Hi, after updating to 2.21 it has changed the dates of all my dives in the computer. My last dives are all now between 2007 and 2001.
The same issue has happened on both mine and my wife's OSTCs.
Annoyingly there's a lot of dives from our cave trip which is on there which I want to back up, but don't want to have to manually change all the dive dates.
Is there a known fix for this or a way to change the dates in bulk?
Upgrade to 2.21 screwed up dates of dives
Re: Upgrade to 2.21 screwed up dates of dives
Hi
Did you change date and time settings after update?
I never had this kind of problem. But i do first(!) backup and then second(!) any changes on the firmware. And i do not care about my logbook because it is a rolling memory, so sooner or later all your dives will fall out of the memory...
