the Beta4.
The cfconfig files ar textfiles, you can edit them with a normal editor and translate the CF descrioptions.
die nächste Beta Version ist fertig, Beta 4
Ihr könnt sie hier: http://www.angermayr.net/download/ostctools.htm downloaden
Momentan arbeite ich an de deutschen Übersetzung der OSTC Tools.
Die deutschen Custom Functions liegen der Beta4 als Zip File bei.
Die cfconfig Dateien sind normale Textdateien, sie können mit einem Texteditor (Notepad, usw) bearbeitet und die CF Beschreibungen übersetzt werden.
Grüße
Posted: 15 Apr 2012, 21:47
by Howdy
When I start OSTCDump I get the following error: "Error reading dlgRegister.Caption:Division by zero."
Choices are "OK" to continue with risk of data loss - program crashes.
Or "Cancel" close program.
Im on a Windows 7 computer.
Thanks!
//N
Posted: 16 Apr 2012, 21:45
by scubatinoo
Hallo Robert
Habe die Beta4 heruntergeladen. Ist ein Stück interessantes Software, dass du da zur Verfügung stellst! Vielen Dank schonmal dafür.
Der Workflow ist noch etwas "technisch" und somit gewöhnungsbedürftig. Sehr gut hingegen gefällt mir aber der Profile-Reader! Allerdings kommt hier ein Problem mit der Logbuchnummer zum vorschein... Der erste Tauchgang meines OSTC trägt die Nummer 65525 (!!!), der zweite 65526 und so weiter. Seit dem letzten Tauchgang am vergangenen Samstag ist die Dive Nr. aber plötzlich 0000
Zumindest erstellen deine Programme diese Informationen, wenn ich den Dump auslese und die Profile extrahiere...
Aber wie schon gesagt: Der Profil-Reader gefällt mir gut. Ich finde, ihr Cracks solltet eure Intelligenz bündeln und zusammen an der ultimative OSTC-Anwendung arbeiten
Posted: 17 Apr 2012, 06:38
by Rob
Hallo Scubatinoo,
maile mir bitte die drei Dump Dateien zu, die diese Tauchgangsnummern erzeugen, ich kann das mit meinem OSTC nicht nachvollziehen.
Grüße
Posted: 17 Apr 2012, 10:11
by scubatinoo
Hoi Rob
Mach ich gerne. Hab die Files auf meinem Mac (virtualbox) zuhause. Kannst mir kurz durchgeben, wo ich nach was suchen muss, damit ich die richtigen Files maile?
Posted: 17 Apr 2012, 10:20
by Rob
Hi Scubatinoo,
einfach OSTCDump ausführen und die Daten vom TC laden.
Dann bitte alle drei Files mir zumailen.
die Dateinamen und das Verzeichnis werden in OSTCDump angzeigt (normalerweise (Eigene Dateien/OSTCTools/Binaries)
Ich brauche ein komplettes Set (dateiname.bb0 dateiname.bb1 dateiname.bsp)
Grüße
Posted: 20 Apr 2012, 08:12
by scubatinoo
Hoi Rob
Hast die Daten bekommen und konnest schon 'reinschauen?
Posted: 20 Apr 2012, 08:13
by scubatinoo
Hoi Rob
Hast Du meine Daten bekommen und konnest schon 'reinschauen? Nimmt mich wunder, was es mit der Nummerierung auf sich hat...
Posted: 20 Apr 2012, 09:05
by Rob
Hi scubatinoo,
ja, Daten bekommen und Fehler gefunden.
Kannst du mal nachsehen ob CF28 Bei dir tatsächlich so eingestellt ist?
CF28 Logbuch offset für Anzeige der tatsächlichen Tauchgangsnummer
Default
Value: 32768
Actual
Value: 0
Mit Aktuellem Wert = 0 müsste eigentlich, wenn der Logbuchspeicher, sagen wir mal mit 30 Tauchgängen voll ist immer die TG Nummer 1 - 30 erscheinen, niemals eine höhere TG Nummer. Also max TG Nummer ist Max Anzahl der TG im Logbuch.
Ist das bei dir so gewollt?
Die nächste Beta wird bald fertig sein ... Anfang Nächste Woche.
(Es sind jetzt doch ein paar "unschönheiten" gefunden worden.)
Grüße
Posted: 20 Apr 2012, 10:26
by scubatinoo
Interessant... Ich weiss ich hab mit dem CF28 herumgespielt, weil ich der Meinung bin dass mein OSTC die Tauchgänge im Logbuch falsch nummeriert. Ich bin mir aber sicher, danach CF28 wieder auf 0 (null) gesetzt zu haben... Der Compi liegt aktuell zuhause - schaue heute Abend aber nochmals nach.
Posted: 20 Apr 2012, 10:37
by Rob
Steht ja auch auf 0, Aktueller Wert = 0
der Defaultwert steht auf 32768 (einmal zu viel reduziert
Meiner Ansicht nach ist 0 so ziemlich der schlechteste Wert, den man einstellen kann.
Denn die Maximal mögliche Tauchgangsnummer ist dann immer die Anzahl der TG im Profilspeicher.
Wenn du 25 TG im Profilspeicher hast, solltest du den wert auf 25 Stellen.
siehe Beschreibung der CF.
Grüße
Posted: 20 Apr 2012, 11:44
by scubatinoo
CF28 hat keinen Einfluss auf die Logbuch-Übersichtseite, sondern nur auf die Tauchgangsnummer in den Tauchgangs-Detailseiten. So wie ich das verstanden habe, kann man mit dem Offset die Tauchgangsnummer personalisieren: Wenn ich also insgesamt 702 Tauchgänge habe, kann ich erwirken dass der erste TG mit dem OSTC die Nummer 703 bekommt. Da ich aber mein Logbuch noch von Hand auf Papier führe, ist das für mich nicht so wichtig. Darum bleibt CF28 auf Null. Vielleicht kann ich dann mal irgendwann in ein paar Jahren ablesen, wieviel TG's ich mit dem OSTC gemacht habe...
Posted: 20 Apr 2012, 13:22
by swissdiving
Es ist genau so wie es tinoo beschreibt.
Posted: 20 Apr 2012, 14:24
by Iglooz
Same way to use my OSTC and same problem with OSTC Profile ....
Iglooz
PS : French translation update of CF still under work, I'm progressing ...
Posted: 20 Apr 2012, 18:29
CF28 quite easy to use: Just enter your current amount of dives here. CF28 then will be updated every dive and the correct number is shown in the logbook detail view for each dive.
Posted: 22 Apr 2012, 15:12
by scubatinoo
@Rob: Bei mir des definitiv 0 als Default und 0 als Active eingestellt. Keine Ahnung woher der Default-Wert kommt...
Posted: 22 Apr 2012, 15:38
by swissdiving
Default 0 heisst das es keine offset gibt. Das heisst der neuste Tauchgang ist immer der Tauchgang nummeriert als "1" in der Tauchgangliste und in den Details zum Tauchgang. So wie es tinoo schon gesagt hat.
Die Anzahl der Tauchgänge registriert im OSTC müssen ja auch nicht zwingend mit den Tauchgängen im Papierlogbuch übereinstimmen.
Wenn ich einen Tauchgang beginnen und ihn nach 1 Minute und 2m Tiefe abbreche nehme ich diesen sicher nicht im Papier Log auf. Der OSTC hat nichts desto trotz einen Tauchgang registriert. In einem solchen Falle muss dann eben CF28 angepasst werden damit es mit den Tauchgängen im Papier Logbuch übereinstimmt.
Posted: 22 Apr 2012, 21:28
by scubatinoo
Was aber komplett falsch ist. Denn der fünfte Tauchgang soll
zwar in der Übersicht-Seite die Nummer 1 haben (damit er zuoberst
dargestellt wird), in der Detailseite sollte er aber schon die
Nummer 5 haben! Schliesslich ist es der fünfte TG... Und das ist
meiner Meinung nach in der neusten Firmware falsch...
Posted: 22 Apr 2012, 22:31
by swissdiving
Ob es so falsch oder richtig ist, ist ansichtssache. Für die leute die ein papier lgobuch führen schlussendlich irrelevant, bestennfalls ein kosmetisches ärgerniss.
Posted: 22 Apr 2012, 22:40
by scubatinoo
Für die Leute, die wissen wollen wieviele Tauchgänge sie mit dem OSTC gemacht haben oder machen, finde ich die Info schon noch nützlich. Ansonsten wäre so eine Art "Statistik"-Seite cool, wo Anzahl TG, max Tiefe und Gesamt-TG-Zeit angezeigt wird.
Posted: 23 Apr 2012, 07:30
by Rob
Wenn man wissen will wie viele Tauchgänge sie mit dem OSTC gemacht haben schaut man auf Byte 3-4 in EEPROM Bank 0, dort steht die Anzahl der mit diesem OSTC gemachten Tauchgänge. Zu sehen in OSTC Config auf dem Info Tab rechts oben "Total dives".
Alternativ und auch ohne Hilfsmittel auslesbar, CF28 auf die Anzahl der gemachten TG stellen, dann kann man in CF28 die Anzahl der TG mit dem OSTC sehen.
Grüße
EDIT: - again in english
If you like to know how many dives your ostc did, look at byte 3-4 in EEProm Bank0, the number of dives is saved here. You can visualize the value in OSTC Config Info Tab top right "Total dives".
As an alternative and readable without a tool set CF28 to the number of dives made with the ostc. By reading CF28 you can see the number of dives with this ostc.
regards
