i did it before but i can't figure out how to do it anymore.
How can you write or edit a note ( e.g. your name ) in the bottom row on the surface display.
I know i did it with the interface but i can't find the option anymore.
Thanks, Reiner
custom note in bottom line
Re: custom note in bottom line
It's called custom text in the "Divinglog Downloader" or with Jdivelog ("Read OSTC Settings").
After clicking "Download" a Page with all the custom functions appear. There you can enter your custom text, click on save to store the settings in the OSTC. Make sure to have an up-to date Downloader from Divinglog.
Hello Reiner
Here you can see it on the screenshot:
www.divinglog.de/pics/OSTCSettings3.png
Matthias, there seems to be a problem with the forum software. When I try to insert an image tag (embedded image) or link I'll get a server error message:
Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
[img]www.divinglog.de/pics/OSTCSettings3.png[/img]
OK, I'll check if the problem continues until Monday. Seems to be the database server is busy...
Edit: Now the entire Forum looks differrent but the IMG Tag is running again
Seems I'll have work for the weekend....
i got it now with the latest divinglog software and OSTC add-on as mentioned.
Obviously i was using an older divinglog version on this PC.
Thanks a lot, Reiner
