I tried to upgrade to 2.61 last night but ended up with a blank screen and non-responsive OSTC. I think what may have happened was that I started the upgrade and just as it kicked off, the OSTC went to sleep. Nothing I do wakes it up.
I have also tried the magnetic reset as described by Matthias elsewhere in this forum. COM4 was the correct port to select before. When I plug OSTC in the computer beeps showing that the device is connected.
- Connect OSTC
- Start Bootloader
- Put magnet near middle screw on back
When I do this, nothing happens. I have tried pushing update firmware after putting the magnet on the back but all I get is the following:
Connected to \\.\COM4 at 115200
HEX: 4 days old, INHX32,18Fcode+cfg, total=85392 bytes.
ERROR!
Not found!
Any suggestions?
