Re: Weird NDL on 2,70
[DF]
I did my first dive with firmware version 2.70 yesterday. CCR, GF 30/90 with Tx12/62 as diluent.
Started dive with SP 0,5 and switched to 1,3 at about 25m and 10 minutes into the dive. 5 minutes later I descended to 35m and saw I had an impossible NDL of 46 minutes. For reference the Shearwater Predator that is connected to the cells showed 2 min NDL at that time.
I waited for a while to see if it would settle but it kept on showing unreasonable NDL:s. I switched back to 0.5 and then it showed 0 min NDL as it should have. Changed back to 1,3 and this time it worked. From that on it behaved like expected.
Should I send in some binaries grabbed with OSTC Tools or is there something else I can do to help you figure this out?
Update:
[size=medium]I have checked the NDL:s all the way from the start of the dive now and they ARE ALL WRONG except for the really shallow part.
I don’t know if it is because the firmware cannot handle a SP of 0.5 as except from the 0.7 I had it set on earlier or if the new firmware contains a serious bug in all respects. In any case I recommend that you cancel the 2.70 firmware release for now and recommend people to roll back to an earlier version.
It might be something with just my settings and then it is all good, but it might also be something that will bend the shit out of some people if they trust their computers thinking they are on and NDL dive.[/size]
Update:
Yes, please post the dive data downloaded with "OSTC Tools", for example. Let's have a look...
[DF]
I attached a screendump from Diving log too.
You can se at min 17 where i change the setpoint down to 0.5 again the NDL drops suddenly down from around 40min to 0min.
[img]file.php?2,file=408,filename=OSTC+strange+NDL.jpg[/img]
Hi there,
here the dive:
[img]file.php?2,file=409,filename=00831_25-0 ... 100min.jpg[/img]
I'm not a rebreather specialist but here are the profile data in pure text.
Export from OSTCProfile:
Filename: 00831_25-06-2013_047m_100min
DiveFileversion: 100
LogBookProfileVersion: 33
DiveNumber: 831
Date of dive: 25.06.2013
Time at begin of dive: 20:10:00
Time at end of dive: 21:51:00
Maximum depth (mbar): 4652
Maximum depth (bar): 4,652
Divetime: 100min 1sec
Selected Gas at begin of dive (1): 12/62
Gas 1: 12/62
Gas 2: 10/70
Gas 3: 15/55
Gas 4: 21/35
Gas 5: 20/20
Gas 6: 17/45
Minimum water temperature: 3,2
Maximum water temperature from profile:5,6
Minimum water temperature from profile:3,3
Surface air pressure (mBar): 1029
Desaturation time after dive (min): 619
Maximum CNS (%): 51
Average depth: 2115 mbar
Total divetime: 6301 sec
Gradient Factor Low: 30%
Gradient Factor High: 90%
Decotype: ZH-L16-GF CC
Last decostep: 3m
Firmware version: 270
Battery voltage in mV after dive: 4,153
Salinity: 1
Sampling rate (sec): 5
Sampling divisor temperature: 12 information size 2
Sampling divisor deco/NDL: 6 information size 2
Sampling divisor gradientfactor: 6 information size 1
Sampling divisor ppO2 sensors: 12 information size 3
Sampling divisor deco debug: 6 information size 15
Sampling divisor CNS: 12 information size 1
Profile data
ProfileOffset: 258
Number of ProfileEntries: 1260
Entry Time Depth mBar , Additional Info
1 0:05 1,82m 178 , SetPoint set to 50
2 0:10 2,67m 262
3 0:15 3,81m 374
4 0:20 4,19m 411
5 0:25 4,23m 415
6 0:30 4,39m 431 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
7 0:35 4,21m 413
8 0:40 4,49m 440
9 0:45 4,60m 451
10 0:50 4,64m 455
11 0:55 5,08m 498
12 1:00 5,07m 497 , Temperature 38, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
13 1:05 5,00m 490
14 1:10 5,01m 491
15 1:15 5,03m 493
16 1:20 5,05m 495
17 1:25 5,05m 495
18 1:30 4,98m 488 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
19 1:35 4,93m 483
20 1:40 4,86m 477
21 1:45 4,77m 468
22 1:50 4,89m 480
23 1:55 5,01m 491
24 2:00 4,98m 488 , Temperature 37, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
25 2:05 5,07m 497
26 2:10 4,88m 479
27 2:15 4,52m 443
28 2:20 4,70m 461
29 2:25 4,72m 463
30 2:30 4,51m 442 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
31 2:35 4,56m 447
32 2:40 4,71m 462
33 2:45 4,73m 464
34 2:50 5,02m 492
35 2:55 5,32m 522
36 3:00 5,45m 534 , Temperature 36, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
37 3:05 5,36m 526
38 3:10 5,37m 527
39 3:15 5,32m 522
40 3:20 5,30m 520
41 3:25 5,48m 537
42 3:30 5,52m 541 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
43 3:35 5,58m 547
44 3:40 5,61m 550
45 3:45 5,67m 556
46 3:50 5,41m 531
47 3:55 5,41m 531
48 4:00 5,23m 513 , Temperature 36, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
49 4:05 5,02m 492
50 4:10 5,23m 513
51 4:15 5,07m 497
52 4:20 5,76m 565
53 4:25 6,33m 621
54 4:30 6,89m 676 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
55 4:35 7,54m 739
56 4:40 8,26m 810
57 4:45 8,49m 833
58 4:50 8,50m 834
59 4:55 8,41m 825
60 5:00 8,58m 841 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
61 5:05 8,85m 868
62 5:10 9,27m 909
63 5:15 9,71m 952
64 5:20 9,90m 971
65 5:25 10,29m 1009
66 5:30 10,80m 1059 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
67 5:35 11,25m 1103
68 5:40 11,36m 1114
69 5:45 11,34m 1112
70 5:50 11,47m 1125
71 5:55 11,58m 1136
72 6:00 11,75m 1152 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
73 6:05 11,86m 1163
74 6:10 12,06m 1183
75 6:15 12,45m 1221
76 6:20 12,95m 1270
77 6:25 13,07m 1282
78 6:30 13,18m 1293 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
79 6:35 13,37m 1311
80 6:40 13,11m 1286
81 6:45 12,98m 1273
82 6:50 12,71m 1246
83 6:55 12,52m 1228
84 7:00 12,51m 1227 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
85 7:05 12,63m 1239
86 7:10 12,71m 1246
87 7:15 12,84m 1259
88 7:20 12,95m 1270
89 7:25 13,36m 1310
90 7:30 14,03m 1376 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
91 7:35 14,50m 1422
92 7:40 15,32m 1502
93 7:45 16,30m 1598
94 7:50 17,23m 1690
95 7:55 17,66m 1732
96 8:00 18,22m 1787 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
97 8:05 18,62m 1826
98 8:10 18,94m 1857
99 8:15 19,20m 1883
100 8:20 19,34m 1897
101 8:25 19,87m 1949
102 8:30 20,54m 2014 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
103 8:35 21,16m 2075
104 8:40 22,09m 2166
105 8:45 22,97m 2253
106 8:50 23,34m 2289
107 8:55 23,63m 2317
108 9:00 24,01m 2355 , Temperature 36, Non Deko Limit 179min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
109 9:05 24,53m 2406
110 9:10 24,81m 2433
111 9:15 25,14m 2465
112 9:20 25,39m 2490
113 9:25 25,67m 2517
114 9:30 26,00m 2550 , Non Deko Limit 128min, Gradient factor 0, Deco Debug
115 9:35 26,50m 2599
116 9:40 27,01m 2649
117 9:45 27,99m 2745
118 9:50 28,55m 2800
119 9:55 28,85m 2829
120 10:00 29,26m 2869 , Temperature 36, Non Deko Limit 83min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
121 10:05 29,65m 2908
122 10:10 30,11m 2953
123 10:15 30,41m 2982
124 10:20 30,36m 2977 , SetPoint set to 130
125 10:25 30,46m 2987
126 10:30 30,67m 3008 , Non Deko Limit 73min, Gradient factor 0, Deco Debug
127 10:35 30,89m 3029
128 10:40 31,31m 3070
129 10:45 31,37m 3076
130 10:50 31,48m 3087
131 10:55 31,41m 3080
132 11:00 31,48m 3087 , Temperature 37, Non Deko Limit 68min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
133 11:05 31,52m 3091
134 11:10 31,65m 3104
135 11:15 31,62m 3101
136 11:20 31,69m 3108
137 11:25 31,55m 3094
138 11:30 31,60m 3099 , Non Deko Limit 67min, Gradient factor 0, Deco Debug
139 11:35 31,58m 3097
140 11:40 31,44m 3083
141 11:45 31,44m 3083
142 11:50 31,44m 3083
143 11:55 31,44m 3083
144 12:00 31,52m 3091 , Temperature 38, Non Deko Limit 67min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
145 12:05 31,73m 3112
146 12:10 31,83m 3121
147 12:15 31,87m 3125
148 12:20 32,00m 3138
149 12:25 31,74m 3113
150 12:30 31,97m 3135 , Non Deko Limit 64min, Gradient factor 0, Deco Debug
151 12:35 31,92m 3130
152 12:40 31,96m 3134
153 12:45 32,04m 3142
154 12:50 32,02m 3140
155 12:55 32,02m 3140
156 13:00 31,85m 3123 , Temperature 39, Non Deko Limit 65min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
157 13:05 31,86m 3124
158 13:10 31,76m 3115
159 13:15 31,68m 3107
160 13:20 31,63m 3102
161 13:25 31,72m 3111
162 13:30 31,94m 3132 , Non Deko Limit 64min, Gradient factor 0, Deco Debug
163 13:35 32,14m 3152
164 13:40 32,41m 3178
165 13:45 32,62m 3199
166 13:50 32,68m 3205
167 13:55 33,08m 3244
168 14:00 33,79m 3314 , Temperature 40, Non Deko Limit 54min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
169 14:05 34,30m 3364
170 14:10 34,33m 3367
171 14:15 34,45m 3378
172 14:20 34,32m 3366
173 14:25 34,32m 3366
174 14:30 34,30m 3364 , Non Deko Limit 52min, Gradient factor 0, Deco Debug
175 14:35 34,65m 3398
176 14:40 35,01m 3433
177 14:45 35,33m 3465
178 14:50 35,54m 3485
179 14:55 35,54m 3485
180 15:00 35,62m 3493 , Temperature 41, Non Deko Limit 46min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 4
181 15:05 35,32m 3464
182 15:10 35,76m 3507
183 15:15 35,64m 3495
184 15:20 36,04m 3534
185 15:25 36,31m 3561
186 15:30 36,37m 3567 , Non Deko Limit 43min, Gradient factor 0, Deco Debug
187 15:35 36,58m 3587
188 15:40 36,68m 3597
189 15:45 37,01m 3629
190 15:50 36,93m 3622
191 15:55 36,86m 3615
192 16:00 36,96m 3625 , Temperature 44, Non Deko Limit 40min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 4
193 16:05 37,36m 3664
194 16:10 37,44m 3672
195 16:15 37,73m 3700
196 16:20 37,93m 3720
197 16:25 38,03m 3729
198 16:30 37,99m 3726 , Non Deko Limit 37min, Gradient factor 0, Deco Debug
199 16:35 38,49m 3775
200 16:40 38,60m 3785
201 16:45 38,79m 3804
202 16:50 38,57m 3782 , SetPoint set to 50
203 16:55 38,70m 3795
204 17:00 38,95m 3820 , Temperature 46, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 5
205 17:05 39,02m 3827 , SetPoint set to 130
206 17:10 39,15m 3839
207 17:15 39,06m 3830
208 17:20 39,02m 3827
209 17:25 38,87m 3812
210 17:30 38,47m 3773 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
211 17:35 38,46m 3772
212 17:40 38,49m 3775
213 17:45 38,47m 3773
214 17:50 38,66m 3791
215 17:55 38,43m 3769
216 18:00 38,50m 3776 , Temperature 48, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 5
217 18:05 38,65m 3790
218 18:10 38,88m 3813
219 18:15 39,01m 3826
220 18:20 39,26m 3850
221 18:25 39,53m 3877
222 18:30 39,71m 3894 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
223 18:35 40,02m 3925
224 18:40 40,14m 3936
225 18:45 40,30m 3952
226 18:50 40,64m 3985
227 18:55 40,98m 4019
228 19:00 41,07m 4028 , Temperature 49, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 6
229 19:05 41,10m 4031
230 19:10 40,81m 4002
231 19:15 41,07m 4028
232 19:20 41,01m 4022
233 19:25 41,00m 4021
234 19:30 41,07m 4028 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
235 19:35 40,83m 4004
236 19:40 40,79m 4000
237 19:45 40,84m 4005
238 19:50 40,76m 3997
239 19:55 41,15m 4035
240 20:00 41,42m 4062 , Temperature 50, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 6
241 20:05 41,23m 4043
242 20:10 41,10m 4031
243 20:15 41,02m 4023
244 20:20 40,82m 4003
245 20:25 40,55m 3977
246 20:30 40,65m 3986 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
247 20:35 40,59m 3981
248 20:40 40,55m 3977
249 20:45 40,39m 3961
250 20:50 40,36m 3958
251 20:55 40,50m 3972
252 21:00 40,49m 3971 , Temperature 52, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 7
253 21:05 40,70m 3991
254 21:10 40,59m 3981
255 21:15 40,71m 3992
256 21:20 40,62m 3983
257 21:25 40,47m 3969
258 21:30 40,37m 3959 , Decostop at 3m 1min, Gradient factor 0, Deco Debug 3m 1min
259 21:35 40,43m 3965
260 21:40 40,37m 3959
261 21:45 40,18m 3940
262 21:50 40,26m 3948
263 21:55 40,39m 3961
264 22:00 40,33m 3955 , Temperature 53, Decostop at 3m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 3m 1min, CNS 7
265 22:05 40,26m 3948
266 22:10 40,36m 3958
267 22:15 40,47m 3969
268 22:20 40,38m 3960
269 22:25 40,73m 3994
270 22:30 40,94m 4015 , Decostop at 3m 1min, Gradient factor 0, Deco Debug 3m 1min
271 22:35 40,74m 3995
272 22:40 40,82m 4003
273 22:45 40,88m 4009
274 22:50 41,09m 4030
275 22:55 41,31m 4051
276 23:00 41,73m 4092 , Temperature 53, Decostop at 3m 2min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 3m 2min, CNS 8
277 23:05 41,91m 4110
278 23:10 42,10m 4129
279 23:15 42,17m 4135
280 23:20 42,21m 4139
281 23:25 42,59m 4177
282 23:30 42,88m 4205 , Decostop at 3m 2min, Gradient factor 0, Deco Debug 3m 2min
283 23:35 43,10m 4227
284 23:40 43,43m 4259
285 23:45 43,96m 4311
286 23:50 44,62m 4376
287 23:55 44,97m 4410
288 24:00 45,06m 4419 , Temperature 53, Decostop at 6m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 6m 1min, 3m 2min, CNS 8
289 24:05 45,13m 4426
290 24:10 45,22m 4435
291 24:15 45,20m 4433
292 24:20 45,38m 4450
293 24:25 45,50m 4462
294 24:30 45,61m 4473 , Decostop at 6m 1min, Gradient factor 0, Deco Debug 6m 1min, 3m 2min
295 24:35 45,91m 4502
296 24:40 45,88m 4499
297 24:45 45,86m 4497
298 24:50 45,75m 4487
299 24:55 45,85m 4496
300 25:00 45,96m 4507 , Temperature 54, Decostop at 6m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 6m 1min, 3m 3min, CNS 9
301 25:05 45,70m 4482
302 25:10 45,61m 4473
303 25:15 45,98m 4509
304 25:20 45,94m 4505
305 25:25 45,69m 4481
306 25:30 46,23m 4534 , Decostop at 9m 1min, Gradient factor 0, Deco Debug 9m 1min, 6m 1min, 3m 2min
307 25:35 46,34m 4544
308 25:40 46,17m 4528
309 25:45 46,04m 4515
310 25:50 46,31m 4541
311 25:55 46,49m 4559
312 26:00 46,13m 4524 , Temperature 53, Decostop at 12m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 9m 1min, 6m 1min, 3m 3min, CNS 9
313 26:05 45,97m 4508
314 26:10 45,90m 4501
315 26:15 45,86m 4497
316 26:20 45,80m 4491
317 26:25 45,83m 4494
318 26:30 45,61m 4473 , Decostop at 12m 1min, Gradient factor 0, Deco Debug 9m 1min, 6m 2min, 3m 2min
319 26:35 45,68m 4480
320 26:40 45,90m 4501
321 26:45 45,86m 4497
322 26:50 45,87m 4498
323 26:55 45,75m 4487
324 27:00 45,44m 4456 , Temperature 54, Decostop at 12m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 9m 1min, 6m 2min, 3m 3min, CNS 10
325 27:05 45,35m 4447
326 27:10 45,27m 4439
327 27:15 45,31m 4443
328 27:20 45,45m 4457
329 27:25 45,48m 4460
330 27:30 45,23m 4436 , Decostop at 12m 1min, Gradient factor 0, Deco Debug 12m 1min, 9m 1min, 6m 1min, 3m 3min
331 27:35 45,08m 4421
332 27:40 44,96m 4409
333 27:45 45,07m 4420
334 27:50 45,17m 4430
335 27:55 44,97m 4410
336 28:00 44,76m 4389 , Temperature 54, Decostop at 12m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 1min, 9m 1min, 6m 2min, 3m 3min, CNS 11
337 28:05 44,47m 4361
338 28:10 44,31m 4345
339 28:15 44,09m 4324
340 28:20 44,28m 4342
341 28:25 44,13m 4328
342 28:30 44,01m 4316 , Decostop at 12m 1min, Gradient factor 0, Deco Debug 12m 1min, 9m 1min, 6m 2min, 3m 4min
343 28:35 43,86m 4301
344 28:40 43,79m 4294
345 28:45 43,44m 4260
346 28:50 43,13m 4230
347 28:55 43,16m 4233
348 29:00 43,07m 4224 , Temperature 55, Decostop at 12m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 1min, 9m 1min, 6m 2min, 3m 4min, CNS 11
349 29:05 42,72m 4189
350 29:10 42,59m 4177
351 29:15 42,78m 4195
352 29:20 42,87m 4204
353 29:25 42,85m 4202
354 29:30 42,72m 4189 , Decostop at 12m 1min, Gradient factor 0, Deco Debug 12m 1min, 9m 1min, 6m 3min, 3m 4min
355 29:35 42,72m 4189
356 29:40 42,77m 4194
357 29:45 42,82m 4199
358 29:50 42,59m 4177
359 29:55 42,55m 4173
360 30:00 42,55m 4173 , Temperature 55, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 1min, 9m 2min, 6m 2min, 3m 4min, CNS 12
361 30:05 42,35m 4153
362 30:10 41,95m 4114
363 30:15 42,04m 4123
364 30:20 41,82m 4101
365 30:25 41,89m 4108
366 30:30 41,70m 4089 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 12m 1min, 9m 2min, 6m 2min, 3m 5min
367 30:35 42,16m 4134
368 30:40 42,33m 4151
369 30:45 42,64m 4182
370 30:50 42,71m 4188
371 30:55 42,95m 4212
372 31:00 43,49m 4265 , Temperature 55, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 1min, 9m 2min, 6m 2min, 3m 5min, CNS 12
373 31:05 43,90m 4305
374 31:10 44,34m 4348
375 31:15 44,71m 4385
376 31:20 45,04m 4417
377 31:25 45,12m 4425
378 31:30 45,30m 4442 , Decostop at 12m 1min, Gradient factor 0, Deco Debug 12m 1min, 9m 2min, 6m 3min, 3m 4min
379 31:35 45,45m 4457
380 31:40 45,62m 4474
381 31:45 45,47m 4459
382 31:50 45,78m 4489
383 31:55 45,78m 4489
384 32:00 45,96m 4507 , Temperature 55, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 1min, 9m 1min, 6m 3min, 3m 5min, CNS 13
385 32:05 45,99m 4510
386 32:10 45,70m 4482
387 32:15 45,73m 4485
388 32:20 45,72m 4484
389 32:25 45,85m 4496
390 32:30 45,79m 4490 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 1min, 9m 1min, 6m 3min, 3m 5min
391 32:35 45,78m 4489
392 32:40 45,64m 4476
393 32:45 45,79m 4490
394 32:50 45,78m 4489
395 32:55 45,66m 4478
396 33:00 45,57m 4469 , Temperature 55, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 1min, 9m 2min, 6m 3min, 3m 5min, CNS 13
397 33:05 45,61m 4473
398 33:10 45,90m 4501
399 33:15 46,30m 4540
400 33:20 46,37m 4547
401 33:25 46,32m 4542
402 33:30 46,31m 4541 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 1min, 9m 2min, 6m 3min, 3m 5min
403 33:35 45,84m 4495
404 33:40 45,67m 4479
405 33:45 45,48m 4460
406 33:50 45,39m 4451
407 33:55 45,27m 4439
408 34:00 45,09m 4422 , Temperature 55, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 1min, 9m 2min, 6m 3min, 3m 6min, CNS 14
409 34:05 45,01m 4414
410 34:10 44,31m 4345
411 34:15 43,27m 4243
412 34:20 42,91m 4208
413 34:25 42,17m 4135
414 34:30 41,34m 4054 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 1min, 9m 2min, 6m 4min, 3m 6min
415 34:35 41,06m 4027
416 34:40 40,64m 3985
417 34:45 40,70m 3991
418 34:50 40,53m 3975
419 34:55 40,45m 3967
420 35:00 40,81m 4002 , Temperature 55, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 1min, 9m 3min, 6m 3min, 3m 6min, CNS 14
421 35:05 40,82m 4003
422 35:10 40,49m 3971
423 35:15 40,59m 3981
424 35:20 40,57m 3979
425 35:25 40,44m 3966
426 35:30 40,33m 3955 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 1min, 9m 3min, 6m 3min, 3m 7min
427 35:35 40,38m 3960
428 35:40 40,35m 3957
429 35:45 40,34m 3956
430 35:50 40,22m 3944
431 35:55 40,31m 3953
432 36:00 40,31m 3953 , Temperature 55, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 2min, 9m 2min, 6m 4min, 3m 6min, CNS 15
433 36:05 40,47m 3969
434 36:10 40,29m 3951
435 36:15 40,31m 3953
436 36:20 40,29m 3951
437 36:25 40,27m 3949
438 36:30 40,26m 3948 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 2min, 9m 2min, 6m 4min, 3m 7min
439 36:35 40,29m 3951
440 36:40 40,28m 3950
441 36:45 40,29m 3951
442 36:50 40,26m 3948
443 36:55 40,29m 3951
444 37:00 40,20m 3942 , Temperature 55, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 2min, 9m 2min, 6m 4min, 3m 7min, CNS 15
445 37:05 40,16m 3938
446 37:10 40,00m 3923
447 37:15 40,05m 3928
448 37:20 40,29m 3951
449 37:25 40,38m 3960
450 37:30 40,88m 4009 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 2min, 9m 2min, 6m 4min, 3m 7min
451 37:35 40,81m 4002
452 37:40 40,49m 3971
453 37:45 40,72m 3993
454 37:50 40,40m 3962
455 37:55 40,54m 3976
456 38:00 40,69m 3990 , Temperature 55, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 2min, 9m 3min, 6m 4min, 3m 7min, CNS 16
457 38:05 40,63m 3984
458 38:10 40,47m 3969
459 38:15 40,41m 3963
460 38:20 40,44m 3966
461 38:25 40,37m 3959
462 38:30 40,28m 3950 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 2min, 9m 3min, 6m 4min, 3m 7min
463 38:35 39,82m 3905
464 38:40 39,87m 3910
465 38:45 39,66m 3889
466 38:50 39,33m 3857
467 38:55 38,96m 3821
468 39:00 38,73m 3798 , Temperature 56, Decostop at 15m 2min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 2min, 12m 1min, 9m 3min, 6m 4min, 3m 8min, CNS 17
469 39:05 38,37m 3763
470 39:10 38,07m 3733
471 39:15 37,99m 3726
472 39:20 37,93m 3720
473 39:25 37,83m 3710
474 39:30 37,69m 3696 , Decostop at 15m 2min, Gradient factor 0, Deco Debug 15m 2min, 12m 1min, 9m 3min, 6m 5min, 3m 7min
475 39:35 37,79m 3706
476 39:40 37,94m 3721
477 39:45 38,18m 3744
478 39:50 38,38m 3764
479 39:55 38,64m 3789
480 40:00 38,71m 3796 , Temperature 55, Decostop at 15m 2min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 2min, 12m 1min, 9m 3min, 6m 5min, 3m 7min, CNS 17
481 40:05 38,62m 3787
482 40:10 38,76m 3801
483 40:15 38,69m 3794
484 40:20 38,58m 3783
485 40:25 38,48m 3774
486 40:30 38,52m 3778 , Decostop at 15m 2min, Gradient factor 0, Deco Debug 15m 2min, 12m 2min, 9m 2min, 6m 5min, 3m 8min
487 40:35 38,33m 3759
488 40:40 37,99m 3726
489 40:45 37,75m 3702
490 40:50 37,31m 3659
491 40:55 37,13m 3641
492 41:00 36,68m 3597 , Temperature 55, Decostop at 18m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 18m 1min, 15m 1min, 12m 2min, 9m 3min, 6m 4min, 3m 8min, CNS 18
493 41:05 36,61m 3590
494 41:10 36,33m 3563
495 41:15 36,16m 3546
496 41:20 35,84m 3515
497 41:25 35,94m 3525
498 41:30 35,65m 3496 , Decostop at 18m 1min, Gradient factor 0, Deco Debug 18m 1min, 15m 1min, 12m 2min, 9m 3min, 6m 5min, 3m 8min
499 41:35 35,16m 3448
500 41:40 35,02m 3434
501 41:45 34,86m 3419
502 41:50 34,80m 3413
503 41:55 34,06m 3340
504 42:00 33,73m 3308 , Temperature 56, Decostop at 18m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 18m 1min, 15m 1min, 12m 2min, 9m 3min, 6m 5min, 3m 8min, CNS 18
505 42:05 33,52m 3287
506 42:10 32,99m 3235
507 42:15 32,70m 3207
508 42:20 32,57m 3194
509 42:25 32,51m 3188
510 42:30 32,39m 3176 , Decostop at 18m 1min, Gradient factor 0, Deco Debug 18m 1min, 15m 1min, 12m 2min, 9m 3min, 6m 5min, 3m 8min
511 42:35 32,11m 3149
512 42:40 31,86m 3124
513 42:45 31,90m 3128
514 42:50 31,75m 3114
515 42:55 31,60m 3099
516 43:00 31,41m 3080 , Temperature 55, Decostop at 18m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 18m 1min, 15m 1min, 12m 2min, 9m 3min, 6m 5min, 3m 8min, CNS 19
517 43:05 31,18m 3058
518 43:10 30,89m 3029
519 43:15 30,46m 2987
520 43:20 30,14m 2956
521 43:25 30,22m 2964
522 43:30 30,35m 2976 , Decostop at 18m 1min, Gradient factor 0, Deco Debug 18m 1min, 15m 1min, 12m 2min, 9m 3min, 6m 5min, 3m 9min
523 43:35 30,41m 2982
524 43:40 30,39m 2980
525 43:45 30,33m 2974
526 43:50 30,28m 2969
527 43:55 30,34m 2975
528 44:00 30,46m 2987 , Temperature 52, Decostop at 15m 2min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 2min, 12m 2min, 9m 3min, 6m 5min, 3m 9min, CNS 19
529 44:05 30,32m 2973
530 44:10 30,39m 2980
531 44:15 30,59m 3000
532 44:20 30,56m 2997
533 44:25 30,55m 2996
534 44:30 30,57m 2998 , Decostop at 15m 2min, Gradient factor 0, Deco Debug 15m 2min, 12m 2min, 9m 3min, 6m 5min, 3m 9min
535 44:35 30,73m 3014
536 44:40 30,71m 3012
537 44:45 30,87m 3027
538 44:50 30,79m 3019
539 44:55 30,80m 3020
540 45:00 30,90m 3030 , Temperature 49, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 3min, 9m 3min, 6m 5min, 3m 9min, CNS 20
541 45:05 30,93m 3033
542 45:10 30,96m 3036
543 45:15 30,95m 3035
544 45:20 30,90m 3030
545 45:25 30,75m 3016
546 45:30 30,39m 2980 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 3min, 9m 3min, 6m 5min, 3m 9min
547 45:35 29,81m 2923
548 45:40 29,48m 2891
549 45:45 29,55m 2898
550 45:50 29,49m 2892
551 45:55 29,45m 2888
552 46:00 29,46m 2889 , Temperature 47, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 3min, 9m 3min, 6m 5min, 3m 9min, CNS 20
553 46:05 29,54m 2897
554 46:10 29,53m 2896
555 46:15 29,33m 2876
556 46:20 29,08m 2852
557 46:25 28,83m 2827
558 46:30 29,04m 2848 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 3min, 9m 3min, 6m 5min, 3m 9min
559 46:35 29,17m 2861
560 46:40 29,15m 2859
561 46:45 28,93m 2837
562 46:50 28,27m 2772
563 46:55 27,89m 2735
564 47:00 27,89m 2735 , Temperature 45, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 3min, 9m 3min, 6m 5min, 3m 10min, CNS 21
565 47:05 28,01m 2747
566 47:10 27,82m 2728
567 47:15 27,68m 2714
568 47:20 27,62m 2709
569 47:25 27,51m 2698
570 47:30 27,21m 2668 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 2min, 9m 4min, 6m 5min, 3m 10min
571 47:35 27,14m 2662
572 47:40 27,31m 2678
573 47:45 27,27m 2674
574 47:50 27,16m 2663
575 47:55 26,63m 2612
576 48:00 25,77m 2527 , Temperature 44, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 2min, 9m 4min, 6m 5min, 3m 10min, CNS 21
577 48:05 25,90m 2540
578 48:10 25,94m 2544
579 48:15 25,87m 2537
580 48:20 25,07m 2459
581 48:25 24,40m 2393
582 48:30 24,28m 2381 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 3min, 9m 3min, 6m 6min, 3m 9min
583 48:35 23,94m 2348
584 48:40 23,50m 2305
585 48:45 23,31m 2286
586 48:50 22,09m 2166
587 48:55 21,95m 2153
588 49:00 21,65m 2123 , Temperature 43, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 2min, 9m 4min, 6m 6min, 3m 9min, CNS 22
589 49:05 21,23m 2082
590 49:10 21,14m 2073
591 49:15 20,87m 2047
592 49:20 20,51m 2011
593 49:25 20,67m 2027
594 49:30 20,79m 2039 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 2min, 9m 4min, 6m 6min, 3m 9min
595 49:35 20,99m 2058
596 49:40 21,41m 2100
597 49:45 21,61m 2119
598 49:50 21,81m 2139
599 49:55 22,10m 2167
600 50:00 22,48m 2205 , Temperature 43, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 2min, 9m 4min, 6m 5min, 3m 10min, CNS 22
601 50:05 22,86m 2242
602 50:10 23,30m 2285
603 50:15 23,84m 2338
604 50:20 24,41m 2394
605 50:25 24,68m 2420
606 50:30 25,06m 2458 , Decostop at 12m 2min, Gradient factor 0, Deco Debug 12m 2min, 9m 4min, 6m 6min, 3m 10min
607 50:35 25,07m 2459
608 50:40 24,90m 2442
609 50:45 24,61m 2413
610 50:50 24,70m 2422
611 50:55 24,87m 2439
612 51:00 24,82m 2434 , Temperature 42, Decostop at 12m 2min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 2min, 9m 4min, 6m 6min, 3m 9min, CNS 23
613 51:05 24,99m 2451
614 51:10 25,09m 2460
615 51:15 25,23m 2474
616 51:20 25,22m 2473
617 51:25 25,04m 2456
618 51:30 24,81m 2433 , Decostop at 12m 2min, Gradient factor 0, Deco Debug 12m 2min, 9m 4min, 6m 6min, 3m 9min
619 51:35 25,01m 2453
620 51:40 25,02m 2454
621 51:45 25,18m 2469
622 51:50 25,54m 2505
623 51:55 25,57m 2508
624 52:00 25,68m 2518 , Temperature 42, Decostop at 12m 2min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 2min, 9m 4min, 6m 6min, 3m 10min, CNS 24
625 52:05 25,94m 2544
626 52:10 26,42m 2591
627 52:15 27,01m 2649
628 52:20 28,06m 2752
629 52:25 29,08m 2852
630 52:30 30,14m 2956 , Decostop at 12m 1min, Gradient factor 0, Deco Debug 12m 1min, 9m 4min, 6m 6min, 3m 10min
631 52:35 31,17m 3057
632 52:40 32,66m 3203
633 52:45 33,68m 3303
634 52:50 34,67m 3400
635 52:55 35,18m 3450
636 53:00 35,53m 3484 , Temperature 41, Decostop at 12m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 1min, 9m 4min, 6m 6min, 3m 10min, CNS 24
637 53:05 35,96m 3526
638 53:10 36,35m 3565
639 53:15 36,86m 3615
640 53:20 37,39m 3667
641 53:25 37,79m 3706
642 53:30 38,59m 3784 , Decostop at 12m 1min, Gradient factor 0, Deco Debug 12m 1min, 9m 4min, 6m 6min, 3m 10min
643 53:35 39,09m 3833
644 53:40 38,95m 3820
645 53:45 38,84m 3809
646 53:50 38,40m 3766
647 53:55 37,94m 3721
648 54:00 37,73m 3700 , Temperature 44, Decostop at 12m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 1min, 9m 4min, 6m 6min, 3m 11min, CNS 25
649 54:05 38,14m 3740
650 54:10 37,88m 3715
651 54:15 38,63m 3788
652 54:20 39,18m 3842
653 54:25 40,02m 3925
654 54:30 41,26m 4046 , Decostop at 12m 1min, Gradient factor 0, Deco Debug 12m 1min, 9m 4min, 6m 7min, 3m 10min
655 54:35 41,92m 4111
656 54:40 42,39m 4157
657 54:45 42,48m 4166
658 54:50 42,66m 4184
659 54:55 42,94m 4211
660 55:00 43,04m 4221 , Temperature 46, Decostop at 12m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 1min, 9m 4min, 6m 7min, 3m 11min, CNS 25
661 55:05 43,34m 4250
662 55:10 43,71m 4286
663 55:15 43,12m 4229
664 55:20 42,78m 4195
665 55:25 42,71m 4188
666 55:30 42,97m 4214 , Decostop at 12m 1min, Gradient factor 0, Deco Debug 12m 1min, 9m 5min, 6m 6min, 3m 11min
667 55:35 42,59m 4177
668 55:40 42,56m 4174
669 55:45 42,17m 4135
670 55:50 41,31m 4051
671 55:55 41,13m 4033
672 56:00 40,14m 3936 , Temperature 48, Decostop at 12m 2min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 2min, 9m 4min, 6m 7min, 3m 11min, CNS 26
673 56:05 39,17m 3841
674 56:10 38,51m 3777
675 56:15 37,90m 3717
676 56:20 37,22m 3650
677 56:25 36,27m 3557
678 56:30 35,59m 3490 , Decostop at 12m 2min, Gradient factor 0, Deco Debug 12m 2min, 9m 4min, 6m 7min, 3m 11min
679 56:35 35,38m 3470
680 56:40 35,16m 3448
681 56:45 34,65m 3398
682 56:50 34,18m 3352
683 56:55 33,93m 3327
684 57:00 32,92m 3228 , Temperature 50, Decostop at 12m 3min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 12m 3min, 9m 4min, 6m 7min, 3m 11min, CNS 26
685 57:05 32,34m 3171
686 57:10 31,68m 3107
687 57:15 30,82m 3022
688 57:20 30,23m 2965
689 57:25 29,69m 2912
690 57:30 28,85m 2829 , Decostop at 12m 3min, Gradient factor 0, Deco Debug 12m 3min, 9m 4min, 6m 7min, 3m 11min
691 57:35 27,99m 2745
692 57:40 27,28m 2675
693 57:45 26,49m 2598
694 57:50 25,99m 2549
695 57:55 25,59m 2510
696 58:00 25,17m 2468 , Temperature 49, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 2min, 9m 4min, 6m 7min, 3m 12min, CNS 27
697 58:05 25,25m 2476
698 58:10 25,17m 2468
699 58:15 25,19m 2470
700 58:20 25,12m 2463
701 58:25 24,81m 2433
702 58:30 24,35m 2388 , Decostop at 12m 3min, Gradient factor 0, Deco Debug 12m 3min, 9m 4min, 6m 7min, 3m 12min
703 58:35 23,99m 2353
704 58:40 23,40m 2295
705 58:45 23,18m 2273
706 58:50 22,86m 2242
707 58:55 22,16m 2173
708 59:00 21,43m 2102 , Temperature 48, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 2min, 9m 4min, 6m 8min, 3m 11min, CNS 27
709 59:05 20,70m 2030
710 59:10 19,95m 1956
711 59:15 19,69m 1931
712 59:20 19,55m 1917
713 59:25 19,27m 1890
714 59:30 18,66m 1830 , Decostop at 15m 1min, Gradient factor 0, Deco Debug 15m 1min, 12m 2min, 9m 5min, 6m 7min, 3m 11min
715 59:35 17,98m 1763
716 59:40 17,74m 1740
717 59:45 17,12m 1679
718 59:50 16,94m 1661
719 59:55 16,70m 1638
720 60:00 16,40m 1608 , Temperature 47, Decostop at 15m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 15m 1min, 12m 2min, 9m 4min, 6m 8min, 3m 11min, CNS 28
721 60:05 16,06m 1575
722 60:10 15,60m 1530
723 60:15 15,02m 1473
724 60:20 15,00m 1471
725 60:25 14,44m 1416
726 60:30 14,02m 1375 , Decostop at 12m 3min, Gradient factor 23, Deco Debug 12m 3min, 9m 4min, 6m 7min, 3m 12min
727 60:35 13,51m 1325
728 60:40 13,36m 1310
729 60:45 13,13m 1288
730 60:50 12,84m 1259
731 60:55 12,86m 1261
732 61:00 12,77m 1252 , Temperature 46, Decostop at 12m 3min, Gradient factor 33, ppO2 Sensor Value 33, Deco Debug 12m 3min, 9m 4min, 6m 7min, 3m 12min, CNS 28
733 61:05 12,63m 1239
734 61:10 12,60m 1236
735 61:15 12,59m 1235
736 61:20 12,81m 1256
737 61:25 13,12m 1287
738 61:30 13,16m 1291 , Decostop at 12m 2min, Gradient factor 27, Deco Debug 12m 2min, 9m 5min, 6m 7min, 3m 11min
739 61:35 13,23m 1297
740 61:40 13,23m 1297
741 61:45 13,34m 1308
742 61:50 13,26m 1300
743 61:55 13,09m 1284
744 62:00 13,00m 1275 , Temperature 44, Decostop at 12m 2min, Gradient factor 26, ppO2 Sensor Value 26, Deco Debug 12m 2min, 9m 4min, 6m 7min, 3m 12min, CNS 29
745 62:05 12,99m 1274
746 62:10 13,01m 1276
747 62:15 12,87m 1262
748 62:20 12,82m 1257
749 62:25 12,62m 1238
750 62:30 12,97m 1272 , Decostop at 12m 2min, Gradient factor 25, Deco Debug 12m 2min, 9m 4min, 6m 7min, 3m 11min
751 62:35 12,66m 1242
752 62:40 12,72m 1247
753 62:45 12,69m 1244
754 62:50 12,66m 1242
755 62:55 12,63m 1239
756 63:00 12,52m 1228 , Temperature 43, Decostop at 12m 1min, Gradient factor 27, ppO2 Sensor Value 27, Deco Debug 12m 1min, 9m 4min, 6m 8min, 3m 11min, CNS 29
757 63:05 12,41m 1217
758 63:10 12,21m 1197
759 63:15 12,19m 1195
760 63:20 12,34m 1210
761 63:25 12,47m 1223
762 63:30 12,54m 1230 , Decostop at 12m 1min, Gradient factor 24, Deco Debug 12m 1min, 9m 4min, 6m 7min, 3m 12min
763 63:35 12,16m 1192
764 63:40 12,22m 1198
765 63:45 12,24m 1200
766 63:50 12,50m 1226
767 63:55 12,51m 1227
768 64:00 11,97m 1174 , Temperature 41, Decostop at 9m 4min, Gradient factor 28, ppO2 Sensor Value 28, Deco Debug 9m 4min, 6m 8min, 3m 11min, CNS 30
769 64:05 11,49m 1127
770 64:10 10,78m 1057
771 64:15 10,03m 984
772 64:20 9,68m 949
773 64:25 9,87m 968
774 64:30 9,41m 923 , Decostop at 9m 4min, Gradient factor 53, Deco Debug 9m 4min, 6m 7min, 3m 12min
775 64:35 9,28m 910
776 64:40 9,25m 907
777 64:45 9,12m 894
778 64:50 9,13m 895
779 64:55 8,80m 863
780 65:00 8,09m 793 , Temperature 40, Decostop at 9m 4min, Gradient factor 65, ppO2 Sensor Value 65, Deco Debug 9m 4min, 6m 7min, 3m 11min, CNS 31
781 65:05 7,95m 780
782 65:10 8,84m 867
783 65:15 9,11m 893
784 65:20 9,32m 914
785 65:25 9,28m 910
786 65:30 9,27m 909 , Decostop at 9m 3min, Gradient factor 50, Deco Debug 9m 3min, 6m 7min, 3m 12min
787 65:35 9,22m 904
788 65:40 9,14m 896
789 65:45 8,82m 865
790 65:50 8,90m 873
791 65:55 8,79m 862
792 66:00 8,87m 870 , Temperature 38, Decostop at 9m 3min, Gradient factor 52, ppO2 Sensor Value 52, Deco Debug 9m 3min, 6m 7min, 3m 12min, CNS 31
793 66:05 8,96m 879
794 66:10 8,98m 881
795 66:15 9,23m 905
796 66:20 9,24m 906
797 66:25 9,20m 902
798 66:30 9,20m 902 , Decostop at 9m 2min, Gradient factor 46, Deco Debug 9m 2min, 6m 8min, 3m 11min
799 66:35 9,20m 902
800 66:40 9,28m 910
801 66:45 9,16m 898
802 66:50 9,15m 897
803 66:55 9,06m 888
804 67:00 8,93m 876 , Temperature 38, Decostop at 9m 2min, Gradient factor 39, ppO2 Sensor Value 39, Deco Debug 9m 2min, 6m 7min, 3m 12min, CNS 32
805 67:05 9,06m 888
806 67:10 9,10m 892
807 67:15 9,06m 888
808 67:20 9,03m 886
809 67:25 8,92m 875
810 67:30 8,84m 867 , Decostop at 9m 1min, Gradient factor 39, Deco Debug 9m 1min, 6m 8min, 3m 11min
811 67:35 9,03m 886
812 67:40 9,10m 892
813 67:45 9,08m 890
814 67:50 9,12m 894
815 67:55 9,11m 893
816 68:00 9,10m 892 , Temperature 38, Decostop at 9m 1min, Gradient factor 33, ppO2 Sensor Value 33, Deco Debug 9m 1min, 6m 7min, 3m 12min, CNS 32
817 68:05 9,12m 894
818 68:10 9,10m 892
819 68:15 9,11m 893
820 68:20 9,11m 893
821 68:25 9,11m 893
822 68:30 9,10m 892 , Decostop at 9m 1min, Gradient factor 32, Deco Debug 9m 1min, 6m 7min, 3m 11min
823 68:35 9,11m 893
824 68:40 9,15m 897
825 68:45 9,16m 898
826 68:50 9,18m 900
827 68:55 9,16m 898
828 69:00 9,15m 897 , Temperature 37, Decostop at 6m 7min, Gradient factor 29, ppO2 Sensor Value 29, Deco Debug 6m 7min, 3m 12min, CNS 33
829 69:05 9,15m 897
830 69:10 9,09m 891
831 69:15 8,68m 851
832 69:20 7,97m 782
833 69:25 7,83m 768
834 69:30 7,83m 768 , Decostop at 6m 7min, Gradient factor 44, Deco Debug 6m 7min, 3m 12min
835 69:35 7,79m 764
836 69:40 7,57m 742
837 69:45 7,16m 702
838 69:50 7,09m 695
839 69:55 6,95m 682
840 70:00 6,79m 666 , Temperature 37, Decostop at 6m 7min, Gradient factor 55, ppO2 Sensor Value 55, Deco Debug 6m 7min, 3m 11min, CNS 33
841 70:05 6,70m 657
842 70:10 6,56m 643
843 70:15 6,56m 643
844 70:20 6,43m 631
845 70:25 6,04m 592
846 70:30 6,12m 600 , Decostop at 6m 6min, Gradient factor 62, Deco Debug 6m 6min, 3m 12min
847 70:35 5,97m 585
848 70:40 6,05m 593
849 70:45 5,99m 587
850 70:50 5,99m 587
851 70:55 5,96m 584
852 71:00 5,99m 587 , Temperature 36, Decostop at 6m 6min, Gradient factor 62, ppO2 Sensor Value 62, Deco Debug 6m 6min, 3m 11min, CNS 34
853 71:05 5,96m 584
854 71:10 5,96m 584
855 71:15 5,96m 584
856 71:20 5,83m 572
857 71:25 6,16m 604
858 71:30 6,24m 612 , Decostop at 6m 5min, Gradient factor 57, Deco Debug 6m 5min, 3m 12min
859 71:35 6,23m 611
860 71:40 6,24m 612
861 71:45 6,25m 613
862 71:50 6,13m 601
863 71:55 6,20m 608
864 72:00 6,35m 623 , Temperature 35, Decostop at 6m 5min, Gradient factor 54, ppO2 Sensor Value 54, Deco Debug 6m 5min, 3m 11min, CNS 34
865 72:05 6,43m 631
866 72:10 6,48m 635
867 72:15 6,59m 646
868 72:20 6,56m 643
869 72:25 6,64m 651
870 72:30 6,64m 651 , Decostop at 6m 4min, Gradient factor 48, Deco Debug 6m 4min, 3m 12min
871 72:35 6,59m 646
872 72:40 6,59m 646
873 72:45 6,36m 624
874 72:50 6,30m 618
875 72:55 6,49m 636
876 73:00 6,45m 633 , Temperature 35, Decostop at 6m 4min, Gradient factor 48, ppO2 Sensor Value 48, Deco Debug 6m 4min, 3m 11min, CNS 35
877 73:05 6,49m 636
878 73:10 6,87m 674
879 73:15 6,92m 679
880 73:20 6,80m 667
881 73:25 6,59m 646
882 73:30 6,52m 639 , Decostop at 6m 3min, Gradient factor 45, Deco Debug 6m 3min, 3m 12min
883 73:35 6,60m 647
884 73:40 6,65m 652
885 73:45 6,64m 651
886 73:50 6,64m 651
887 73:55 6,74m 661
888 74:00 6,71m 658 , Temperature 35, Decostop at 6m 3min, Gradient factor 41, ppO2 Sensor Value 41, Deco Debug 6m 3min, 3m 12min, CNS 35
889 74:05 6,74m 661
890 74:10 6,59m 646
891 74:15 6,57m 644
892 74:20 6,49m 636
893 74:25 6,59m 646
894 74:30 6,54m 641 , Decostop at 6m 2min, Gradient factor 41, Deco Debug 6m 2min, 3m 12min
895 74:35 6,52m 639
896 74:40 6,37m 625
897 74:45 6,49m 636
898 74:50 6,24m 612
899 74:55 6,14m 602
900 75:00 6,28m 616 , Temperature 34, Decostop at 6m 2min, Gradient factor 43, ppO2 Sensor Value 43, Deco Debug 6m 2min, 3m 12min, CNS 36
901 75:05 6,24m 612
902 75:10 6,47m 634
903 75:15 6,83m 670
904 75:20 6,73m 660
905 75:25 6,57m 644
906 75:30 6,43m 631 , Decostop at 6m 1min, Gradient factor 39, Deco Debug 6m 1min, 3m 12min
907 75:35 6,59m 646
908 75:40 6,48m 635
909 75:45 6,72m 659
910 75:50 6,70m 657
911 75:55 6,69m 656
912 76:00 6,58m 645 , Temperature 34, Decostop at 6m 1min, Gradient factor 35, ppO2 Sensor Value 35, Deco Debug 6m 1min, 3m 12min, CNS 37
913 76:05 6,57m 644
914 76:10 6,60m 647
915 76:15 6,58m 645
916 76:20 6,58m 645
917 76:25 6,57m 644
918 76:30 6,57m 644 , Decostop at 3m 12min, Gradient factor 33, Deco Debug 3m 12min
919 76:35 6,95m 682
920 76:40 6,93m 680
921 76:45 6,65m 652
922 76:50 6,74m 661
923 76:55 6,57m 644
924 77:00 6,55m 642 , Temperature 34, Decostop at 3m 12min, Gradient factor 32, ppO2 Sensor Value 32, Deco Debug 3m 12min, CNS 37
925 77:05 6,68m 655
926 77:10 6,93m 680
927 77:15 6,97m 684
928 77:20 6,80m 667
929 77:25 6,63m 650
930 77:30 6,45m 633 , Decostop at 3m 11min, Gradient factor 24, Deco Debug 3m 11min
931 77:35 5,99m 587
932 77:40 5,87m 576
933 77:45 5,85m 574
934 77:50 5,62m 551
935 77:55 5,77m 566
936 78:00 6,08m 596 , Temperature 34, Decostop at 3m 11min, Gradient factor 28, ppO2 Sensor Value 28, Deco Debug 3m 11min, CNS 38
937 78:05 5,57m 546
938 78:10 5,41m 531
939 78:15 5,51m 540
940 78:20 5,38m 528
941 78:25 5,34m 524
942 78:30 5,36m 526 , Decostop at 3m 11min, Gradient factor 37, Deco Debug 3m 11min
943 78:35 4,55m 446
944 78:40 4,48m 439
945 78:45 4,45m 436
946 78:50 4,45m 436
947 78:55 4,62m 453
948 79:00 4,41m 432 , Temperature 34, Decostop at 3m 10min, Gradient factor 50, ppO2 Sensor Value 50, Deco Debug 3m 10min, CNS 38
949 79:05 4,42m 433
950 79:10 4,32m 424
951 79:15 4,49m 440
952 79:20 4,53m 444
953 79:25 4,58m 449
954 79:30 4,70m 461 , Decostop at 3m 10min, Gradient factor 44, Deco Debug 3m 10min
955 79:35 4,68m 459
956 79:40 4,66m 457
957 79:45 4,79m 470
958 79:50 4,61m 452
959 79:55 4,33m 425
960 80:00 4,32m 424 , Temperature 33, Decostop at 3m 9min, Gradient factor 48, ppO2 Sensor Value 48, Deco Debug 3m 9min, CNS 39
961 80:05 3,76m 369
962 80:10 3,65m 358
963 80:15 3,71m 364
964 80:20 3,68m 361
965 80:25 3,79m 372
966 80:30 3,99m 391 , Decostop at 3m 9min, Gradient factor 52, Deco Debug 3m 9min
967 80:35 3,99m 391
968 80:40 3,98m 390
969 80:45 4,11m 403
970 80:50 4,72m 463
971 80:55 4,38m 430
972 81:00 4,14m 406 , Temperature 33, Decostop at 3m 8min, Gradient factor 48, ppO2 Sensor Value 48, Deco Debug 3m 8min, CNS 39
973 81:05 4,01m 393
974 81:10 3,82m 375
975 81:15 4,18m 410
976 81:20 4,69m 460
977 81:25 4,08m 400
978 81:30 3,74m 367 , Decostop at 3m 8min, Gradient factor 53, Deco Debug 3m 8min
979 81:35 3,11m 305
980 81:40 3,17m 311
981 81:45 3,40m 333
982 81:50 3,59m 352
983 81:55 3,44m 337
984 82:00 2,79m 274 , Temperature 33, Decostop at 3m 7min, Gradient factor 66, ppO2 Sensor Value 66, Deco Debug 3m 7min, CNS 40
985 82:05 3,21m 315
986 82:10 3,44m 337
987 82:15 3,66m 359
988 82:20 3,86m 379
989 82:25 3,82m 375
990 82:30 3,59m 352 , Decostop at 3m 7min, Gradient factor 52, Deco Debug 3m 7min
991 82:35 3,77m 370
992 82:40 3,73m 366
993 82:45 3,79m 372
994 82:50 3,86m 379
995 82:55 3,85m 378
996 83:00 3,67m 360 , Temperature 33, Decostop at 3m 6min, Gradient factor 49, ppO2 Sensor Value 49, Deco Debug 3m 6min, CNS 40
997 83:05 3,55m 348
998 83:10 3,54m 347
999 83:15 3,24m 318
1000 83:20 3,17m 311
1001 83:25 3,15m 309
1002 83:30 3,25m 319 , Decostop at 3m 6min, Gradient factor 54, Deco Debug 3m 6min
1003 83:35 3,25m 319
1004 83:40 3,25m 319
1005 83:45 3,20m 314
1006 83:50 3,02m 296
1007 83:55 3,03m 297
1008 84:00 3,31m 325 , Temperature 33, Decostop at 3m 5min, Gradient factor 52, ppO2 Sensor Value 52, Deco Debug 3m 5min, CNS 41
1009 84:05 3,34m 328
1010 84:10 3,40m 333
1011 84:15 3,42m 335
1012 84:20 3,53m 346
1013 84:25 3,60m 353
1014 84:30 3,61m 354 , Decostop at 3m 5min, Gradient factor 46, Deco Debug 3m 5min
1015 84:35 3,71m 364
1016 84:40 3,71m 364
1017 84:45 3,66m 359
1018 84:50 3,64m 357
1019 84:55 3,64m 357
1020 85:00 3,62m 355 , Temperature 33, Decostop at 3m 4min, Gradient factor 44, ppO2 Sensor Value 44, Deco Debug 3m 4min, CNS 41
1021 85:05 3,69m 362
1022 85:10 3,68m 361
1023 85:15 3,90m 382
1024 85:20 3,87m 380
1025 85:25 3,79m 372
1026 85:30 3,69m 362 , Decostop at 3m 4min, Gradient factor 41, Deco Debug 3m 4min
1027 85:35 3,63m 356
1028 85:40 3,76m 369
1029 85:45 3,95m 387
1030 85:50 3,91m 383
1031 85:55 3,64m 357
1032 86:00 3,57m 350 , Temperature 33, Decostop at 3m 3min, Gradient factor 42, ppO2 Sensor Value 42, Deco Debug 3m 3min, CNS 42
1033 86:05 3,47m 340
1034 86:10 3,52m 345
1035 86:15 3,66m 359
1036 86:20 3,85m 378
1037 86:25 4,00m 392
1038 86:30 3,81m 374 , Decostop at 3m 3min, Gradient factor 36, Deco Debug 3m 3min
1039 86:35 4,03m 395
1040 86:40 4,06m 398
1041 86:45 3,64m 357
1042 86:50 3,59m 352
1043 86:55 3,54m 347
1044 87:00 3,34m 328 , Temperature 33, Decostop at 3m 2min, Gradient factor 42, ppO2 Sensor Value 42, Deco Debug 3m 2min, CNS 42
1045 87:05 3,14m 308
1046 87:10 3,23m 317
1047 87:15 3,29m 323
1048 87:20 3,39m 332
1049 87:25 3,50m 343
1050 87:30 3,54m 347 , Decostop at 3m 2min, Gradient factor 32, Deco Debug 3m 2min
1051 87:35 3,60m 353
1052 87:40 3,51m 344
1053 87:45 3,35m 329
1054 87:50 3,50m 343
1055 87:55 3,60m 353
1056 88:00 3,67m 360 , Temperature 33, Decostop at 3m 1min, Gradient factor 29, ppO2 Sensor Value 29, Deco Debug 3m 1min, CNS 43
1057 88:05 3,34m 328
1058 88:10 3,08m 302
1059 88:15 3,29m 323
1060 88:20 3,31m 325
1061 88:25 3,41m 334
1062 88:30 3,41m 334 , Decostop at 3m 1min, Gradient factor 32, Deco Debug 3m 1min
1063 88:35 3,47m 340
1064 88:40 3,38m 331
1065 88:45 3,23m 317
1066 88:50 3,21m 315
1067 88:55 3,26m 320
1068 89:00 3,31m 325 , Temperature 33, Non Deko Limit 240min, Gradient factor 33, ppO2 Sensor Value 33, Deco Debug , CNS 44
1069 89:05 3,30m 324
1070 89:10 3,29m 323
1071 89:15 3,31m 325
1072 89:20 3,30m 324
1073 89:25 3,30m 324
1074 89:30 3,30m 324 , Non Deko Limit 240min, Gradient factor 32, Deco Debug
1075 89:35 3,31m 325
1076 89:40 3,27m 321
1077 89:45 3,27m 321
1078 89:50 3,30m 324
1079 89:55 3,32m 326
1080 90:00 3,35m 329 , Temperature 33, Non Deko Limit 240min, Gradient factor 29, ppO2 Sensor Value 29, Deco Debug , CNS 44
1081 90:05 3,40m 333
1082 90:10 3,34m 328
1083 90:15 3,19m 313
1084 90:20 3,46m 339
1085 90:25 3,84m 377
1086 90:30 3,71m 364 , Non Deko Limit 240min, Gradient factor 22, Deco Debug
1087 90:35 4,16m 408
1088 90:40 4,70m 461
1089 90:45 4,94m 484
1090 90:50 4,98m 488
1091 90:55 4,95m 485
1092 91:00 4,98m 488 , Temperature 33, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 45
1093 91:05 5,05m 495
1094 91:10 5,02m 492
1095 91:15 4,74m 465
1096 91:20 4,75m 466
1097 91:25 4,76m 467
1098 91:30 4,13m 405 , Non Deko Limit 240min, Gradient factor 13, Deco Debug
1099 91:35 3,93m 385
1100 91:40 3,56m 349
1101 91:45 3,64m 357
1102 91:50 3,63m 356
1103 91:55 3,46m 339
1104 92:00 3,40m 333 , Temperature 33, Non Deko Limit 240min, Gradient factor 24, ppO2 Sensor Value 24, Deco Debug , CNS 45
1105 92:05 3,35m 329
1106 92:10 3,06m 300
1107 92:15 3,11m 305
1108 92:20 3,14m 308
1109 92:25 3,24m 318
1110 92:30 3,29m 323 , Non Deko Limit 240min, Gradient factor 25, Deco Debug
1111 92:35 3,16m 310
1112 92:40 3,31m 325
1113 92:45 3,26m 320
1114 92:50 3,16m 310
1115 92:55 3,02m 296
1116 93:00 2,87m 281 , Temperature 33, Non Deko Limit 240min, Gradient factor 31, ppO2 Sensor Value 31, Deco Debug , CNS 46
1117 93:05 3,05m 299
1118 93:10 3,05m 299
1119 93:15 3,06m 300
1120 93:20 2,97m 291
1121 93:25 3,12m 306
1122 93:30 3,28m 322 , Non Deko Limit 240min, Gradient factor 23, Deco Debug
1123 93:35 3,04m 298
1124 93:40 3,17m 311
1125 93:45 3,11m 305
1126 93:50 3,10m 304
1127 93:55 3,21m 315
1128 94:00 3,25m 319 , Temperature 33, Non Deko Limit 240min, Gradient factor 22, ppO2 Sensor Value 22, Deco Debug , CNS 46
1129 94:05 3,24m 318
1130 94:10 3,10m 304
1131 94:15 3,06m 300
1132 94:20 3,14m 308
1133 94:25 3,25m 319
1134 94:30 3,01m 295 , Non Deko Limit 240min, Gradient factor 25, Deco Debug
1135 94:35 3,03m 297
1136 94:40 2,91m 285
1137 94:45 2,89m 283
1138 94:50 2,67m 262
1139 94:55 2,81m 276
1140 95:00 2,75m 270 , Temperature 33, Non Deko Limit 240min, Gradient factor 29, ppO2 Sensor Value 29, Deco Debug , CNS 47
1141 95:05 2,56m 251
1142 95:10 2,05m 201
1143 95:15 2,09m 205
1144 95:20 2,03m 199
1145 95:25 1,83m 179
1146 95:30 1,84m 180 , Non Deko Limit 240min, Gradient factor 44, Deco Debug
1147 95:35 1,89m 185
1148 95:40 2,20m 216
1149 95:45 2,38m 233
1150 95:50 2,70m 265
1151 95:55 2,58m 253
1152 96:00 2,57m 252 , Temperature 33, Non Deko Limit 240min, Gradient factor 30, ppO2 Sensor Value 30, Deco Debug , CNS 47
1153 96:05 2,74m 269
1154 96:10 2,85m 279
1155 96:15 2,43m 238
1156 96:20 2,11m 207
1157 96:25 1,79m 176
1158 96:30 1,83m 179 , Non Deko Limit 240min, Gradient factor 42, Deco Debug
1159 96:35 1,92m 188
1160 96:40 2,14m 210
1161 96:45 2,20m 216
1162 96:50 2,36m 231
1163 96:55 2,23m 219
1164 97:00 2,12m 208 , Temperature 33, Non Deko Limit 240min, Gradient factor 36, ppO2 Sensor Value 36, Deco Debug , CNS 48
1165 97:05 1,58m 155
1166 97:10 1,37m 134
1167 97:15 1,64m 161
1168 97:20 1,83m 179
1169 97:25 1,71m 168
1170 97:30 1,68m 165 , Non Deko Limit 240min, Gradient factor 42, Deco Debug
1171 97:35 1,76m 173
1172 97:40 1,78m 175
1173 97:45 1,92m 188
1174 97:50 1,74m 171
1175 97:55 1,68m 165
1176 98:00 1,57m 154 , Temperature 33, Non Deko Limit 240min, Gradient factor 43, ppO2 Sensor Value 43, Deco Debug , CNS 48
1177 98:05 1,35m 132
1178 98:10 1,44m 141
1179 98:15 1,25m 123
1180 98:20 1,38m 135
1181 98:25 1,42m 139
1182 98:30 1,13m 111 , Non Deko Limit 240min, Gradient factor 50, Deco Debug
1183 98:35 0,77m 76
1184 98:40 1,22m 120
1185 98:45 1,25m 123
1186 98:50 1,26m 124
1187 98:55 1,27m 125
1188 99:00 1,28m 126 , Temperature 33, Non Deko Limit 240min, Gradient factor 46, ppO2 Sensor Value 46, Deco Debug , CNS 49
1189 99:05 1,31m 128
1190 99:10 1,34m 131
1191 99:15 1,49m 146
1192 99:20 1,52m 149
1193 99:25 1,78m 175
1194 99:30 1,90m 186 , Non Deko Limit 240min, Gradient factor 30, Deco Debug
1195 99:35 2,23m 219
1196 99:40 2,15m 211
1197 99:45 1,80m 177
1198 99:50 1,39m 136
1199 99:55 1,28m 126
1200 100:00 1,00m 98 , Temperature 33, Non Deko Limit 240min, Gradient factor 46, ppO2 Sensor Value 46, Deco Debug , CNS 49
1201 100:05 0,64m 63
1202 100:10 0,43m 42
1203 100:15 0,03m 3
1204 100:20 0,03m 3
1205 100:25 0,02m 2
1206 100:30 0,03m 3 , Non Deko Limit 240min, Gradient factor 64, Deco Debug
1207 100:35 0,03m 3
1208 100:40 0,10m 10
1209 100:45 0,24m 24
1210 100:50 0,34m 33
1211 100:55 0,04m 4
1212 101:00 0,03m 3 , Temperature 33, Non Deko Limit 240min, Gradient factor 63, ppO2 Sensor Value 63, Deco Debug , CNS 49
1213 101:05 0,02m 2
1214 101:10 0,03m 3
1215 101:15 0,02m 2
1216 101:20 0,03m 3
1217 101:25 0,02m 2
1218 101:30 0,02m 2 , Non Deko Limit 240min, Gradient factor 63, Deco Debug
1219 101:35 0,04m 4
1220 101:40 0,01m 1
1221 101:45 0,03m 3
1222 101:50 0,02m 2
1223 101:55 0,03m 3
1224 102:00 0,01m 1 , Temperature 33, Non Deko Limit 240min, Gradient factor 62, ppO2 Sensor Value 62, Deco Debug , CNS 50
1225 102:05 0,03m 3
1226 102:10 0,03m 3
1227 102:15 0,03m 3
1228 102:20 0,02m 2
1229 102:25 0,03m 3
1230 102:30 0,02m 2 , Non Deko Limit 240min, Gradient factor 61, Deco Debug
1231 102:35 0,02m 2
1232 102:40 0,04m 4
1233 102:45 0,03m 3
1234 102:50 0,03m 3
1235 102:55 0,03m 3
1236 103:00 0,04m 4 , Temperature 34, Non Deko Limit 240min, Gradient factor 60, ppO2 Sensor Value 60, Deco Debug , CNS 50
1237 103:05 0,03m 3
1238 103:10 0,02m 2
1239 103:15 0,03m 3
1240 103:20 0,04m 4
1241 103:25 0,02m 2
1242 103:30 0,03m 3 , Non Deko Limit 240min, Gradient factor 59, Deco Debug
1243 103:35 0,02m 2
1244 103:40 0,03m 3
1245 103:45 0,02m 2
1246 103:50 0,02m 2
1247 103:55 0,03m 3
1248 104:00 0,03m 3 , Temperature 34, Non Deko Limit 240min, Gradient factor 58, ppO2 Sensor Value 58, Deco Debug , CNS 51
1249 104:05 0,02m 2
1250 104:10 0,03m 3
1251 104:15 0,03m 3
1252 104:20 0,04m 4
1253 104:25 0,03m 3
1254 104:30 0,02m 2 , Non Deko Limit 240min, Gradient factor 58, Deco Debug
1255 104:35 0,02m 2
1256 104:40 0,04m 4
1257 104:45 0,03m 3
1258 104:50 0,03m 3
1259 104:55 0,03m 3
1260 105:00 0,03m 3 , Temperature 34, Non Deko Limit 240min, Gradient factor 57, ppO2 Sensor Value 57, Deco Debug , CNS 51
here the dive:
DiveNumber: 831
Gas 1: 12/62
Gas 2: 10/70
Gas 3: 15/55
Gas 4: 21/35
Gas 5: 20/20
Gas 6: 17/45
Maximum CNS (%): 51
Last decostep: 3m
Salinity: 1
Profile data
ProfileOffset: 258
2 0:10 2,67m 262
3 0:15 3,81m 374
4 0:20 4,19m 411
5 0:25 4,23m 415
7 0:35 4,21m 413
8 0:40 4,49m 440
9 0:45 4,60m 451
10 0:50 4,64m 455
11 0:55 5,08m 498
13 1:05 5,00m 490
14 1:10 5,01m 491
15 1:15 5,03m 493
16 1:20 5,05m 495
17 1:25 5,05m 495
19 1:35 4,93m 483
20 1:40 4,86m 477
21 1:45 4,77m 468
22 1:50 4,89m 480
23 1:55 5,01m 491
25 2:05 5,07m 497
26 2:10 4,88m 479
27 2:15 4,52m 443
28 2:20 4,70m 461
29 2:25 4,72m 463
31 2:35 4,56m 447
32 2:40 4,71m 462
33 2:45 4,73m 464
34 2:50 5,02m 492
35 2:55 5,32m 522
37 3:05 5,36m 526
38 3:10 5,37m 527
39 3:15 5,32m 522
40 3:20 5,30m 520
41 3:25 5,48m 537
43 3:35 5,58m 547
44 3:40 5,61m 550
45 3:45 5,67m 556
46 3:50 5,41m 531
47 3:55 5,41m 531
49 4:05 5,02m 492
50 4:10 5,23m 513
51 4:15 5,07m 497
52 4:20 5,76m 565
53 4:25 6,33m 621
55 4:35 7,54m 739
56 4:40 8,26m 810
57 4:45 8,49m 833
58 4:50 8,50m 834
59 4:55 8,41m 825
61 5:05 8,85m 868
62 5:10 9,27m 909
63 5:15 9,71m 952
64 5:20 9,90m 971
65 5:25 10,29m 1009
67 5:35 11,25m 1103
68 5:40 11,36m 1114
69 5:45 11,34m 1112
70 5:50 11,47m 1125
71 5:55 11,58m 1136
73 6:05 11,86m 1163
74 6:10 12,06m 1183
75 6:15 12,45m 1221
76 6:20 12,95m 1270
77 6:25 13,07m 1282
79 6:35 13,37m 1311
80 6:40 13,11m 1286
81 6:45 12,98m 1273
82 6:50 12,71m 1246
83 6:55 12,52m 1228
85 7:05 12,63m 1239
86 7:10 12,71m 1246
87 7:15 12,84m 1259
88 7:20 12,95m 1270
89 7:25 13,36m 1310
91 7:35 14,50m 1422
92 7:40 15,32m 1502
93 7:45 16,30m 1598
94 7:50 17,23m 1690
95 7:55 17,66m 1732
97 8:05 18,62m 1826
98 8:10 18,94m 1857
99 8:15 19,20m 1883
772 64:20 9,68m 949
773 64:25 9,87m 968
775 64:35 9,28m 910
776 64:40 9,25m 907
777 64:45 9,12m 894
778 64:50 9,13m 895
779 64:55 8,80m 863
781 65:05 7,95m 780
782 65:10 8,84m 867
783 65:15 9,11m 893
784 65:20 9,32m 914
785 65:25 9,28m 910
787 65:35 9,22m 904
788 65:40 9,14m 896
789 65:45 8,82m 865
790 65:50 8,90m 873
791 65:55 8,79m 862
793 66:05 8,96m 879
794 66:10 8,98m 881
795 66:15 9,23m 905
796 66:20 9,24m 906
797 66:25 9,20m 902
799 66:35 9,20m 902
800 66:40 9,28m 910
801 66:45 9,16m 898
802 66:50 9,15m 897
803 66:55 9,06m 888
805 67:05 9,06m 888
806 67:10 9,10m 892
807 67:15 9,06m 888
808 67:20 9,03m 886
809 67:25 8,92m 875
811 67:35 9,03m 886
812 67:40 9,10m 892
813 67:45 9,08m 890
814 67:50 9,12m 894
815 67:55 9,11m 893
817 68:05 9,12m 894
818 68:10 9,10m 892
819 68:15 9,11m 893
820 68:20 9,11m 893
821 68:25 9,11m 893
823 68:35 9,11m 893
824 68:40 9,15m 897
825 68:45 9,16m 898
826 68:50 9,18m 900
827 68:55 9,16m 898
829 69:05 9,15m 897
830 69:10 9,09m 891
831 69:15 8,68m 851
832 69:20 7,97m 782
833 69:25 7,83m 768
835 69:35 7,79m 764
836 69:40 7,57m 742
837 69:45 7,16m 702
838 69:50 7,09m 695
839 69:55 6,95m 682
841 70:05 6,70m 657
842 70:10 6,56m 643
843 70:15 6,56m 643
844 70:20 6,43m 631
845 70:25 6,04m 592
847 70:35 5,97m 585
848 70:40 6,05m 593
849 70:45 5,99m 587
850 70:50 5,99m 587
851 70:55 5,96m 584
853 71:05 5,96m 584
854 71:10 5,96m 584
855 71:15 5,96m 584
856 71:20 5,83m 572
857 71:25 6,16m 604
859 71:35 6,23m 611
860 71:40 6,24m 612
861 71:45 6,25m 613
862 71:50 6,13m 601
863 71:55 6,20m 608
865 72:05 6,43m 631
866 72:10 6,48m 635
867 72:15 6,59m 646
868 72:20 6,56m 643
869 72:25 6,64m 651
871 72:35 6,59m 646
872 72:40 6,59m 646
873 72:45 6,36m 624
874 72:50 6,30m 618
875 72:55 6,49m 636
877 73:05 6,49m 636
878 73:10 6,87m 674
879 73:15 6,92m 679
880 73:20 6,80m 667
881 73:25 6,59m 646
883 73:35 6,60m 647
884 73:40 6,65m 652
885 73:45 6,64m 651
886 73:50 6,64m 651
887 73:55 6,74m 661
889 74:05 6,74m 661
890 74:10 6,59m 646
891 74:15 6,57m 644
892 74:20 6,49m 636
893 74:25 6,59m 646
895 74:35 6,52m 639
896 74:40 6,37m 625
897 74:45 6,49m 636
898 74:50 6,24m 612
899 74:55 6,14m 602
901 75:05 6,24m 612
902 75:10 6,47m 634
903 75:15 6,83m 670
904 75:20 6,73m 660
905 75:25 6,57m 644
907 75:35 6,59m 646
908 75:40 6,48m 635
909 75:45 6,72m 659
910 75:50 6,70m 657
911 75:55 6,69m 656
913 76:05 6,57m 644
914 76:10 6,60m 647
915 76:15 6,58m 645
916 76:20 6,58m 645
917 76:25 6,57m 644
919 76:35 6,95m 682
920 76:40 6,93m 680
921 76:45 6,65m 652
922 76:50 6,74m 661
923 76:55 6,57m 644
925 77:05 6,68m 655
926 77:10 6,93m 680
927 77:15 6,97m 684
928 77:20 6,80m 667
929 77:25 6,63m 650
931 77:35 5,99m 587
932 77:40 5,87m 576
933 77:45 5,85m 574
934 77:50 5,62m 551
935 77:55 5,77m 566
937 78:05 5,57m 546
938 78:10 5,41m 531
939 78:15 5,51m 540
940 78:20 5,38m 528
941 78:25 5,34m 524
943 78:35 4,55m 446
944 78:40 4,48m 439
945 78:45 4,45m 436
946 78:50 4,45m 436
947 78:55 4,62m 453
949 79:05 4,42m 433
950 79:10 4,32m 424
951 79:15 4,49m 440
952 79:20 4,53m 444
953 79:25 4,58m 449
955 79:35 4,68m 459
956 79:40 4,66m 457
957 79:45 4,79m 470
958 79:50 4,61m 452
959 79:55 4,33m 425
961 80:05 3,76m 369
962 80:10 3,65m 358
963 80:15 3,71m 364
964 80:20 3,68m 361
965 80:25 3,79m 372
967 80:35 3,99m 391
968 80:40 3,98m 390
969 80:45 4,11m 403
970 80:50 4,72m 463
971 80:55 4,38m 430
973 81:05 4,01m 393
974 81:10 3,82m 375
975 81:15 4,18m 410
976 81:20 4,69m 460
977 81:25 4,08m 400
979 81:35 3,11m 305
980 81:40 3,17m 311
981 81:45 3,40m 333
982 81:50 3,59m 352
983 81:55 3,44m 337
985 82:05 3,21m 315
986 82:10 3,44m 337
987 82:15 3,66m 359
988 82:20 3,86m 379
989 82:25 3,82m 375
991 82:35 3,77m 370
992 82:40 3,73m 366
993 82:45 3,79m 372
994 82:50 3,86m 379
995 82:55 3,85m 378
997 83:05 3,55m 348
998 83:10 3,54m 347
999 83:15 3,24m 318
1183 98:35 0,77m 76
1203 100:15 0,03m 3
1204 100:20 0,03m 3
1205 100:25 0,02m 2
1207 100:35 0,03m 3
1211 100:55 0,04m 4
1213 101:05 0,02m 2
1214 101:10 0,03m 3
1215 101:15 0,02m 2
1216 101:20 0,03m 3
1217 101:25 0,02m 2
1219 101:35 0,04m 4
1220 101:40 0,01m 1
1221 101:45 0,03m 3
1222 101:50 0,02m 2
1223 101:55 0,03m 3
1225 102:05 0,03m 3
1226 102:10 0,03m 3
1227 102:15 0,03m 3
1228 102:20 0,02m 2
1229 102:25 0,03m 3
1231 102:35 0,02m 2
1232 102:40 0,04m 4
1233 102:45 0,03m 3
1234 102:50 0,03m 3
1235 102:55 0,03m 3
1237 103:05 0,03m 3
1238 103:10 0,02m 2
1239 103:15 0,03m 3
1240 103:20 0,04m 4
1241 103:25 0,02m 2
1243 103:35 0,02m 2
1244 103:40 0,03m 3
1245 103:45 0,02m 2
1246 103:50 0,02m 2
1247 103:55 0,03m 3
1249 104:05 0,02m 2
1250 104:10 0,03m 3
1251 104:15 0,03m 3
1252 104:20 0,04m 4
1253 104:25 0,03m 3
1255 104:35 0,02m 2
1256 104:40 0,04m 4
1257 104:45 0,03m 3
1258 104:50 0,03m 3
1259 104:55 0,03m 3
Home: http://www.angermayr.eu
email: ostctools@angermayr.eu
[DF]
Thanks, didn't know you could do that.
I cut out the interesting 10 minutes and highlighted the wierd NDL:s
Pretty weird
Pretty weird
I'm not surprised the NDL drops to zero when switching to a setpoint of 0,5 (an OC mix of 10/62) in 38m. Switching back to 1.30 should give you the initial NDL after some minutes, of course. I'll have a look.
Hi DF,
Even you can do that, using OSTCTools.
OSTCProfile, load the profile you'd like to inspect,
rightmousebuttonclick -> List.
[DF]
heinrichsweikamp Wrote:
> Hi,
> I'll have a look.
> Regards,
Problem is the initial NDL was wrong. I am pretty sure the NDL from 30m until 38m are way too high ranging from 72min NDL @ 30m to 37min @ 38m.
72minutes @ 30m should give me 25minutes of deco and 37min @ 38m should give me 22 minutes of deco. Even half the runtime at those depths are decompression dives and not within the No Decompression Limit. Switching the SP down and then up again made the deco calculations right, but before that they were way off.
Rob Wrote:
> Hi DF,
> inspect,
> Regards
> Rob
Okay, awesome!
It would be really cool if there was a way to see the SP changes on the graph too for the next version. And some way of showing the maximum amount from the deco debug values in the dive information window.
Nice software!
BTW, it was the DPI setting that caused the text to be partially hidden.
> Hi,
> I'll have a look.
> Regards,
Rob Wrote:
> Hi DF,
> inspect,
> Regards
> Rob
Okay, awesome!
Nice software!
My guess is that your start Diluent was not set (There must be a * behind it).
I'd recommend to reset the Gases and CFs using the reset menu and setup your CCR configuration from scratch.
It's not a general issue, we made a lot of tests and real dives and the NDL are comparable to the 2.50 over the full range of setpoints (Incl. 0,5). Put your unit in the simulator next to a 2.50, you won't see more then minute off.
[DF]
> Hi,
> scratch.
> Regards,
It is an * in front of it and it showed the correct diluent both on the surface menu and in the water. It is part of my predive checklist and i am very sure it was the correct diluent.
It also shows in the log:
Gas 1: 12/62
Gas 2: 10/70
Gas 3: 15/55
Gas 4: 21/35
Gas 5: 20/20
Gas 6: 17/45
However, if any of the other diluents or, for that sake, any of the OC gasses except pure O2 was activated the NDL:s would not be as long as they were. It is simply wrong; you cannot get an NDL of 72 minutes at 30 meters using any gas! You have to agree with that.
> Hi,
> scratch.
> Regards,
Gas 1: 12/62
Gas 2: 10/70
Gas 3: 15/55
Gas 4: 21/35
Gas 5: 20/20
Gas 6: 17/45
[DF]
Hm, I reset as you suggested and then uploaded a previously saved configuration file with OSTC tools. The same config file i used to set it up when i got all the errors.
Simulation now shows proper NDL:s.
Why wrong the first time and then correct the next?
From which version did you upgrade to the 2.70?
[DF]
2.65 beta
Then there were no problems. Just all gasses logged wrong, thinking i was breathing air, but the NDL and deco was fine.
