Cannot download dives from OSTC
Posted: 11 Jul 2012, 21:17
by Jan_Arild
I'm using JDiveLog 2.16 to download from OSTC firmware 2.01.
Connection to the divecomputer works and I'm also able to do setup. When trying to download dives, latest 18 dives do not show in the PC import window, only previus dives which is already imported show.
Ideas anyone?
Re: Cannot download dives from OSTC
Posted: 17 Jul 2012, 23:14
Are the date and time settings correct? Maybe Jdivelog ignores dives with were made in the fuuture.
Posted: 19 Jul 2012, 20:55
by Jan_Arild
Checked date and time on the computer and on the dives who will not import, all looks good.
Last dive which uploads to the PC is made 12. feb 2012, the next dive later same day and on will not upload.
Posted: 19 Jul 2012, 22:16
by scubatinoo
If you are using JDiveLog: Do you press the "recycling"-look-like green button for synchronizing the dives? If i do that, a new windows will pop-up, from where i can choose which dives to import...
Posted: 24 Jul 2012, 11:18
by Jan_Arild
Hi scubatinoo.
This is exactly what I do, but dives made after 12. feb 2012 will not show in the new window. Even if I can se them directly at the OSTC.
Posted: 24 Jul 2012, 11:37
What is your setting at "Settings -> Divecomputer"? Maybe the dives with a newer firmware version are not imported?
Posted: 25 Jul 2012, 12:13
by Jan_Arild
You may have a point.
"Settings -> Divecomputer" is protocol version OSTC Mk2 1.50-1.70. Divecomputer is upgraded to 1.90 i think, will check this tonight.
By the way, after upgrade to 1.90? I really miss the ability to be able to reset the stopwach without the need of going into the menu.
Posted: 25 Jul 2012, 12:26
I'd really recommend to upgrade to 2.21. Then you can reset the stopwatch with a shortcut:
When the stopwatch is shown, press left -> right -> right to reset it.
Posted: 25 Jul 2012, 13:12
by PeJo
> Regards,
I guess that shortcut isn't included in Simulator mode? (or has it been removed in 2.28beta?)
/Petter
Posted: 25 Jul 2012, 13:16
Sorry, it's "left-left-right" (And yes, this works in Simulator, too).
Posted: 25 Jul 2012, 13:28
by PeJo
> in Simulator, too).
> Regards,
With the right keystrokes it works, thanks!
/Petter
Posted: 27 Jul 2012, 14:49
by Jan_Arild
Solved
My comuter FTI driver was lost some while back.
Reinstalled, then COM 9 was avelible by USB again, the V2.01 became avelible in Settings -> Divecomputer, and download was sucessful.
Also madae an up grade V2.21 all good :-)
Thanks Matthias.
