Could somebody please give me a link to the newest firmware file for the 2N?
Cant seem to find it, getting confused... ;-/
I´m using a Mac computer!
Thanks!
Newest firmware for 2N?
Re: Newest firmware for 2N?
maybe here
http://www.heinrichsweikamp.com/#/en/ostc_2n/firmware/
search on the bottom page, file mk2_vXXX.zip
same for PC or MAC
same for PC or MAC
If you actually have a closer look at the OSTC Forum the 3rd. Sticky from the top says:
"Sticky:New firmware 2.50 available for the Mk.2/2N"
Pretty much everything you need to know about the new firmware you will find there. Granted, it does not point you directly to the download location of the FW / Bootloader location. But if you do look at the website there is a menu item on the right that say "Firmware". The chances are very high that you'll find the firmware for the OSTC there!
Make sure you make yourself familiar with the instructions and read the forum before you start updating your OSTC. It can sometimes get a bit tricky, though I did not have any problems at all.
Also, just in case you haven't done it yet, you do have to install the relevant com port drivers before you can connect your OSTC to do the update.
Mac users quite often have some problems to get the connection working. Make sure you search the forum for the relevant information.
If you, after searching the forum still get stuck, most forum users will be more than happy to help.
Well, sorry for the trouble. I´m not a "computer-junkie" I just like diving
"Bardass" Thanks!!
"Bardass" Thanks!!
Actually I just realised that the HW website is very thin on information on how to update the FW of the OSTC on a Mac. Is there somewhere a description for this?:S
5 minutes later:
Ohh hurray I found it! Its here:
http://forum.heinrichsweikamp.com/read.php?2,4071
5 minutes later:
