Put it on charge and it was lit up as usual. Came back later to check to see if it was full and nothing.
Tried a magnet reset and just got an orange light blinking.
Tried bootloader but no response.
Any Ideas? Not sure exactly what version it had on it but was 2.x something
OSTC 2N Frozen when charging with black screen
Re: OSTC 2N Frozen when charging with black screen
And if i unplug from usb and plug back in again nothing from pc or ostc.
When i do magnet reset. bootloader is open and download 2.5.
Comes up connected ok and flashes ok. Says write complete but still nothing.
I get orange and blue light when is being flashed.
Then sits there for a while and flashes orange. then nothing.
you have to do the magnet reset when connected to usb and charging
Hard to tell what happened here, can you send us a mail please: info@heinrichsweikamp.com - I'm quite sure we get this sorted.
What i did next was left it plugged into usb. Turned off computer (PC) and then unplugged 2n thinking that was it then it came back to life with 2.5 updated on it.
A very strange glitch but all seems to work ok now.
Dived it yesterdaqy with no issues.
How do you recharge the 2N? Through a PC or some sort of USB (Phone-) charger?
I always charge it through the pc and download the logs at the same time.
Is it ok to charge them through the mains via usb cable or is it best to leave connected to pc?
Any random 5V power-source with the right connector can be used to charge the OSTC....
OSTC 2N #4807
