Bug? - StopWatch - disappears during dive (fw 2.21).
Posted: 01 Jul 2012, 19:34
by Rob
today i did a dive 66m TX18/46 + TX48/10 + 100% O2
At 21m I resettes the stop watch, and it starts vith 0:00 Ok
at 12m too (stopwatch reset 0:00)
at 9m i wanted to reset the stopwatch again but i did a mistake and switched from the TX48/10 (i changed to this gas at 21m) bsck to the 18/46 i corrected my mistake immediately and switched to the TX48/10 after that i openes the menu and the entry for the stopwatch was gone. During the rest of the dive the menu didn't show the menu entry for the stopwatch, and the stopwatch and average depth in the display was gone.
Now i got the date from the ostc and CF51 is still at 1 = "Show Stopwatch".
Parameter list after the dive
Serial : 2207
Total Dives : 44
Gas 1 : actual TX18/46 default Air change depth 0 inactive First gas
Gas 2 : actual TX48/10 default Air change depth 21 inactive
Gas 3 : actual Oxygen default Air change depth 6 active
Gas 4 : actual Air default Air change depth 0 active
Gas 5 : actual Air default Air change depth 0 active
Gas 6 : actual TX48/10
First gas : 1
Salinity : 1,00
Deco Type : 4
Use O2 Sensor Module in CC Mode : 0
Setpoint 1 : 0,80
Setpoint 2 : 1,00
Setpoint 3 : 1,20
DebugMode : off
Current Batterie Voltage [mV] : 0
Lowest Batterie Voltage [mV] : 4010
Lowest Batterie Voltage [V] : 4,010
Lowest Batterie Voltage Date : 31.05.2012
Lowest Batterie Voltage Temperature: 147
Last complete charge : 01.06.2012
Total charge cycles : 5
Total complete charge cycles : 3
Temperature extrema Minimum : -74
Temperature extrema Minimum Date : 04.06.2012
Temperature extrema Maximum : 289
Temperature extrema Maximum Date : 27.04.2012
CustomText active : yes
CustomText : Robert Angermayr
Dim OLED in divemode : no
Standard dateformat : DDMMYY
Number of CF in firmware : 64
Firmwareversion Bank 1 : 221
Custom Functions
CF00 Actual 100 Tauchtiefe für automatischen Tauchmodus Start
CF01 Actual 30 Tauchtiefe für Tauchmodus Ende
CF02 Actual 240 Verzögerung für Tauchmodus Ende
CF03 Actual 120 Haltezeit für Menüs und Oberflächenmodus
CF04 Actual 5 Haltezeit für Menüvorstufe
CF05 Actual 7 Schwelle für Anzeige der Vertikalgeschwindigkeit
CF06 Actual 1160 Absolutdruck zum Einschalten aus dem Sleepmode
CF07 Actual 1080 Max. "erlaubter" Luftdruck für Luftdruckkompensation im Sleepmode
CF08 Actual 20 Schwellwert für Anzeige des Gradienten Faktors
CF09 Actual 20 Schwellwert (O2-Gehalt) für Anzeige des aktuellen Gases im Tauchmodus
CF10 Actual 45 Haltezeit für Menüs im Tauchmodus
CF11 Actual 110 Faktor für Sättigungsvorgänge
CF12 Actual 90 Faktor für Entsättigungsvorgänge
CF13 Actual 60 Verhältnis für Flugverbotszeit in Abhängigkeit der Entsättigungszeit
CF14 Actual 100 Schwelle für optischen Alarm des Gradienten Faktors
CF15 Actual 10 Schwellwert zur Anzeige der CNS Belastung im Oberflächenmodus
CF16 Actual 10 Voraussichtlicher Abstand zum Dekostop
CF17 Actual 19 Untere Schwelle für ppO2 Warnung
CF18 Actual 160 Obere Schwelle für ppO2 Warnung
CF19 Actual 140 Obere Schwelle für Anzeige des ppO2
CF20 Actual 10 Abtastrate für Tiefenspeicherung
CF21 Actual 6 Divisor für Temperaturspeicherung
CF22 Actual 6 Divisor für Dekodatenspeicherung
CF23 Actual 6 Divisor für Gradienten Faktoren
CF24 Actual 0 Divisor für Speicherung des ppO2
CF25 Actual 0 Divisor für zusätzliche Debugdaten für Entwickler
CF26 Actual 12 Divisor für Speicherung des CNS
CF27 Actual 20 Schwelle für Anzeige des CNS Wertes
CF28 Actual 814 Logbuch Offset für Anzeige der tatsächlichen Tauchgangsnummer
CF29 Actual 3 Tiefe des letzten Dekostops
CF30 Actual 10 Delay für Apnoe-Modus Ende
CF31 Actual 0 Anzeige von Batteriesymbol oder Spannung
CF32 Actual 20 GF low (Unterer Gradient für GF Erweiterung)
CF33 Actual 70 GF high (Oberer Gradient für GF Erweiterung)
CF34 Actual 199 Farbe Batterie
CF35 Actual 255 Farbe Standard
CF36 Actual 62 Farbe Maske
CF37 Actual 224 Farbe Warnanzeigen
CF38 Actual 0 Anzeige der Tauchzeit mit Sekunden
CF39 Actual 0 Festen SetPoint ändern
CF40 Actual 1 Warnung Ceiling
CF41 Actual 1 Gasmix Symbole
CF42 Actual 1 Besseres Gas anzeigen
CF43 Actual 13000 Tiefenalarm
CF44 Actual 101 CNS Warnung
CF45 Actual 101 GF Warnung
CF46 Actual 161 ppO2 Warning
CF47 Actual 15 Auf- Abstiegsgeschwindigkeitswarnung
CF48 Actual 0 Zeitversatz pro Tag
CF49 Actual 0 Höhenmesser anzeigen
CF50 Actual 0 Zeige Logbuchmarker
CF51 Actual 1 Stoppuhr anzeigen
CF52 Actual 0 Gewebegraph anzeigen
CF53 Actual 0 Leitgewebe anzeigen
CF54 Actual 0 Flachster Stop oben
CF55 Actual 0 Gaswechselzeit
CF56 Actual 20 Gasverbrauch Bottom Gas
CF57 Actual 20 Gasverbrauch Deko bzw. Aufstiegs Gas
CF58 Actual 0 Zukünftige Zeit bis zur Oberfläche
CF59 Actual 0 Cave Warning
CF60 Actual 0 Grafische Anzeige der Auftiegsgeschwindigkeit
CF61 Actual 0 Zeige pSCR ppO2
CF62 Actual 4 pSCR O2 Drop
CF63 Actual 10 pSCR Gegenlungenverhältnis
Done
Re: Bug? - StopWatch - disappears during dive (fw 2.21).
Posted: 01 Jul 2012, 19:42
by Vortax
Just a question: did you tried pressing the right button in the dive screen several times until the stopwatch appeared again?
Right button during dive mode changes function between stopwatch, tissue saturation, END, etc etc. you can only reset stopwatch when the stopwatch is currently displayed on the screen. Otherwise, the option to reset it desapears.
Posted: 01 Jul 2012, 20:25
by Rob
Hi Vortax,
hmmm, i think so, but now i'm uncertain.
I think ive tried this but i didn't manage to get the stopwatch again.
In Simulator it works.
I will try this again with my next dive.
