hi
i received my unit from a german dealer.
the firmware is 1.22 and serial 12-188
i have 2 questions.
i cannot find the simulator function in the "MORE" section.
there is a blank space instead of "simulator".
also given the serial n?, do i have anu reason to get involved with the buttons problem that happened a while ago?
thanks for your assistance.
robert
simulation
Re: simulation
> section.
It's normal.
The simulator appears in the unstable FW 1.23
http://www.heinrichsweikamp.com/read.php?2,751
Servan
> section.
It's normal.
Servan
Re: simulation
Hello Robert.
Update to 1.28 and you'll find this entry.
http://www.heinrichsweikamp.net/ostc/en ... CCDB62.htm
divingcool
Re: simulation
hi
thanks, for your posts.
i wish i could do the update, as eventhough i downloaded the necessary softwares, respecting the procedure, i cant get it done.
i get an error message.
fyi, i also downloaded jdivelog, as some users successfuly updated the firmware but in the settings, no com port appear.
i have no idea.
i have no idea.
Re: simulation
Check the wiki: http://www.heinrichsweikamp.net/ostc/pm ... .Interface There is step by step manual.
It's essential that the update works, seems that you did not install the driver already. If possible, please try to give more detailed informations about your system/error messages.
divingcool
Re: simulation
hi Matthias
Yessssssssss!..., i succeed, a little tricky anyway but it finally worked fine. found the port, checked the pic
and done.
thanks.
i will not bother you anylonger until you answer these questions below.
1- serial 12-188 is this serial fine, meaning that i will not have the, let say tough to press buttons, that has been solved.
2- maybe and probably this question has already been adressed, but is there any project having a kind of wrist support with bungees, like the deep sea supply one.
thanks a lot
robert
and done.
thanks.
thanks a lot
robert
Re: simulation
Hello Robert,
"12-xxx" is one of the latest batch, it's fine.
Yes, there are several projects we're in contact with. As soon as any is ready we'll publish is here. We are also thinking of an alternative right now.
divingcool
Re: simulation
hi Matthias
thanks for your assistance and answering my silly questions.
take care
kind regards
robert
take care
kind regards
robert
divingcool
Re: simulation
> "MORE"
> > section.
> It's normal.
> 51
> Regards
> Servan
thanks for your advices, update finally went fine.
simulator works.
take care
> "MORE"
> > section.
> It's normal.
> 51
> Regards
> Servan
simulator works.
take care
