Marker
Abyss79
Marker
Post by Abyss79 »
I have a question about Marker option.
Why in dive mode the marker came out in Menu only when is shown in main screen?
To set a Marker I have to select it with Enter button and after open the menu and select Marker again...
Is it correct? There is not any fast way?
Christian [OSTC 3737]
SSAV Luino(VA) - Italy
www.ssav.it
DTR.Diver66
Re: Marker
Post by DTR.Diver66 »
Hello Abyss79,
yes it is correct. How often do you use this feature?
Re: Marker
Most of the functions in the "custom view" area (e.g. the marker) can be accessed using the following shortcut:
left - left - right
Re: Marker
Actually I think the problem is that if you choose to set a marker. When you set it you return to the menu point marker, which can be confusing as it may leave the impression that the marker was not set.
It would be neat if we could have a message that says
"Marker set"
Abyss79
Re: Marker
Post by Abyss79 »
Now I understand....
I try in simulator, and I didn't get any massage, that why I was confused.
I will try in real dive.
www.ssav.it
Re: Marker
There's no message. I think a short confirmation can be included in one of the next betas.
Re: Marker
That would be very cool. Thanks Matthias.
