Battery on MK2
Battery on MK2
Post by Bardass »
how can we do to change battery on MK2 ?
it's easy to unscrew the battery compartment, but after ?
i can't remove the battery, it's too hard to do it, there's not enough place to extract the battery.
gorcio
Re: Battery on MK2
Post by gorcio »
I guess you won't need the battery anymore ? Glue a string to the top of it, with a good glue and pull out :-). Even if you can't take it out completely, you might be able to use pliers as long as it sticks out a bit.
Kind regards,
Gorcio, OSTC MK2 828
Re: Battery on MK2
Post by Bardass »
no, i need the battery after trying to extract it
i want to use a soft method if it's possible ;)
Re: Battery on MK2
It's a tight fit but the battery just sits there. Give the OSTC a hard knock on the hand and the battery will be out.
Re: Battery on MK2
Post by Bardass »
I tried this before i opened this thread
Without any succes
Vert tight so ;)
Re: Battery on MK2
Try harder :-)
Re: Battery on MK2
Use a hammer :-))
Re: Battery on MK2
scubatinoo Wrote:
> Use a hammer :-))
That's how we got the battery in ;)
