Lost USB Connection
CHS
Lost USB Connection
Post by CHS »
since yesterday I have the following problem. I can not connect my OSTC 2 (v2,70) via USB. The OSTC works fine, loading via USB is no problem but I can not connect with the PC neither with the diving log software I use nor the bootloader. I tried several combinations of cabeles an PCs.
Any clue?
Christoph
OSTC 2N 6199
Re: Lost USB Connection
There is no magic trick here, if can rule out the cable and driver, it's a contact issue.
Such issues are linked to corrosion on the bulkhead pins, most likely. Can you have a look at the pins and carefully clean them (With WD40, for example) if necessary?
CHS
Post by CHS »
I wonder about this as the OSTC is quite new and I did no dives between working and not.
Christoph
OSTC 2N 6199
Which model is it?
CHS
Post by CHS »
It's a 2N. I will check the contacts this evening.
Christoph
OSTC 2N 6199
Post by scubatinoo »
Christoph, did you plug anything else to your USB? Is the battery symbol changing its color when plugged in?
My OSTC is charging but not connecting when plugged to an USB-Hub, for example. I have to connect it directely to an USB-Port on my Computer, but i guess this is an Hardware issue from my computer...
You'll need a cable with a small head. When the cable is not fully inserted the unit may charge but the actual data lines are not connected yet. If you email us info@heinrichsweikamp.com we'll put a compatible cable for you in the mail today.
CHS
Post by CHS »
@scubatinoo:
I tried several cabels and changed USB Ports (hub and directly) I also tried it on my notebook and the PC on work. The bat symbol changes it's colour but no connection to the software.
@Matthias:
email is on it's way - thank you.
Christoph
OSTC 2N 6199
Christoph, i think it's a driver problem. Did you try to install the "original" drivers from http://www.ftdichip.com/Drivers/VCP.htm ?
CHS
Post by CHS »
...back again. Meanwhile I got the new USB cable, thanks Matthias, checked everything. reinstalled drivers - nothing.
The OSTC is loading but not recognised by the PC - any further comments or ideas?
Christoph
OSTC 2N 6199
Hi Christoph,
Please send in the unit for a check. So we can rule out (or confirm) the issue with the 2N itself.
CHS
Post by CHS »
will send in the 2N on wednesday next week.
Christoph
OSTC 2N 6199
