Deep Stop
Abyss79
Deep Stop
Post by Abyss79 »
Hi everybody
thanks for the new firmaware there was sime nice add on.
Safety stop, graphic ascent ratio
Do you think will be a good idea to add a system for calculating deep stop (Pyle stop or similar).
I will appreciate them. Think about it!
Christian
Christian [OSTC 3737]
SSAV Luino(VA) - Italy
www.ssav.it
Re: Deep Stop
Post by Bardass »
What do you think of GF ...
Re: Deep Stop
As Bardass says check out GF.
Abyss79
Re: Deep Stop
Post by Abyss79 »
OK GF show me the % in case it will became grater then a certain value.
Deep stoop is a bit differente.
If the ascent between max depth and first deco stop is more than 10 meters you should stop for a couple of minute and so on until the distance between actual depth and safaty stop is less the 10 meters.
You can't do this with GF, or i'm missing something?
www.ssav.it
Re: Deep Stop
Correct but Bühlmann does only allow an approximation of deepstops through GF.
Re: Deep Stop
Post by Bardass »
> 10 meters.
> something?
> Thanks
why did you bought an ostc then ?
Re: Deep Stop
@Bardass
I am assuming you're adressing Abyss...
Re: Deep Stop
Post by Bardass »
swissdiving Wrote:
> @Bardass
no ;)
Abyss79
Re: Deep Stop
Post by Abyss79 »
I'm using Aladin computer and buhlmann table since I start diving, and I'm happy with it.
Deep stop is not something against buhlmann, but just a way to control the size of boulbe during ascending.
I will do deep stop also if computer doesn't say to do it.So why not include them as an option.
About me could be nice feature to have. But I can survive also without it.
www.ssav.it
Re: Deep Stop
@Bardass
I am not that fussed about deep stops. I do deep stops anyways. Besides I love the OSTC as it is.
@Abyss
Its not about whether to include deeps stops or not. Its about the Bühlmann algorithm which does not encompass them.
A different algorithm would have to be implemented (rgbm or if I am not mistaken VPM). HW has no intention of implementing those algorithms.
wrobell
Re: Deep Stop
Post by wrobell »
> ascending.
Please read the following
http://liquivision.com/docs/deepstops.pdf
http://www.ddplan.com/usage.htm
In short: gradient factors are better version of deep stops.
w
Abyss79
Re: Deep Stop
Post by Abyss79 »
I read the articles,
so the best is to decrase the high GF.
What you use as GF low and hight?
Now I'm using 30% and 90%
I make same test and from a dive at 50m for 15 minutes deco start at 15m
If I put HGF to 75 it became 18m
Also in this way from 50m to 18m there is a lot of space and personally I prefer to stop between 30 and 35m for safaty.
www.ssav.it
Re: Deep Stop
@Abyss
Read this to understand more about GF:
Clearing Up The Confusion About "Deep Stops"
Re: Deep Stop
Hi Abyss,
for a deep stop try GF 5/80 or 10/80 ( alternativly 5/90 or 10/90 ).
The first GF value controls the deeper stops, the second value controls the shallow stops.
The smaller the first value the deeper the first stop.
The smaller the second value the longer the shallow stops.
Make sure to read and understand GF values with the already provided links.
Make sure to dive these values only after completly understanding them.
Diving the OSTC without understanding the customized GF values might be dangerous.
wrobell
Re: Deep Stop
Post by wrobell »
> and 35m for safaty.
YMMV, but if I understood the Baker's paper well (the PDF file linked
above), the 30m-35m deco stop is not giving you more safety - it might
be problematic on shallower stops - this is explained in the text of
the paper (page 3) with appropriate graph (Figure 2).
As others explained, lower GF Low value to have deeper stops.
Fortunately, OSTC has nice simulator builtin (well... two of them:)),
so I would encourage you to try at home. :)
w
wrobell
Re: Deep Stop
Post by wrobell »
the following article provides some insight about deeper stops as well http://hhssoftware.com/v-planner/decomyths.html
