Strange NDL on 2 dives today V2.70
daviesjez
OK, some very strange behavour on my MK2, today running V2.70. Please advise as to what i have missed in the update ( note, i only ever update to stable revisions)
I mimic my hardwired Predator, with all settings with the exception of just lowering SP1 to 1.25, so 2 dives today:
Both dives shallow, 25m
Both 63 min each
Dil 18/42
Shearwater sp 1.3, OSTC 1.25
both set to use GF CC with 30/75
On both dives, the OSTC was showing 20 mins additioanl NDL from the shearwater UNTIL the shearwater dipped into deco and then the OSTC started matching the deco to the minute... This scenario occured on both dives. NDL on the OSTC went straight from 20 mins to 1 min deco.
Has anyone else seen this situation before, or have have i missed a CF setting
Any help appreciated
Jez
Both 63 min each
Dil 18/42
Jez
Re: Strange NDL on 2 dives today V2.70
"First" SP properly set in the "CCR Setup" Menu? When updating from a beta version between 2.50 and 2.70 the setting of the "first" SP was not transferred properly. Look here: read.php?2,11884,11895#msg-11895
daviesjez
Hi Matthias
Yes, the first sp is set correctly ( and was displaying 1.25 throughout the dive)
I only ever jump between stable versions so no beta was ever installed.
Its just very strange that once deco obligation is started, it corrects itself.
I am going to back up the CF's tonight, and do a CF and deco reset and then restore the settings. I am diving again on next weekend so will try again, unless you have any other suggestions
Jez
Jez
daviesjez
Well Yesterday's dive....
after performing what was said in my previous post....
total dive 34 mtrs for 64 min. Again, identical settings with the 1 exception of 1.25 set point set on the OSTC and 1.3 on the shearwater.
with 1 min of NDL left on the shearwater, my OSTC said i had 10( which is strange as this is running a 1.25 fixed sp. VS a 1.3 on the shearwater), and then straight into deco ( showing 1 minute extra again the Shearwater which was as anticipated.)
So for some reason, the NDL does not seem to be mirroring the Predator within a reasonable margin. What have i set wrong?
Jez
Jez
[DF]
> read.php?2,11884
> ,11895#msg-11895
> Regards,
My problem was not that the first SP was transferred incorrectly either, mainly because I set it up manually after updating the firmware. I used to have 0.7 but after the update I set it to 0.5. That it started with 0.5 can also be seen in the profile data I pasted.
This is the third person reporting strange NDL:s after updating to 2.70, there is clearly a bug somewhere. It is also a quite serious bug that should be rooted out asap, as it shows the wrong NDL. I know people that use the OSTC as their primary and only computer and I am worried that they will not be aware that the NDL is wrong and overstay their bottom time. Not everyone is a technical diver and even if it shows the correct deco they may not have sufficient gas or training to perform the necessary stops. I hope you will look into this a bit more this time.
/ Daniel
> read.php?2,11884
> ,11895#msg-11895
> Regards,
/ Daniel
> NDL.
If it is a bug, then it affects only CC-Dives, not
OC-Dives! I did some dives with 2.70 and 2.71beta
without any problems! My OSTC everytime went earlier
into Deco-Mode than my Galileo... So everything was
like expected.
> NDL.
like expected.
We've used the 2.70 in quite a lot of CC dives ourselves BEFORE releasing it. We found no problem what so ever with the NDL. Please download the two dives with the OSTC Tools and post the .dive file here.
[DF]
> not
> earlier
> was
> like expected.
How do you know that? That is incorrect deduction, "I have no problems so no one has"
It is obviously not a general issue, if it was the firmware would never have been released, even as a beta. The HW guys are quite professional. It does not affect the majority off CC dives either, if it was a lot more error reports would have come in.
But it is a bug that under certain circumstances shows up. No one knows why, otherwise it would have been fixed. We report it since HW cannot possible test all variations and as all software manufacturers they rely on their customers giving feedback when something goes wrong.
For me, the problem was not that the SP was transferred incorrectly. It was not that the DIL setup was wrong either. Everything shows in the log I pasted that it was set up correctly but that the NDL,s were way off. If this can happen to three different persons it can happen to anyone and it must be fixed before someone gets hurt. That the absolute majority have not reported any issues does not help the person getting bent by probably the most serious error ever reported. The NDL,s must be showed correctly to everyone, not just most people.
I am happy that your update went as planned but I have confidence that HW will try to resolve why that is not so for everyone. Have fun and dive hard
/ DF
> not
> earlier
> was
> like expected.
/ DF
daviesjez
I will attmept to rip the profile data using OSTC tools tonight and post up.
A further update, dived last weekend, and again was 10 minutes adrift on NDL and then again hit deco on the Predator and the OSTC flipped into Deco mirroring within reason ( 1-2 mins more ). So that has now been 4 dives....
I am diving again this Saturday with my wife and i will set her OSTC back to previous stable version and keep mine on 2.70 and compare on the dive....
Jez
Jez
daviesjez
Ok dive 1:
( interesting at around 31 minutes )
Filename: 00531_21-07-2013_025m_063min
DiveFileversion: 100
LogBookProfileVersion: 33
DiveNumber: 531
Date of dive: 21/07/2013
Time at begin of dive: 08:52:00
Time at end of dive: 09:56:00
Maximum depth (mbar): 2519
Maximum depth (bar): 2.519
Divetime: 63min 11sec
Selected Gas at begin of dive (2): 18/42
Gas 1: 21/35
Gas 2: 18/42
Gas 3: 21/0
Gas 4: 21/0
Gas 5: 21/0
Gas 6: 21/35
Minimum water temperature: 16.3
Maximum water temperature from profile:19.4
Minimum water temperature from profile:16.4
Surface air pressure (mBar): 1021
Desaturation time after dive (min): 281
Maximum CNS (%): 33
Average depth: 2101 mbar
Total divetime: 4058 sec
Gradient Factor Low: 30%
Gradient Factor High: 75%
Decotype: ZH-L16-GF CC
Last decostep: 6m
Firmware version: 270
Battery voltage in mV after dive: 4.066
Salinity: 1.03
Sampling rate (sec): 10
Sampling divisor temperature: 6 information size 2
Sampling divisor deco/NDL: 6 information size 2
Sampling divisor gradientfactor: 6 information size 1
Sampling divisor ppO2 sensors: 0 information size 3
Sampling divisor deco debug: 0 information size 15
Sampling divisor CNS: 12 information size 1
Profile data
ProfileOffset: 258
Number of ProfileEntries: 405
Entry Time Depth mBar , Additional Info
1 0:10 5.13m 518 , SetPoint set to 125
2 0:20 7.40m 747
3 0:30 9.28m 937
4 0:40 12.74m 1287
5 0:50 16.78m 1695
6 1:00 20.06m 2026 , Temperature 194, Non Deko Limit 92min, Gradient factor 0
7 1:10 22.31m 2254
8 1:20 22.59m 2282
9 1:30 22.39m 2262
10 1:40 22.40m 2263
11 1:50 22.14m 2236
12 2:00 21.82m 2204 , Temperature 188, Non Deko Limit 44min, Gradient factor 0, CNS 1
13 2:10 21.69m 2191
14 2:20 21.64m 2186
15 2:30 22.07m 2229
16 2:40 22.07m 2229
17 2:50 22.50m 2273
18 3:00 22.62m 2285 , Temperature 183, Non Deko Limit 39min, Gradient factor 0
19 3:10 22.49m 2272
20 3:20 22.53m 2276
21 3:30 22.49m 2272
22 3:40 22.50m 2273
23 3:50 22.60m 2283
24 4:00 22.02m 2224 , Temperature 179, Non Deko Limit 40min, Gradient factor 0, CNS 2
25 4:10 21.85m 2207
26 4:20 21.67m 2189
27 4:30 21.83m 2205
28 4:40 21.99m 2221
29 4:50 22.09m 2231
30 5:00 22.30m 2252 , Temperature 176, Non Deko Limit 43min, Gradient factor 0
31 5:10 22.39m 2262
32 5:20 22.01m 2223
33 5:30 22.10m 2232
34 5:40 22.07m 2229
35 5:50 21.83m 2205
36 6:00 22.27m 2249 , Temperature 174, Non Deko Limit 42min, Gradient factor 0, CNS 3
37 6:10 21.85m 2207
38 6:20 21.91m 2213
39 6:30 21.83m 2205
40 6:40 21.95m 2217
41 6:50 21.93m 2215
42 7:00 21.96m 2218 , Temperature 172, Non Deko Limit 42min, Gradient factor 0
43 7:10 22.31m 2253
44 7:20 22.36m 2259
45 7:30 22.28m 2250
46 7:40 22.58m 2281
47 7:50 23.05m 2328
48 8:00 22.52m 2275 , Temperature 170, Non Deko Limit 36min, Gradient factor 0, CNS 4
49 8:10 22.75m 2298
50 8:20 22.73m 2296
51 8:30 22.90m 2313
52 8:40 23.01m 2324
53 8:50 23.95m 2419
54 9:00 23.27m 2350 , Temperature 169, Non Deko Limit 30min, Gradient factor 0
55 9:10 23.18m 2341
56 9:20 23.04m 2327
57 9:30 23.12m 2335
58 9:40 23.29m 2352
59 9:50 22.99m 2322
60 10:00 22.99m 2322 , Temperature 168, Non Deko Limit 34min, Gradient factor 0, CNS 5
61 10:10 23.04m 2327
62 10:20 22.78m 2301
63 10:30 22.73m 2296
64 10:40 22.91m 2314
65 10:50 22.74m 2297
66 11:00 22.76m 2299 , Temperature 167, Non Deko Limit 36min, Gradient factor 0
67 11:10 22.85m 2308
68 11:20 23.03m 2326
69 11:30 23.00m 2323
70 11:40 22.66m 2289
71 11:50 22.55m 2278
72 12:00 22.69m 2292 , Temperature 166, Non Deko Limit 37min, Gradient factor 0, CNS 6
73 12:10 22.59m 2282
74 12:20 22.65m 2288
75 12:30 22.71m 2294
76 12:40 22.71m 2294
77 12:50 22.57m 2280
78 13:00 22.82m 2305 , Temperature 166, Non Deko Limit 36min, Gradient factor 0
79 13:10 22.94m 2317
80 13:20 23.37m 2361
81 13:30 23.93m 2417
82 13:40 24.03m 2427
83 13:50 24.16m 2440
84 14:00 24.37m 2462 , Temperature 165, Non Deko Limit 27min, Gradient factor 0, CNS 7
85 14:10 24.62m 2487
86 14:20 24.73m 2498
87 14:30 24.61m 2486
88 14:40 24.75m 2500
89 14:50 24.62m 2487
90 15:00 24.81m 2506 , Temperature 165, Non Deko Limit 24min, Gradient factor 0
91 15:10 24.40m 2465
92 15:20 24.06m 2430
93 15:30 24.34m 2459
94 15:40 23.42m 2366
95 15:50 23.41m 2365
96 16:00 23.33m 2357 , Temperature 165, Non Deko Limit 31min, Gradient factor 0, CNS 8
97 16:10 23.54m 2378
98 16:20 23.49m 2373
99 16:30 23.47m 2371
100 16:40 23.67m 2391
101 16:50 23.60m 2384
102 17:00 23.44m 2368 , Temperature 165, Non Deko Limit 30min, Gradient factor 0
103 17:10 23.61m 2385
104 17:20 23.52m 2376
105 17:30 23.57m 2381
106 17:40 23.52m 2376
107 17:50 23.27m 2350
108 18:00 23.39m 2363 , Temperature 164, Non Deko Limit 31min, Gradient factor 0, CNS 9
109 18:10 22.88m 2311
110 18:20 22.95m 2318
111 18:30 23.53m 2377
112 18:40 23.79m 2403
113 18:50 23.77m 2401
114 19:00 23.47m 2371 , Temperature 164, Non Deko Limit 29min, Gradient factor 0
115 19:10 22.76m 2299
116 19:20 23.18m 2341
117 19:30 23.24m 2347
118 19:40 23.81m 2405
119 19:50 23.54m 2378
120 20:00 23.85m 2409 , Temperature 164, Non Deko Limit 28min, Gradient factor 0, CNS 10
121 20:10 24.24m 2448
122 20:20 24.72m 2497
123 20:30 24.35m 2460
124 20:40 23.20m 2343
125 20:50 22.88m 2311
126 21:00 22.82m 2305 , Temperature 164, Non Deko Limit 33min, Gradient factor 0
127 21:10 22.74m 2297
128 21:20 22.67m 2290
129 21:30 22.51m 2274
130 21:40 22.13m 2235
131 21:50 22.49m 2272
132 22:00 21.88m 2210 , Temperature 164, Non Deko Limit 40min, Gradient factor 0, CNS 11
133 22:10 22.05m 2227
134 22:20 22.17m 2239
135 22:30 22.23m 2245
136 22:40 22.08m 2230
137 22:50 22.21m 2243
138 23:00 22.30m 2252 , Temperature 164, Non Deko Limit 38min, Gradient factor 0
139 23:10 22.18m 2240
140 23:20 22.55m 2278
141 23:30 22.38m 2261
142 23:40 22.36m 2259
143 23:50 22.35m 2258
144 24:00 22.18m 2240 , Temperature 164, Non Deko Limit 37min, Gradient factor 0, CNS 12
145 24:10 22.26m 2248
146 24:20 22.32m 2255
147 24:30 22.05m 2227
148 24:40 22.18m 2240
149 24:50 21.96m 2218
150 25:00 22.03m 2225 , Temperature 164, Non Deko Limit 40min, Gradient factor 0
151 25:10 22.19m 2241
152 25:20 22.32m 2255
153 25:30 22.53m 2276
154 25:40 22.42m 2265
155 25:50 22.36m 2259
156 26:00 22.31m 2254 , Temperature 164, Non Deko Limit 37min, Gradient factor 0, CNS 13
157 26:10 22.27m 2249
158 26:20 22.27m 2249
159 26:30 21.85m 2207
160 26:40 21.98m 2220
161 26:50 22.44m 2267
162 27:00 22.47m 2270 , Temperature 164, Non Deko Limit 35min, Gradient factor 0
163 27:10 23.46m 2370
164 27:20 23.61m 2385
165 27:30 23.44m 2368
166 27:40 23.60m 2384
167 27:50 23.50m 2374
168 28:00 23.44m 2368 , Temperature 164, Non Deko Limit 29min, Gradient factor 0, CNS 14
169 28:10 23.48m 2372
170 28:20 23.50m 2374
171 28:30 23.94m 2418
172 28:40 24.07m 2431
173 28:50 24.02m 2426
174 29:00 23.80m 2404 , Temperature 164, Non Deko Limit 25min, Gradient factor 0
175 29:10 23.96m 2420
176 29:20 23.94m 2418
177 29:30 24.60m 2485
178 29:40 24.75m 2500
179 29:50 24.74m 2499
180 30:00 24.75m 2500 , Temperature 164, Non Deko Limit 20min, Gradient factor 0, CNS 15
181 30:10 24.86m 2511
182 30:20 24.70m 2495
183 30:30 24.91m 2516
184 30:40 24.89m 2514
185 30:50 24.72m 2497
186 31:00 24.08m 2432 , Temperature 164, Non Deko Limit 20min, Gradient factor 0
187 31:10 24.18m 2442
188 31:20 24.03m 2427
189 31:30 24.08m 2432
190 31:40 24.22m 2446
191 31:50 23.99m 2423
192 32:00 24.03m 2427 , Temperature 164, Non Deko Limit 0min, Gradient factor 0, CNS 16
193 32:10 24.14m 2438
194 32:20 23.66m 2390
195 32:30 23.78m 2402
196 32:40 23.61m 2385
197 32:50 23.60m 2384
198 33:00 23.50m 2374 , Temperature 164, Non Deko Limit 0min, Gradient factor 0
199 33:10 23.68m 2392
200 33:20 23.87m 2411
201 33:30 23.81m 2405
202 33:40 23.47m 2371
203 33:50 22.91m 2314
204 34:00 22.52m 2275 , Temperature 164, Non Deko Limit 0min, Gradient factor 0, CNS 17
205 34:10 22.64m 2287
206 34:20 22.16m 2238
207 34:30 21.98m 2220
208 34:40 22.05m 2227
209 34:50 22.04m 2226
210 35:00 22.49m 2272 , Temperature 164, Non Deko Limit 0min, Gradient factor 0
211 35:10 22.70m 2293
212 35:20 22.86m 2309
213 35:30 22.60m 2283
214 35:40 22.82m 2305
215 35:50 22.86m 2309
216 36:00 22.88m 2311 , Temperature 164, Non Deko Limit 0min, Gradient factor 0, CNS 18
217 36:10 22.69m 2292
218 36:20 22.49m 2272
219 36:30 22.44m 2267
220 36:40 22.43m 2266
221 36:50 22.04m 2226
222 37:00 22.26m 2248 , Temperature 164, Non Deko Limit 0min, Gradient factor 0
223 37:10 22.47m 2270
224 37:20 22.64m 2287
225 37:30 22.63m 2286
226 37:40 22.60m 2283
227 37:50 22.51m 2274
228 38:00 22.55m 2278 , Temperature 164, Non Deko Limit 0min, Gradient factor 0, CNS 19
229 38:10 22.60m 2283
230 38:20 22.52m 2275
231 38:30 22.48m 2271
232 38:40 22.44m 2267
233 38:50 22.39m 2262
234 39:00 22.37m 2260 , Temperature 164, Non Deko Limit 0min, Gradient factor 0
235 39:10 22.53m 2276
236 39:20 22.45m 2268
237 39:30 22.51m 2274
238 39:40 22.61m 2284
239 39:50 22.63m 2286
240 40:00 22.59m 2282 , Temperature 164, Decostop at 6m 1min, Gradient factor 0, CNS 20
241 40:10 22.57m 2280
242 40:20 22.90m 2313
243 40:30 22.75m 2298
244 40:40 23.40m 2364
245 40:50 23.27m 2350
246 41:00 23.31m 2355 , Temperature 164, Decostop at 6m 1min, Gradient factor 0
247 41:10 23.26m 2349
248 41:20 23.56m 2380
249 41:30 23.70m 2394
250 41:40 23.96m 2420
251 41:50 24.32m 2457
252 42:00 23.88m 2412 , Temperature 164, Decostop at 6m 1min, Gradient factor 0, CNS 21
253 42:10 23.88m 2412
254 42:20 23.67m 2391
255 42:30 23.80m 2404
256 42:40 23.47m 2371
257 42:50 23.58m 2382
258 43:00 23.66m 2390 , Temperature 164, Decostop at 6m 1min, Gradient factor 0
259 43:10 23.61m 2385
260 43:20 23.68m 2392
261 43:30 23.60m 2384
262 43:40 23.51m 2375
263 43:50 23.41m 2365
264 44:00 23.26m 2349 , Temperature 164, Decostop at 6m 1min, Gradient factor 0, CNS 22
265 44:10 23.12m 2335
266 44:20 23.42m 2366
267 44:30 23.54m 2378
268 44:40 23.54m 2378
269 44:50 23.62m 2386
270 45:00 23.73m 2397 , Temperature 164, Decostop at 6m 2min, Gradient factor 0
271 45:10 23.72m 2396
272 45:20 23.77m 2401
273 45:30 23.62m 2386
274 45:40 23.59m 2383
275 45:50 23.33m 2357
276 46:00 22.91m 2314 , Temperature 164, Decostop at 6m 2min, Gradient factor 0, CNS 23
277 46:10 23.05m 2328
278 46:20 22.86m 2309
279 46:30 23.24m 2347
280 46:40 23.19m 2342
281 46:50 23.16m 2339
282 47:00 22.92m 2315 , Temperature 164, Decostop at 6m 2min, Gradient factor 0
283 47:10 23.06m 2329
284 47:20 23.26m 2349
285 47:30 23.23m 2346
286 47:40 23.51m 2375
287 47:50 23.61m 2385
288 48:00 23.79m 2403 , Temperature 164, Decostop at 6m 3min, Gradient factor 0, CNS 24
289 48:10 23.62m 2386
290 48:20 23.73m 2397
291 48:30 23.85m 2409
292 48:40 24.25m 2449
293 48:50 24.22m 2446
294 49:00 23.89m 2413 , Temperature 164, Decostop at 6m 3min, Gradient factor 0
295 49:10 23.58m 2382
296 49:20 23.41m 2365
297 49:30 23.51m 2375
298 49:40 23.91m 2415
299 49:50 23.85m 2409
300 50:00 23.68m 2392 , Temperature 164, Decostop at 6m 3min, Gradient factor 0, CNS 25
301 50:10 24.02m 2426
302 50:20 23.81m 2405
303 50:30 23.85m 2409
304 50:40 23.81m 2405
305 50:50 23.98m 2422
306 51:00 23.83m 2407 , Temperature 164, Decostop at 6m 4min, Gradient factor 0
307 51:10 23.44m 2368
308 51:20 23.30m 2353
309 51:30 23.32m 2356
310 51:40 23.27m 2350
311 51:50 23.30m 2353
312 52:00 23.37m 2361 , Temperature 164, Decostop at 6m 4min, Gradient factor 0, CNS 26
313 52:10 23.29m 2352
314 52:20 23.29m 2352
315 52:30 23.41m 2365
316 52:40 23.41m 2365
317 52:50 23.47m 2371
318 53:00 23.36m 2360 , Temperature 164, Decostop at 6m 4min, Gradient factor 0
319 53:10 23.32m 2356
320 53:20 23.37m 2361
321 53:30 23.42m 2366
322 53:40 23.16m 2339
323 53:50 23.11m 2334
324 54:00 22.45m 2268 , Temperature 164, Decostop at 6m 4min, Gradient factor 0, CNS 27
325 54:10 21.54m 2176
326 54:20 20.36m 2057
327 54:30 19.38m 1958
328 54:40 18.88m 1907
329 54:50 19.18m 1937
330 55:00 18.39m 1858 , Temperature 164, Decostop at 6m 4min, Gradient factor 0
331 55:10 17.17m 1734
332 55:20 15.89m 1605
333 55:30 14.93m 1508
334 55:40 14.14m 1428
335 55:50 12.85m 1298
336 56:00 12.33m 1245 , Temperature 165, Decostop at 6m 5min, Gradient factor 0, CNS 28
337 56:10 12.69m 1282
338 56:20 11.60m 1172
339 56:30 11.14m 1125
340 56:40 10.93m 1104
341 56:50 10.26m 1036
342 57:00 9.77m 987 , Temperature 165, Decostop at 6m 4min, Gradient factor 0
343 57:10 9.77m 987
344 57:20 9.95m 1005
345 57:30 8.86m 895
346 57:40 8.24m 832
347 57:50 8.13m 821
348 58:00 7.52m 760 , Temperature 165, Decostop at 6m 4min, Gradient factor 0, CNS 29
349 58:10 6.90m 697
350 58:20 6.97m 704
351 58:30 6.87m 694
352 58:40 6.30m 636
353 58:50 5.72m 578
354 59:00 6.16m 622 , Temperature 166, Decostop at 6m 3min, Gradient factor 4
355 59:10 6.45m 652
356 59:20 6.36m 642
357 59:30 5.85m 591
358 59:40 5.86m 592
359 59:50 5.78m 584
360 60:00 6.50m 657 , Temperature 166, Decostop at 6m 2min, Gradient factor 0, CNS 30
361 60:10 6.42m 648
362 60:20 6.27m 633
363 60:30 5.85m 591
364 60:40 6.01m 607
365 60:50 6.02m 608
366 61:00 5.94m 600 , Temperature 166, Decostop at 6m 1min, Gradient factor 0
367 61:10 5.92m 598
368 61:20 5.14m 519
369 61:30 4.41m 445
370 61:40 4.23m 427
371 61:50 4.22m 426
372 62:00 3.40m 343 , Temperature 165, Non Deko Limit 240min, Gradient factor 29, CNS 31
373 62:10 2.30m 232
374 62:20 1.09m 110
375 62:30 0.14m 14
376 62:40 0.47m 47
377 62:50 0.29m 29
378 63:00 0.32m 32 , Temperature 166, Non Deko Limit 240min, Gradient factor 66
379 63:10 0.43m 43
380 63:20 0.11m 11
381 63:30 0.25m 25
382 63:40 0.14m 14
383 63:50 0.01m 1
384 64:00 0.00m 0 , Temperature 166, Non Deko Limit 240min, Gradient factor 69, CNS 32
385 64:10 0.00m 0
386 64:20 0.01m 1
387 64:30 0.01m 1
388 64:40 0.02m 2
389 64:50 0.02m 2
390 65:00 0.00m 0 , Temperature 167, Non Deko Limit 240min, Gradient factor 66
391 65:10 0.03m 3
392 65:20 0.02m 2
393 65:30 0.00m 0
394 65:40 0.02m 2
395 65:50 0.01m 1
396 66:00 0.01m 1 , Temperature 169, Non Deko Limit 240min, Gradient factor 62, CNS 32
397 66:10 0.02m 2
398 66:20 0.01m 1
399 66:30 0.01m 1
400 66:40 0.02m 2
401 66:50 0.00m 0
402 67:00 0.01m 1 , Temperature 172, Non Deko Limit 240min, Gradient factor 59
403 67:10 0.01m 1
404 67:20 0.01m 1
405 67:30 0.00m 0
DiveNumber: 531
Gas 1: 21/35
Gas 2: 18/42
Gas 3: 21/0
Gas 4: 21/0
Gas 5: 21/0
Gas 6: 21/35
Maximum CNS (%): 33
Last decostep: 6m
Salinity: 1.03
Profile data
ProfileOffset: 258
2 0:20 7.40m 747
3 0:30 9.28m 937
4 0:40 12.74m 1287
5 0:50 16.78m 1695
7 1:10 22.31m 2254
8 1:20 22.59m 2282
9 1:30 22.39m 2262
10 1:40 22.40m 2263
11 1:50 22.14m 2236
13 2:10 21.69m 2191
14 2:20 21.64m 2186
15 2:30 22.07m 2229
16 2:40 22.07m 2229
17 2:50 22.50m 2273
19 3:10 22.49m 2272
20 3:20 22.53m 2276
21 3:30 22.49m 2272
22 3:40 22.50m 2273
23 3:50 22.60m 2283
25 4:10 21.85m 2207
26 4:20 21.67m 2189
27 4:30 21.83m 2205
28 4:40 21.99m 2221
29 4:50 22.09m 2231
31 5:10 22.39m 2262
32 5:20 22.01m 2223
33 5:30 22.10m 2232
34 5:40 22.07m 2229
35 5:50 21.83m 2205
37 6:10 21.85m 2207
38 6:20 21.91m 2213
39 6:30 21.83m 2205
40 6:40 21.95m 2217
41 6:50 21.93m 2215
43 7:10 22.31m 2253
44 7:20 22.36m 2259
45 7:30 22.28m 2250
46 7:40 22.58m 2281
47 7:50 23.05m 2328
49 8:10 22.75m 2298
50 8:20 22.73m 2296
51 8:30 22.90m 2313
52 8:40 23.01m 2324
53 8:50 23.95m 2419
55 9:10 23.18m 2341
56 9:20 23.04m 2327
57 9:30 23.12m 2335
58 9:40 23.29m 2352
59 9:50 22.99m 2322
343 57:10 9.77m 987
345 57:30 8.86m 895
346 57:40 8.24m 832
347 57:50 8.13m 821
349 58:10 6.90m 697
350 58:20 6.97m 704
351 58:30 6.87m 694
352 58:40 6.30m 636
353 58:50 5.72m 578
355 59:10 6.45m 652
356 59:20 6.36m 642
357 59:30 5.85m 591
358 59:40 5.86m 592
359 59:50 5.78m 584
361 60:10 6.42m 648
362 60:20 6.27m 633
363 60:30 5.85m 591
364 60:40 6.01m 607
365 60:50 6.02m 608
367 61:10 5.92m 598
368 61:20 5.14m 519
369 61:30 4.41m 445
370 61:40 4.23m 427
371 61:50 4.22m 426
373 62:10 2.30m 232
374 62:20 1.09m 110
375 62:30 0.14m 14
376 62:40 0.47m 47
377 62:50 0.29m 29
379 63:10 0.43m 43
380 63:20 0.11m 11
381 63:30 0.25m 25
382 63:40 0.14m 14
383 63:50 0.01m 1
385 64:10 0.00m 0
386 64:20 0.01m 1
387 64:30 0.01m 1
388 64:40 0.02m 2
389 64:50 0.02m 2
391 65:10 0.03m 3
392 65:20 0.02m 2
393 65:30 0.00m 0
394 65:40 0.02m 2
395 65:50 0.01m 1
397 66:10 0.02m 2
398 66:20 0.01m 1
399 66:30 0.01m 1
400 66:40 0.02m 2
401 66:50 0.00m 0
403 67:10 0.01m 1
404 67:20 0.01m 1
405 67:30 0.00m 0
daviesjez
And dive 2...
again interesting at around 35 mins....
Filename: 00532_21-07-2013_024m_061min
DiveNumber: 532
Time at begin of dive: 14:26:00
Time at end of dive: 15:28:00
Maximum depth (mbar): 2435
Maximum depth (bar): 2.435
Divetime: 61min 15sec
Gas 1: 21/35
Gas 2: 18/42
Gas 3: 21/0
Gas 4: 21/0
Gas 5: 21/0
Gas 6: 21/35
Minimum water temperature: 16.2
Maximum water temperature from profile:20.1
Minimum water temperature from profile:16.2
Surface air pressure (mBar): 1020
Desaturation time after dive (min): 427
Maximum CNS (%): 37
Average depth: 2024 mbar
Total divetime: 3995 sec
Last decostep: 6m
Battery voltage in mV after dive: 4.057
Salinity: 1.03
Profile data
ProfileOffset: 258
Number of ProfileEntries: 399
1 0:10 5.06m 511 , SetPoint set to 125
2 0:20 7.54m 762
3 0:30 9.64m 974
4 0:40 11.63m 1175
5 0:50 11.91m 1203
6 1:00 11.55m 1167 , Temperature 201, Non Deko Limit 240min, Gradient factor 0
7 1:10 11.47m 1159
8 1:20 11.47m 1159
9 1:30 11.17m 1128
10 1:40 11.07m 1118
11 1:50 11.65m 1177
12 2:00 13.39m 1352 , Temperature 193, Non Deko Limit 240min, Gradient factor 0, CNS 6
13 2:10 15.35m 1550
14 2:20 17.24m 1741
15 2:30 18.88m 1907
16 2:40 20.23m 2043
17 2:50 20.39m 2060
18 3:00 20.28m 2048 , Temperature 186, Non Deko Limit 66min, Gradient factor 0
19 3:10 20.38m 2059
20 3:20 20.32m 2052
21 3:30 20.19m 2039
22 3:40 20.49m 2070
23 3:50 20.64m 2085
24 4:00 21.56m 2178 , Temperature 181, Non Deko Limit 55min, Gradient factor 0, CNS 7
25 4:10 22.10m 2232
26 4:20 22.54m 2277
27 4:30 23.15m 2338
28 4:40 23.30m 2354
29 4:50 23.39m 2363
30 5:00 23.54m 2378 , Temperature 177, Non Deko Limit 32min, Gradient factor 0
31 5:10 23.50m 2374
32 5:20 23.21m 2344
33 5:30 23.35m 2359
34 5:40 23.54m 2378
35 5:50 23.59m 2383
36 6:00 23.01m 2324 , Temperature 174, Non Deko Limit 36min, Gradient factor 0, CNS 8
37 6:10 22.99m 2322
38 6:20 22.88m 2311
39 6:30 22.78m 2301
40 6:40 22.78m 2301
41 6:50 22.68m 2291
42 7:00 22.64m 2287 , Temperature 172, Non Deko Limit 37min, Gradient factor 0
43 7:10 22.38m 2261
44 7:20 22.09m 2231
45 7:30 22.04m 2226
46 7:40 22.06m 2228
47 7:50 22.16m 2238
48 8:00 22.99m 2322 , Temperature 170, Non Deko Limit 38min, Gradient factor 0, CNS 9
49 8:10 23.17m 2340
50 8:20 23.17m 2340
51 8:30 23.54m 2378
52 8:40 23.41m 2365
53 8:50 23.18m 2341
54 9:00 23.02m 2325 , Temperature 168, Non Deko Limit 34min, Gradient factor 0
55 9:10 23.33m 2357
56 9:20 23.10m 2333
57 9:30 22.89m 2312
58 9:40 22.02m 2224
59 9:50 21.95m 2217
60 10:00 21.27m 2148 , Temperature 167, Non Deko Limit 47min, Gradient factor 0, CNS 10
61 10:10 20.71m 2092
62 10:20 20.81m 2102
63 10:30 20.79m 2100
64 10:40 20.79m 2100
65 10:50 20.91m 2112
66 11:00 20.86m 2107 , Temperature 166, Non Deko Limit 56min, Gradient factor 0
67 11:10 20.72m 2093
68 11:20 20.68m 2089
69 11:30 20.98m 2119
70 11:40 21.01m 2122
71 11:50 21.21m 2142
72 12:00 21.47m 2169 , Temperature 165, Non Deko Limit 50min, Gradient factor 0, CNS 11
73 12:10 21.81m 2203
74 12:20 21.83m 2205
75 12:30 22.20m 2242
76 12:40 22.58m 2281
77 12:50 22.76m 2299
78 13:00 23.16m 2339 , Temperature 165, Non Deko Limit 35min, Gradient factor 0
79 13:10 23.55m 2379
80 13:20 23.65m 2389
81 13:30 23.26m 2349
82 13:40 23.23m 2346
83 13:50 23.92m 2416
84 14:00 23.72m 2396 , Temperature 164, Non Deko Limit 30min, Gradient factor 0, CNS 12
85 14:10 23.88m 2412
86 14:20 23.60m 2384
87 14:30 23.58m 2382
88 14:40 23.45m 2369
89 14:50 23.02m 2325
90 15:00 23.60m 2384 , Temperature 164, Non Deko Limit 30min, Gradient factor 0
91 15:10 23.25m 2348
92 15:20 23.33m 2357
93 15:30 23.66m 2390
94 15:40 24.16m 2440
95 15:50 24.11m 2435
96 16:00 24.15m 2439 , Temperature 163, Non Deko Limit 27min, Gradient factor 0, CNS 13
97 16:10 24.06m 2430
98 16:20 24.21m 2445
99 16:30 24.13m 2437
100 16:40 24.13m 2437
101 16:50 24.22m 2446
102 17:00 23.68m 2392 , Temperature 163, Non Deko Limit 28min, Gradient factor 0
103 17:10 23.26m 2349
104 17:20 23.60m 2384
105 17:30 23.13m 2336
106 17:40 22.93m 2316
107 17:50 23.19m 2342
108 18:00 23.14m 2337 , Temperature 163, Non Deko Limit 31min, Gradient factor 0, CNS 14
109 18:10 22.98m 2321
111 18:30 23.02m 2325
112 18:40 22.93m 2316
113 18:50 22.68m 2291
114 19:00 22.39m 2262 , Temperature 163, Non Deko Limit 36min, Gradient factor 0
115 19:10 22.44m 2267
116 19:20 22.25m 2247
117 19:30 22.19m 2241
118 19:40 22.16m 2238
119 19:50 22.19m 2241
120 20:00 22.02m 2224 , Temperature 163, Non Deko Limit 40min, Gradient factor 0, CNS 15
121 20:10 21.75m 2197
122 20:20 21.61m 2183
123 20:30 21.69m 2191
124 20:40 21.92m 2214
125 20:50 22.40m 2263
126 21:00 22.69m 2292 , Temperature 163, Non Deko Limit 36min, Gradient factor 0
127 21:10 22.70m 2293
128 21:20 22.61m 2284
129 21:30 22.88m 2311
130 21:40 22.90m 2313
131 21:50 22.72m 2295
132 22:00 22.51m 2274 , Temperature 163, Non Deko Limit 35min, Gradient factor 0, CNS 16
133 22:10 22.55m 2278
134 22:20 22.54m 2277
135 22:30 22.55m 2278
136 22:40 22.67m 2290
137 22:50 22.47m 2270
138 23:00 22.42m 2265 , Temperature 163, Non Deko Limit 36min, Gradient factor 0
139 23:10 22.59m 2282
140 23:20 22.78m 2301
141 23:30 22.68m 2291
142 23:40 22.77m 2300
143 23:50 23.27m 2350
144 24:00 22.82m 2305 , Temperature 163, Non Deko Limit 32min, Gradient factor 0, CNS 17
145 24:10 22.83m 2306
146 24:20 22.51m 2274
147 24:30 22.49m 2272
148 24:40 22.76m 2299
149 24:50 23.11m 2334
150 25:00 22.90m 2313 , Temperature 162, Non Deko Limit 33min, Gradient factor 0
151 25:10 22.79m 2302
152 25:20 22.86m 2309
153 25:30 22.74m 2297
154 25:40 22.92m 2315
155 25:50 22.98m 2321
156 26:00 22.87m 2310 , Temperature 162, Non Deko Limit 33min, Gradient factor 0, CNS 18
157 26:10 22.85m 2308
158 26:20 22.81m 2304
159 26:30 22.96m 2319
160 26:40 23.00m 2323
161 26:50 23.07m 2330
162 27:00 23.06m 2329 , Temperature 162, Non Deko Limit 32min, Gradient factor 0
163 27:10 23.19m 2342
164 27:20 23.05m 2328
165 27:30 22.92m 2315
166 27:40 22.52m 2275
167 27:50 21.83m 2205
168 28:00 22.34m 2257 , Temperature 162, Non Deko Limit 37min, Gradient factor 0, CNS 19
169 28:10 22.89m 2312
170 28:20 23.12m 2335
171 28:30 23.27m 2350
172 28:40 23.39m 2363
173 28:50 23.36m 2360
174 29:00 23.39m 2363 , Temperature 162, Non Deko Limit 30min, Gradient factor 0
175 29:10 23.80m 2404
176 29:20 23.95m 2419
177 29:30 23.67m 2391
178 29:40 23.70m 2394
179 29:50 23.55m 2379
180 30:00 23.30m 2353 , Temperature 162, Non Deko Limit 30min, Gradient factor 0, CNS 20
181 30:10 23.50m 2374
182 30:20 23.45m 2369
183 30:30 23.46m 2370
184 30:40 23.81m 2405
185 30:50 23.78m 2402
186 31:00 23.57m 2381 , Temperature 162, Non Deko Limit 27min, Gradient factor 0
187 31:10 23.69m 2393
188 31:20 23.61m 2385
189 31:30 23.59m 2383
190 31:40 23.62m 2386
191 31:50 23.70m 2394
192 32:00 23.59m 2383 , Temperature 162, Non Deko Limit 26min, Gradient factor 0, CNS 21
193 32:10 23.34m 2358
194 32:20 23.12m 2335
195 32:30 23.06m 2329
196 32:40 23.44m 2368
197 32:50 23.49m 2373
198 33:00 23.82m 2406 , Temperature 162, Non Deko Limit 24min, Gradient factor 0
199 33:10 23.67m 2391
200 33:20 23.60m 2384
201 33:30 24.06m 2430
202 33:40 23.84m 2408
203 33:50 23.85m 2409
204 34:00 23.55m 2379 , Temperature 162, Non Deko Limit 24min, Gradient factor 0, CNS 22
205 34:10 23.94m 2418
206 34:20 23.72m 2396
207 34:30 24.17m 2441
208 34:40 23.85m 2409
209 34:50 23.73m 2397
210 35:00 23.75m 2399 , Temperature 162, Non Deko Limit 0min, Gradient factor 0
211 35:10 23.40m 2364
212 35:20 23.52m 2376
213 35:30 23.58m 2382
214 35:40 24.03m 2427
215 35:50 23.78m 2402
216 36:00 23.78m 2402 , Temperature 162, Non Deko Limit 0min, Gradient factor 0, CNS 23
217 36:10 23.81m 2405
218 36:20 23.72m 2396
219 36:30 23.82m 2406
220 36:40 23.43m 2367
221 36:50 23.38m 2362
222 37:00 23.28m 2351 , Temperature 162, Non Deko Limit 0min, Gradient factor 0
223 37:10 23.79m 2403
224 37:20 23.60m 2384
225 37:30 23.85m 2409
226 37:40 23.72m 2396
227 37:50 23.83m 2407
228 38:00 23.80m 2404 , Temperature 162, Non Deko Limit 0min, Gradient factor 0, CNS 24
229 38:10 23.76m 2400
230 38:20 23.71m 2395
231 38:30 23.71m 2395
232 38:40 23.47m 2371
233 38:50 23.07m 2330
234 39:00 22.78m 2301 , Temperature 162, Non Deko Limit 0min, Gradient factor 0
235 39:10 22.83m 2306
236 39:20 22.84m 2307
237 39:30 22.68m 2291
238 39:40 22.83m 2306
239 39:50 22.81m 2304
240 40:00 22.86m 2309 , Temperature 162, Non Deko Limit 0min, Gradient factor 0, CNS 25
241 40:10 22.97m 2320
242 40:20 23.07m 2330
243 40:30 22.98m 2321
244 40:40 22.87m 2310
245 40:50 22.78m 2301
246 41:00 22.89m 2312 , Temperature 162, Decostop at 6m 1min, Gradient factor 0
247 41:10 22.76m 2299
248 41:20 22.76m 2299
249 41:30 22.78m 2301
250 41:40 22.76m 2299
251 41:50 22.84m 2307
252 42:00 22.59m 2282 , Temperature 162, Decostop at 6m 1min, Gradient factor 0, CNS 26
253 42:10 22.18m 2240
254 42:20 22.23m 2245
255 42:30 22.62m 2285
256 42:40 22.96m 2319
257 42:50 22.89m 2312
258 43:00 22.91m 2314 , Temperature 162, Decostop at 6m 1min, Gradient factor 0
259 43:10 22.67m 2290
260 43:20 22.77m 2300
261 43:30 22.64m 2287
262 43:40 22.56m 2279
263 43:50 23.26m 2349
264 44:00 22.80m 2303 , Temperature 162, Decostop at 6m 1min, Gradient factor 0, CNS 27
265 44:10 22.99m 2322
266 44:20 22.40m 2263
267 44:30 22.30m 2252
268 44:40 22.18m 2240
269 44:50 21.79m 2201
270 45:00 21.52m 2174 , Temperature 162, Decostop at 6m 1min, Gradient factor 0
271 45:10 21.41m 2163
272 45:20 21.25m 2146
273 45:30 21.12m 2133
274 45:40 20.72m 2093
275 45:50 19.60m 1980
276 46:00 19.32m 1951 , Temperature 163, Decostop at 6m 1min, Gradient factor 0, CNS 28
277 46:10 19.84m 2004
278 46:20 19.98m 2018
279 46:30 20.52m 2073
280 46:40 21.02m 2123
281 46:50 20.66m 2087
282 47:00 20.66m 2087 , Temperature 162, Decostop at 6m 1min, Gradient factor 0
283 47:10 20.28m 2048
284 47:20 20.03m 2023
285 47:30 19.97m 2017
286 47:40 20.30m 2050
287 47:50 20.71m 2092
288 48:00 20.58m 2079 , Temperature 162, Decostop at 6m 2min, Gradient factor 0, CNS 29
289 48:10 20.24m 2044
290 48:20 20.67m 2088
291 48:30 20.89m 2110
292 48:40 20.95m 2116
293 48:50 21.24m 2145
294 49:00 20.80m 2101 , Temperature 162, Decostop at 6m 2min, Gradient factor 0
295 49:10 20.80m 2101
296 49:20 20.83m 2104
297 49:30 20.72m 2093
298 49:40 20.91m 2112
299 49:50 20.83m 2104
300 50:00 20.84m 2105 , Temperature 162, Decostop at 6m 2min, Gradient factor 0, CNS 30
301 50:10 21.03m 2124
302 50:20 20.99m 2120
303 50:30 21.04m 2125
304 50:40 20.86m 2107
305 50:50 21.07m 2128
306 51:00 21.06m 2127 , Temperature 162, Decostop at 6m 2min, Gradient factor 0
307 51:10 21.17m 2138
308 51:20 21.10m 2131
309 51:30 21.06m 2127
310 51:40 20.95m 2116
311 51:50 21.08m 2129
312 52:00 21.02m 2123 , Temperature 162, Decostop at 6m 2min, Gradient factor 0, CNS 31
313 52:10 21.16m 2137
314 52:20 20.44m 2065
315 52:30 20.48m 2069
316 52:40 20.47m 2068
317 52:50 19.71m 1991
318 53:00 19.18m 1937 , Temperature 163, Decostop at 6m 2min, Gradient factor 0
319 53:10 18.70m 1889
320 53:20 17.77m 1795
321 53:30 17.07m 1724
322 53:40 16.62m 1679
323 53:50 15.60m 1576
324 54:00 14.46m 1461 , Temperature 163, Decostop at 6m 2min, Gradient factor 0, CNS 32
325 54:10 14.45m 1460
326 54:20 13.53m 1367
327 54:30 13.05m 1318
328 54:40 12.83m 1296
329 54:50 12.50m 1263
330 55:00 12.02m 1214 , Temperature 163, Decostop at 6m 2min, Gradient factor 0
331 55:10 11.40m 1151
332 55:20 10.65m 1076
333 55:30 9.90m 1000
334 55:40 9.08m 917
335 55:50 8.72m 881
336 56:00 7.64m 772 , Temperature 164, Decostop at 6m 2min, Gradient factor 0, CNS 33
337 56:10 6.74m 681
338 56:20 7.30m 737
339 56:30 6.76m 683
340 56:40 6.60m 667
341 56:50 6.45m 651
342 57:00 6.34m 640 , Temperature 164, Decostop at 6m 1min, Gradient factor 0
343 57:10 6.45m 652
344 57:20 6.12m 618
345 57:30 6.37m 643
346 57:40 6.20m 626
347 57:50 5.89m 595
348 58:00 5.59m 565 , Temperature 164, Non Deko Limit 0min, Gradient factor 0, CNS 34
349 58:10 5.66m 572
350 58:20 5.46m 552
351 58:30 4.68m 473
352 58:40 4.42m 446
353 58:50 4.45m 449
354 59:00 4.57m 462 , Temperature 164, Non Deko Limit 240min, Gradient factor 10
355 59:10 4.28m 432
356 59:20 3.59m 363
357 59:30 3.38m 341
358 59:40 2.60m 263
359 59:50 2.08m 210
360 60:00 1.93m 195 , Temperature 164, Non Deko Limit 240min, Gradient factor 38, CNS 35
361 60:10 0.84m 85
362 60:20 0.19m 19
363 60:30 0.27m 27
364 60:40 0.38m 38
365 60:50 0.31m 31
366 61:00 0.25m 25 , Temperature 165, Non Deko Limit 240min, Gradient factor 62
367 61:10 0.30m 30
368 61:20 0.31m 31
369 61:30 0.34m 34
370 61:40 0.27m 27
371 61:50 0.26m 26
372 62:00 0.18m 18 , Temperature 165, Non Deko Limit 240min, Gradient factor 60, CNS 35
373 62:10 0.25m 25
374 62:20 0.41m 41
375 62:30 0.30m 30
376 62:40 0.14m 14
377 62:50 0.01m 1
378 63:00 0.00m 0 , Temperature 166, Non Deko Limit 240min, Gradient factor 60
379 63:10 0.00m 0
380 63:20 0.01m 1
381 63:30 0.01m 1
382 63:40 0.02m 2
383 63:50 0.02m 2
384 64:00 0.01m 1 , Temperature 167, Non Deko Limit 240min, Gradient factor 56, CNS 36
385 64:10 0.01m 1
386 64:20 0.01m 1
387 64:30 0.01m 1
388 64:40 0.00m 0
389 64:50 0.00m 0
390 65:00 0.00m 0 , Temperature 168, Non Deko Limit 240min, Gradient factor 53
391 65:10 0.01m 1
392 65:20 0.01m 1
393 65:30 0.01m 1
394 65:40 0.02m 2
395 65:50 0.01m 1
396 66:00 0.01m 1 , Temperature 171, Non Deko Limit 240min, Gradient factor 47, CNS 37
397 66:10 0.01m 1
398 66:20 0.01m 1
399 66:30 0.00m 0
DiveNumber: 532
Gas 1: 21/35
Gas 2: 18/42
Gas 3: 21/0
Gas 4: 21/0
Gas 5: 21/0
Gas 6: 21/35
Maximum CNS (%): 37
Last decostep: 6m
Salinity: 1.03
Profile data
ProfileOffset: 258
2 0:20 7.54m 762
3 0:30 9.64m 974
4 0:40 11.63m 1175
5 0:50 11.91m 1203
7 1:10 11.47m 1159
8 1:20 11.47m 1159
9 1:30 11.17m 1128
10 1:40 11.07m 1118
11 1:50 11.65m 1177
13 2:10 15.35m 1550
14 2:20 17.24m 1741
15 2:30 18.88m 1907
16 2:40 20.23m 2043
17 2:50 20.39m 2060
19 3:10 20.38m 2059
20 3:20 20.32m 2052
21 3:30 20.19m 2039
22 3:40 20.49m 2070
23 3:50 20.64m 2085
25 4:10 22.10m 2232
26 4:20 22.54m 2277
27 4:30 23.15m 2338
28 4:40 23.30m 2354
29 4:50 23.39m 2363
31 5:10 23.50m 2374
32 5:20 23.21m 2344
33 5:30 23.35m 2359
34 5:40 23.54m 2378
35 5:50 23.59m 2383
37 6:10 22.99m 2322
38 6:20 22.88m 2311
39 6:30 22.78m 2301
40 6:40 22.78m 2301
41 6:50 22.68m 2291
43 7:10 22.38m 2261
44 7:20 22.09m 2231
45 7:30 22.04m 2226
46 7:40 22.06m 2228
47 7:50 22.16m 2238
49 8:10 23.17m 2340
50 8:20 23.17m 2340
51 8:30 23.54m 2378
52 8:40 23.41m 2365
53 8:50 23.18m 2341
55 9:10 23.33m 2357
56 9:20 23.10m 2333
57 9:30 22.89m 2312
58 9:40 22.02m 2224
59 9:50 21.95m 2217
334 55:40 9.08m 917
335 55:50 8.72m 881
337 56:10 6.74m 681
338 56:20 7.30m 737
339 56:30 6.76m 683
340 56:40 6.60m 667
341 56:50 6.45m 651
343 57:10 6.45m 652
344 57:20 6.12m 618
345 57:30 6.37m 643
346 57:40 6.20m 626
347 57:50 5.89m 595
349 58:10 5.66m 572
350 58:20 5.46m 552
351 58:30 4.68m 473
352 58:40 4.42m 446
353 58:50 4.45m 449
355 59:10 4.28m 432
356 59:20 3.59m 363
357 59:30 3.38m 341
358 59:40 2.60m 263
359 59:50 2.08m 210
361 60:10 0.84m 85
362 60:20 0.19m 19
363 60:30 0.27m 27
364 60:40 0.38m 38
365 60:50 0.31m 31
367 61:10 0.30m 30
368 61:20 0.31m 31
369 61:30 0.34m 34
370 61:40 0.27m 27
371 61:50 0.26m 26
373 62:10 0.25m 25
374 62:20 0.41m 41
375 62:30 0.30m 30
376 62:40 0.14m 14
377 62:50 0.01m 1
379 63:10 0.00m 0
380 63:20 0.01m 1
381 63:30 0.01m 1
382 63:40 0.02m 2
383 63:50 0.02m 2
385 64:10 0.01m 1
386 64:20 0.01m 1
387 64:30 0.01m 1
388 64:40 0.00m 0
389 64:50 0.00m 0
391 65:10 0.01m 1
392 65:20 0.01m 1
393 65:30 0.01m 1
394 65:40 0.02m 2
395 65:50 0.01m 1
397 66:10 0.01m 1
398 66:20 0.01m 1
399 66:30 0.00m 0
You have been diving with Gas 2: 18/42 and you didn't do any gas changes? What's about the other gases in your list: Are they active or inactive?
daviesjez
All other gases are inactive. Its the jump from 20+ mins NDL to 0 with such a shallow dive that is the worrying thing.
Jez
Jez
daviesjez
And another from last week if that helps, and i tried to force the gas switch to gas 1 even though i was already on gas 1 to see if that caused a dec recalc...@
Filename: 00534_02-08-2013_027m_062min
DiveNumber: 534
Date of dive: 02/08/2013
Time at begin of dive: 13:12:00
Time at end of dive: 14:15:00
Maximum depth (mbar): 2690
Maximum depth (bar): 2.69
Divetime: 62min 42sec
Selected Gas at begin of dive (1): 16/47
Gas 1: 16/47
Gas 2: 21/35
Gas 3: 28/0
Gas 4: 21/0
Gas 5: 21/0
Gas 6: 21/35
Minimum water temperature: 16.5
Maximum water temperature from profile:24.4
Minimum water temperature from profile:16.5
Surface air pressure (mBar): 1010
Desaturation time after dive (min): 227
Maximum CNS (%): 27
Average depth: 2124 mbar
Total divetime: 4040 sec
Last decostep: 6m
Salinity: 1.03
Profile data
ProfileOffset: 258
Number of ProfileEntries: 403
1 0:10 3.03m 306 , SetPoint set to 125
2 0:20 6.35m 641
3 0:30 8.28m 836
4 0:40 11.23m 1134
5 0:50 14.41m 1456
6 1:00 17.80m 1798 , Temperature 244, Non Deko Limit 240min, Gradient factor 0
7 1:10 20.92m 2113
8 1:20 23.61m 2385
9 1:30 23.72m 2396
10 1:40 23.78m 2402
11 1:50 23.89m 2413
12 2:00 23.98m 2422 , Temperature 228, Non Deko Limit 30min, Gradient factor 0, CNS 1
13 2:10 24.31m 2456
14 2:20 24.15m 2439
15 2:30 24.07m 2431
16 2:40 24.12m 2436
17 2:50 23.71m 2395
18 3:00 23.56m 2380 , Temperature 215, Non Deko Limit 31min, Gradient factor 0
19 3:10 23.39m 2363
20 3:20 23.53m 2377
21 3:30 23.61m 2385
22 3:40 23.37m 2361
23 3:50 23.52m 2376
24 4:00 23.58m 2382 , Temperature 204, Non Deko Limit 32min, Gradient factor 0, CNS 2
25 4:10 23.71m 2395
26 4:20 23.95m 2419
27 4:30 24.11m 2435
28 4:40 24.03m 2427
29 4:50 25.03m 2528
30 5:00 26.17m 2643 , Temperature 196, Non Deko Limit 21min, Gradient factor 0
31 5:10 26.15m 2641
32 5:20 26.12m 2638
33 5:30 26.22m 2648
34 5:40 26.15m 2641
35 5:50 26.20m 2646
36 6:00 25.92m 2618 , Temperature 190, Non Deko Limit 20min, Gradient factor 0, CNS 3
37 6:10 25.78m 2604
38 6:20 24.89m 2514
39 6:30 24.55m 2480
40 6:40 24.87m 2512
41 6:50 25.47m 2573
42 7:00 25.86m 2612 , Temperature 185, Non Deko Limit 21min, Gradient factor 0
43 7:10 26.11m 2637
44 7:20 26.04m 2630
45 7:30 25.98m 2624
46 7:40 26.08m 2634
47 7:50 25.96m 2622
48 8:00 25.93m 2619 , Temperature 181, Non Deko Limit 20min, Gradient factor 0, CNS 4
49 8:10 25.89m 2615
50 8:20 26.02m 2628
51 8:30 25.92m 2618
52 8:40 25.75m 2601
53 8:50 25.93m 2619
54 9:00 25.87m 2613 , Temperature 177, Non Deko Limit 20min, Gradient factor 0
55 9:10 26.03m 2629
56 9:20 25.99m 2625
57 9:30 26.22m 2648
58 9:40 26.28m 2655
59 9:50 26.35m 2662
60 10:00 25.83m 2609 , Temperature 175, Non Deko Limit 20min, Gradient factor 0, CNS 5
61 10:10 26.19m 2645
62 10:20 26.24m 2650
63 10:30 26.14m 2640
64 10:40 25.71m 2597
65 10:50 24.95m 2520
66 11:00 24.09m 2433 , Temperature 173, Non Deko Limit 25min, Gradient factor 0
67 11:10 23.93m 2417
68 11:20 23.93m 2417
69 11:30 23.89m 2413
70 11:40 24.12m 2436
71 11:50 24.14m 2438
72 12:00 23.68m 2392 , Temperature 172, Non Deko Limit 29min, Gradient factor 0, CNS 6
73 12:10 23.82m 2406
74 12:20 23.60m 2384
75 12:30 23.73m 2397
76 12:40 23.85m 2409
77 12:50 23.87m 2411
78 13:00 24.18m 2442 , Temperature 170, Non Deko Limit 28min, Gradient factor 0
79 13:10 24.25m 2449
80 13:20 24.58m 2483
81 13:30 25.66m 2592
82 13:40 25.52m 2578
83 13:50 25.51m 2577
84 14:00 25.62m 2588 , Temperature 169, Non Deko Limit 21min, Gradient factor 0, CNS 7
85 14:10 25.57m 2583
86 14:20 25.60m 2586 , Change gas to TX16/47
87 14:30 25.61m 2587
88 14:40 25.61m 2587
89 14:50 25.96m 2622
90 15:00 25.38m 2564 , Temperature 169, Non Deko Limit 15min, Gradient factor 0
91 15:10 25.48m 2574
92 15:20 25.57m 2583
93 15:30 25.60m 2586
94 15:40 25.55m 2581
95 15:50 25.59m 2585
96 16:00 25.67m 2593 , Temperature 168, Non Deko Limit 14min, Gradient factor 0, CNS 7
97 16:10 26.04m 2630
98 16:20 26.47m 2674
99 16:30 26.49m 2676
100 16:40 26.77m 2704
101 16:50 26.71m 2698
102 17:00 26.74m 2701 , Temperature 167, Non Deko Limit 11min, Gradient factor 0
103 17:10 26.74m 2701
104 17:20 26.80m 2707
105 17:30 26.27m 2653
106 17:40 25.43m 2569
107 17:50 25.25m 2550
108 18:00 24.90m 2515 , Temperature 167, Non Deko Limit 13min, Gradient factor 0, CNS 7
109 18:10 24.82m 2507
110 18:20 24.54m 2479
111 18:30 24.53m 2478
112 18:40 24.61m 2486
113 18:50 25.13m 2538
114 19:00 25.30m 2556 , Temperature 167, Non Deko Limit 11min, Gradient factor 0
115 19:10 25.57m 2583
116 19:20 26.05m 2631
117 19:30 26.00m 2626
118 19:40 25.87m 2613
119 19:50 26.01m 2627
120 20:00 25.73m 2599 , Temperature 166, Non Deko Limit 10min, Gradient factor 0, CNS 7
121 20:10 25.69m 2595
122 20:20 25.76m 2602
123 20:30 24.81m 2506
124 20:40 25.03m 2528
125 20:50 24.56m 2481
126 21:00 23.93m 2417 , Temperature 166, Non Deko Limit 12min, Gradient factor 0
127 21:10 23.56m 2380
128 21:20 23.59m 2383
129 21:30 23.63m 2387
130 21:40 23.61m 2385
131 21:50 23.54m 2378
132 22:00 23.43m 2367 , Temperature 166, Non Deko Limit 12min, Gradient factor 0, CNS 7
133 22:10 23.64m 2388
134 22:20 23.30m 2353
135 22:30 23.52m 2376
136 22:40 23.99m 2423
137 22:50 24.26m 2450
138 23:00 23.95m 2419 , Temperature 166, Non Deko Limit 10min, Gradient factor 0
139 23:10 23.92m 2416
140 23:20 23.89m 2413
141 23:30 23.80m 2404
142 23:40 23.47m 2371
143 23:50 23.51m 2375
144 24:00 23.54m 2378 , Temperature 166, Non Deko Limit 10min, Gradient factor 0, CNS 7
145 24:10 23.52m 2376
146 24:20 23.56m 2380
147 24:30 23.69m 2393
148 24:40 23.55m 2379
149 24:50 23.60m 2384
150 25:00 23.59m 2383 , Temperature 166, Non Deko Limit 8min, Gradient factor 0
151 25:10 23.50m 2374
152 25:20 23.43m 2367
153 25:30 23.65m 2389
154 25:40 23.66m 2390
155 25:50 23.71m 2395
156 26:00 23.75m 2399 , Temperature 166, Non Deko Limit 7min, Gradient factor 0, CNS 7
157 26:10 23.68m 2392 , Change gas to TX16/47
158 26:20 23.76m 2400
159 26:30 23.68m 2392 , SetPoint set to 125
160 26:40 23.53m 2377
161 26:50 23.21m 2344
162 27:00 23.13m 2336 , Temperature 166, Non Deko Limit 15min, Gradient factor 0
163 27:10 23.08m 2331
164 27:20 22.83m 2306
165 27:30 22.50m 2273
166 27:40 22.39m 2262
167 27:50 22.29m 2251
168 28:00 22.52m 2275 , Temperature 166, Non Deko Limit 20min, Gradient factor 0, CNS 8
169 28:10 22.62m 2285
170 28:20 22.42m 2265
171 28:30 22.50m 2273
172 28:40 22.24m 2246
173 28:50 22.20m 2242
174 29:00 22.55m 2278 , Temperature 166, Non Deko Limit 20min, Gradient factor 0
175 29:10 22.49m 2272
176 29:20 22.64m 2287
177 29:30 23.04m 2327
178 29:40 23.08m 2331
179 29:50 23.35m 2359
180 30:00 23.29m 2352 , Temperature 165, Non Deko Limit 0min, Gradient factor 0, CNS 9
181 30:10 23.23m 2346
182 30:20 22.88m 2311
183 30:30 22.99m 2322
184 30:40 22.79m 2302
185 30:50 22.79m 2302
186 31:00 23.03m 2326 , Temperature 165, Non Deko Limit 0min, Gradient factor 0
187 31:10 22.94m 2317
188 31:20 23.04m 2327
189 31:30 23.08m 2331
190 31:40 23.19m 2342
191 31:50 23.46m 2370
192 32:00 23.32m 2356 , Temperature 165, Non Deko Limit 0min, Gradient factor 0, CNS 10
193 32:10 23.25m 2348
195 32:30 23.59m 2383
196 32:40 23.52m 2376
197 32:50 23.52m 2376
198 33:00 23.42m 2366 , Temperature 165, Non Deko Limit 0min, Gradient factor 0
199 33:10 23.66m 2390
200 33:20 23.39m 2363
201 33:30 23.65m 2389
202 33:40 24.01m 2425
203 33:50 24.99m 2524
204 34:00 25.31m 2557 , Temperature 165, Decostop at 6m 1min, Gradient factor 0, CNS 11
205 34:10 25.72m 2598
206 34:20 25.88m 2614
207 34:30 25.78m 2604
208 34:40 25.43m 2569
209 34:50 25.70m 2596
210 35:00 25.34m 2560 , Temperature 165, Decostop at 6m 1min, Gradient factor 0
211 35:10 25.48m 2574
212 35:20 25.42m 2568
213 35:30 25.42m 2568
214 35:40 25.13m 2538
215 35:50 25.47m 2573
216 36:00 25.79m 2605 , Temperature 165, Decostop at 6m 2min, Gradient factor 0, CNS 12
217 36:10 25.81m 2607
218 36:20 25.90m 2616
219 36:30 25.86m 2612
220 36:40 25.82m 2608
221 36:50 25.73m 2599
222 37:00 24.46m 2471 , Temperature 165, Decostop at 6m 2min, Gradient factor 0
223 37:10 23.90m 2414
224 37:20 23.64m 2388
225 37:30 23.70m 2394
226 37:40 23.44m 2368
227 37:50 23.40m 2364
228 38:00 23.34m 2358 , Temperature 165, Decostop at 6m 3min, Gradient factor 0, CNS 13
229 38:10 23.22m 2345
230 38:20 23.39m 2363
231 38:30 23.44m 2368
233 38:50 23.47m 2371
234 39:00 23.22m 2345 , Temperature 165, Decostop at 6m 3min, Gradient factor 0
235 39:10 23.23m 2346
236 39:20 23.62m 2386
237 39:30 23.31m 2355
238 39:40 23.54m 2378
239 39:50 23.65m 2389
240 40:00 23.45m 2369 , Temperature 165, Decostop at 6m 3min, Gradient factor 0, CNS 14
241 40:10 23.83m 2407
242 40:20 24.54m 2479
243 40:30 24.65m 2490
244 40:40 24.73m 2498
245 40:50 24.25m 2449
246 41:00 23.31m 2355 , Temperature 165, Decostop at 6m 4min, Gradient factor 0
247 41:10 23.22m 2345
248 41:20 23.43m 2367
249 41:30 23.30m 2354
250 41:40 23.30m 2354
251 41:50 23.30m 2354
252 42:00 23.07m 2330 , Temperature 165, Decostop at 6m 4min, Gradient factor 0, CNS 15
253 42:10 23.67m 2391
254 42:20 23.63m 2387
255 42:30 23.48m 2372
256 42:40 23.65m 2389
257 42:50 23.61m 2385
258 43:00 23.61m 2385 , Temperature 165, Decostop at 6m 4min, Gradient factor 0
259 43:10 23.60m 2384
260 43:20 23.53m 2377
261 43:30 23.70m 2394
262 43:40 23.55m 2379
263 43:50 23.64m 2388
264 44:00 23.48m 2372 , Temperature 166, Decostop at 6m 4min, Gradient factor 0, CNS 16
265 44:10 23.63m 2387
266 44:20 23.65m 2389
267 44:30 23.68m 2392
268 44:40 23.72m 2396
269 44:50 23.42m 2366
270 45:00 23.59m 2383 , Temperature 165, Decostop at 6m 5min, Gradient factor 0
271 45:10 23.62m 2386
272 45:20 23.52m 2376
273 45:30 23.65m 2389
274 45:40 23.71m 2395
275 45:50 23.56m 2380
276 46:00 23.35m 2359 , Temperature 165, Decostop at 6m 5min, Gradient factor 0, CNS 17
277 46:10 23.71m 2395
278 46:20 23.46m 2370
279 46:30 23.23m 2346
280 46:40 23.30m 2354
281 46:50 23.30m 2353
282 47:00 23.04m 2327 , Temperature 165, Decostop at 6m 5min, Gradient factor 0
283 47:10 23.30m 2353
284 47:20 23.30m 2354
285 47:30 23.30m 2354
286 47:40 23.22m 2345
287 47:50 22.96m 2319
288 48:00 23.14m 2337 , Temperature 165, Decostop at 6m 6min, Gradient factor 0, CNS 18
289 48:10 23.13m 2336
290 48:20 23.00m 2323
291 48:30 23.06m 2329
292 48:40 23.29m 2352
293 48:50 23.20m 2343
294 49:00 23.32m 2356 , Temperature 165, Decostop at 6m 6min, Gradient factor 0
295 49:10 23.28m 2351
296 49:20 23.30m 2354
297 49:30 23.26m 2349
298 49:40 23.26m 2349
299 49:50 23.26m 2349
300 50:00 23.00m 2323 , Temperature 165, Decostop at 6m 6min, Gradient factor 0, CNS 19
301 50:10 23.26m 2349
302 50:20 22.95m 2318
303 50:30 22.77m 2300
304 50:40 22.40m 2263
305 50:50 22.26m 2248
306 51:00 21.87m 2209 , Temperature 165, Decostop at 6m 7min, Gradient factor 0
307 51:10 21.85m 2207
308 51:20 21.73m 2195
309 51:30 20.79m 2100
310 51:40 20.45m 2066
311 51:50 19.45m 1965
312 52:00 18.61m 1880 , Temperature 166, Decostop at 6m 7min, Gradient factor 0, CNS 20
313 52:10 17.62m 1780
314 52:20 16.86m 1703
315 52:30 15.84m 1600
316 52:40 14.22m 1436
317 52:50 13.90m 1404
318 53:00 13.73m 1387 , Temperature 166, Decostop at 6m 7min, Gradient factor 0
319 53:10 13.79m 1393
320 53:20 13.85m 1399
321 53:30 13.28m 1341
322 53:40 12.88m 1301
323 53:50 12.70m 1283
324 54:00 11.60m 1172 , Temperature 167, Decostop at 6m 7min, Gradient factor 0, CNS 21
325 54:10 10.68m 1079
326 54:20 10.75m 1086
327 54:30 10.81m 1092
328 54:40 10.20m 1030
329 54:50 9.22m 931
330 55:00 8.60m 869 , Temperature 167, Decostop at 6m 6min, Gradient factor 0
331 55:10 8.06m 814
332 55:20 7.03m 710
333 55:30 7.00m 707
334 55:40 7.27m 734
335 55:50 6.59m 666
336 56:00 6.25m 631 , Temperature 168, Decostop at 6m 6min, Gradient factor 22, CNS 22
337 56:10 6.54m 661
338 56:20 5.86m 592
339 56:30 5.91m 597
340 56:40 6.23m 629
341 56:50 5.92m 598
342 57:00 6.05m 611 , Temperature 168, Decostop at 6m 5min, Gradient factor 20
343 57:10 6.52m 659
344 57:20 6.25m 631
345 57:30 6.32m 638
346 57:40 6.17m 623
347 57:50 6.24m 630
348 58:00 6.31m 637 , Temperature 168, Decostop at 6m 4min, Gradient factor 3, CNS 23
349 58:10 6.04m 610
350 58:20 6.15m 621
351 58:30 6.18m 624
352 58:40 6.14m 620
353 58:50 6.21m 627
354 59:00 6.16m 622 , Temperature 168, Decostop at 6m 3min, Gradient factor 0
355 59:10 6.14m 620
356 59:20 6.10m 616
357 59:30 6.23m 629
358 59:40 6.27m 633
359 59:50 6.41m 647
360 60:00 5.96m 602 , Temperature 168, Decostop at 6m 2min, Gradient factor 0, CNS 24
361 60:10 6.06m 612
362 60:20 5.67m 573
363 60:30 5.35m 540
364 60:40 5.01m 506
365 60:50 4.48m 453
366 61:00 4.27m 431 , Temperature 169, Decostop at 6m 1min, Gradient factor 18
367 61:10 3.96m 400
368 61:20 3.79m 383
369 61:30 2.88m 291
370 61:40 2.17m 219
371 61:50 0.64m 65
372 62:00 0.31m 31 , Temperature 169, Non Deko Limit 240min, Gradient factor 71, CNS 25
373 62:10 0.37m 37
374 62:20 0.45m 45
375 62:30 0.35m 35
376 62:40 0.40m 40
377 62:50 0.35m 35
378 63:00 0.25m 25 , Temperature 169, Non Deko Limit 240min, Gradient factor 67
379 63:10 0.34m 34
380 63:20 0.32m 32
381 63:30 0.10m 10
382 63:40 0.02m 2
383 63:50 0.03m 3
384 64:00 0.02m 2 , Temperature 170, Non Deko Limit 240min, Gradient factor 66, CNS 26
385 64:10 0.02m 2
386 64:20 0.03m 3
387 64:30 0.03m 3
388 64:40 0.04m 4
389 64:50 0.03m 3
390 65:00 0.03m 3 , Temperature 172, Non Deko Limit 240min, Gradient factor 64
391 65:10 0.02m 2
392 65:20 0.03m 3
393 65:30 0.02m 2
394 65:40 0.02m 2
395 65:50 0.01m 1
396 66:00 0.02m 2 , Temperature 175, Non Deko Limit 240min, Gradient factor 60, CNS 26
397 66:10 0.02m 2
398 66:20 0.03m 3
399 66:30 0.02m 2
400 66:40 0.03m 3
401 66:50 0.03m 3
402 67:00 0.04m 4 , Temperature 179, Non Deko Limit 240min, Gradient factor 57
403 67:10 0.02m 2
Jez
DiveNumber: 534
Gas 1: 16/47
Gas 2: 21/35
Gas 3: 28/0
Gas 4: 21/0
Gas 5: 21/0
Gas 6: 21/35
Maximum CNS (%): 27
Last decostep: 6m
Salinity: 1.03
Profile data
ProfileOffset: 258
2 0:20 6.35m 641
3 0:30 8.28m 836
4 0:40 11.23m 1134
5 0:50 14.41m 1456
7 1:10 20.92m 2113
8 1:20 23.61m 2385
9 1:30 23.72m 2396
10 1:40 23.78m 2402
11 1:50 23.89m 2413
13 2:10 24.31m 2456
14 2:20 24.15m 2439
15 2:30 24.07m 2431
16 2:40 24.12m 2436
17 2:50 23.71m 2395
19 3:10 23.39m 2363
20 3:20 23.53m 2377
21 3:30 23.61m 2385
22 3:40 23.37m 2361
23 3:50 23.52m 2376
25 4:10 23.71m 2395
26 4:20 23.95m 2419
27 4:30 24.11m 2435
28 4:40 24.03m 2427
29 4:50 25.03m 2528
31 5:10 26.15m 2641
32 5:20 26.12m 2638
33 5:30 26.22m 2648
34 5:40 26.15m 2641
35 5:50 26.20m 2646
37 6:10 25.78m 2604
38 6:20 24.89m 2514
39 6:30 24.55m 2480
40 6:40 24.87m 2512
41 6:50 25.47m 2573
43 7:10 26.11m 2637
44 7:20 26.04m 2630
45 7:30 25.98m 2624
46 7:40 26.08m 2634
47 7:50 25.96m 2622
49 8:10 25.89m 2615
50 8:20 26.02m 2628
51 8:30 25.92m 2618
52 8:40 25.75m 2601
53 8:50 25.93m 2619
55 9:10 26.03m 2629
56 9:20 25.99m 2625
57 9:30 26.22m 2648
58 9:40 26.28m 2655
59 9:50 26.35m 2662
329 54:50 9.22m 931
331 55:10 8.06m 814
332 55:20 7.03m 710
333 55:30 7.00m 707
334 55:40 7.27m 734
335 55:50 6.59m 666
337 56:10 6.54m 661
338 56:20 5.86m 592
339 56:30 5.91m 597
340 56:40 6.23m 629
341 56:50 5.92m 598
343 57:10 6.52m 659
344 57:20 6.25m 631
345 57:30 6.32m 638
346 57:40 6.17m 623
347 57:50 6.24m 630
349 58:10 6.04m 610
350 58:20 6.15m 621
351 58:30 6.18m 624
352 58:40 6.14m 620
353 58:50 6.21m 627
355 59:10 6.14m 620
356 59:20 6.10m 616
357 59:30 6.23m 629
358 59:40 6.27m 633
359 59:50 6.41m 647
361 60:10 6.06m 612
362 60:20 5.67m 573
363 60:30 5.35m 540
364 60:40 5.01m 506
365 60:50 4.48m 453
367 61:10 3.96m 400
368 61:20 3.79m 383
369 61:30 2.88m 291
370 61:40 2.17m 219
371 61:50 0.64m 65
373 62:10 0.37m 37
374 62:20 0.45m 45
375 62:30 0.35m 35
376 62:40 0.40m 40
377 62:50 0.35m 35
379 63:10 0.34m 34
380 63:20 0.32m 32
381 63:30 0.10m 10
382 63:40 0.02m 2
383 63:50 0.03m 3
385 64:10 0.02m 2
386 64:20 0.03m 3
387 64:30 0.03m 3
388 64:40 0.04m 4
389 64:50 0.03m 3
391 65:10 0.02m 2
392 65:20 0.03m 3
393 65:30 0.02m 2
394 65:40 0.02m 2
395 65:50 0.01m 1
397 66:10 0.02m 2
398 66:20 0.03m 3
399 66:30 0.02m 2
400 66:40 0.03m 3
401 66:50 0.03m 3
403 67:10 0.02m 2
Jez
Hi Jez,
We'll do some diving in the depth range during the weekend, I'll try to reproduce this. Do you have the @+5 TTS display active during the dive?
daviesjez
Hi Matthias
Thanks for taking a look at this. It looks a little strange doesn't it!
Yes i do have the @+5 TTS, and am using my hardwired predator as primary. I have a horrible feeling the +5 is out as well... I will confirm on the dive tomorrow with my OSTC running 2.70 and the wifes back to prior stable
Jez
Jez
I doubt the 2.5 and the 2.7 will make much difference in the NDL calculations. There were little changes here.
[DF]
I have @+10 TTS activated in the background but I have Cave Bail showing on my display.
I reset the computer as you suggested and after that it showed accurate NDL:s during simulation. However during real dives it still gives strange NDL:s.
I will post the most important part of my profiles as apparently they are too long to fit and I am not allowed to post them in full.
Filename: 00832_21-07-2013_047m_150min
DiveNumber: 832
Date of dive: 2013-07-21
Time at begin of dive: 14:21:00
Time at end of dive: 16:52:00
Maximum depth (mbar): 4721
Maximum depth (bar): 4,721
Divetime: 150min 10sec
Selected Gas at begin of dive (1): 12/65
Gas 1: 12/65
Gas 2: 10/70
Gas 3: 15/55
Gas 4: 21/35
Gas 5: 20/20
Gas 6: 17/45
Minimum water temperature: 3,1
Maximum water temperature from profile:8,9
Minimum water temperature from profile:3,1
Surface air pressure (mBar): 1033
Desaturation time after dive (min): 796
Maximum CNS (%): 69
Average depth: 1919 mbar
Total divetime: 9310 sec
Gradient Factor High: 90%
Last decostep: 3m
Battery voltage in mV after dive: 4,105
Salinity: 1
Sampling rate (sec): 5
Sampling divisor temperature: 12 information size 2
Sampling divisor ppO2 sensors: 12 information size 3
Sampling divisor deco debug: 6 information size 15
Profile data
ProfileOffset: 258
Number of ProfileEntries: 1861
1 0:05 1,62m 159 , SetPoint set to 50
2 0:10 1,61m 158
3 0:15 1,53m 150
4 0:20 1,57m 154
5 0:25 1,63m 160
6 0:30 1,66m 163 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
7 0:35 1,70m 167
8 0:40 2,06m 202
9 0:45 2,50m 245
10 0:50 3,49m 342
11 0:55 4,03m 395
12 1:00 4,55m 446 , Temperature 31, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
13 1:05 4,65m 456
14 1:10 4,80m 471
15 1:15 4,70m 461
16 1:20 4,52m 443
17 1:25 4,32m 424
18 1:30 4,43m 434 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
19 1:35 4,61m 452
20 1:40 5,03m 493
21 1:45 4,93m 483
22 1:50 4,96m 486
23 1:55 4,92m 482
24 2:00 5,00m 490 , Temperature 31, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
25 2:05 5,05m 495
26 2:10 5,09m 499
27 2:15 5,17m 507
28 2:20 5,25m 515
29 2:25 5,35m 525
30 2:30 5,30m 520 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
31 2:35 5,52m 541
32 2:40 5,21m 511
33 2:45 5,21m 511
34 2:50 5,07m 497
35 2:55 4,90m 481
36 3:00 5,06m 496 , Temperature 31, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
37 3:05 5,49m 538
38 3:10 5,29m 519
39 3:15 5,34m 524
40 3:20 4,92m 482
41 3:25 4,52m 443
42 3:30 4,64m 455 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
43 3:35 4,34m 426
44 3:40 4,36m 428
45 3:45 4,46m 437
46 3:50 4,94m 484
47 3:55 5,20m 510
48 4:00 4,96m 486 , Temperature 31, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
49 4:05 5,08m 498
50 4:10 5,09m 499
51 4:15 5,28m 518
52 4:20 5,30m 520
53 4:25 5,23m 513
54 4:30 5,11m 501 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
55 4:35 4,94m 484
56 4:40 5,23m 513
57 4:45 5,24m 514
58 4:50 5,25m 515
59 4:55 5,18m 508
60 5:00 5,27m 517 , Temperature 31, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
61 5:05 5,41m 531
62 5:10 5,32m 522
63 5:15 5,20m 510
64 5:20 5,21m 511
65 5:25 5,31m 521
66 5:30 5,59m 548 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
67 5:35 5,63m 552
68 5:40 5,72m 561
69 5:45 6,02m 590
70 5:50 6,25m 613
71 5:55 6,36m 624
72 6:00 6,22m 610 , Temperature 32, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
73 6:05 6,17m 605
74 6:10 6,00m 588
75 6:15 5,91m 580
76 6:20 5,76m 565
77 6:25 5,57m 546
78 6:30 5,17m 507 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
79 6:35 4,99m 489
80 6:40 4,99m 489
81 6:45 5,09m 499
82 6:50 5,62m 551
83 6:55 6,34m 622
84 7:00 6,93m 680 , Temperature 32, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
85 7:05 7,60m 745
86 7:10 8,03m 787
87 7:15 8,43m 827
88 7:20 9,15m 897
89 7:25 9,49m 931
90 7:30 10,04m 985 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
91 7:35 10,40m 1020
92 7:40 10,77m 1056
93 7:45 11,31m 1109
94 7:50 12,04m 1181
95 7:55 12,22m 1198
96 8:00 12,42m 1218 , Temperature 32, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
97 8:05 12,25m 1201
98 8:10 12,01m 1178
99 8:15 11,78m 1155
100 8:20 11,16m 1094
101 8:25 11,02m 1081
102 8:30 10,95m 1074 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
103 8:35 11,29m 1107
104 8:40 10,87m 1066
105 8:45 10,19m 999
106 8:50 9,23m 905
107 8:55 9,17m 899
108 9:00 9,16m 898 , Temperature 33, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
109 9:05 9,09m 891
110 9:10 9,51m 933
111 9:15 9,31m 913
112 9:20 9,76m 957
113 9:25 10,65m 1044
114 9:30 11,60m 1138 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
115 9:35 12,01m 1178
116 9:40 12,23m 1199
117 9:45 12,32m 1208
118 9:50 12,05m 1182
119 9:55 12,18m 1194
120 10:00 12,10m 1187 , Temperature 33, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
121 10:05 11,66m 1143
122 10:10 11,65m 1142
123 10:15 11,04m 1083
124 10:20 10,30m 1010
125 10:25 9,97m 978
126 10:30 9,99m 980 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
127 10:35 10,01m 982
128 10:40 10,02m 983
129 10:45 10,17m 997
130 10:50 10,13m 993
131 10:55 10,30m 1010
132 11:00 10,74m 1053 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
133 11:05 10,88m 1067
134 11:10 10,77m 1056
135 11:15 11,21m 1099
136 11:20 10,05m 986
137 11:25 9,70m 951
138 11:30 9,62m 943 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
139 11:35 9,64m 945
140 11:40 9,55m 937
141 11:45 9,42m 924
142 11:50 9,24m 906
143 11:55 9,18m 900
144 12:00 9,21m 903 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
145 12:05 9,40m 922
146 12:10 9,41m 923
147 12:15 9,28m 910
148 12:20 9,26m 908
149 12:25 9,73m 954
150 12:30 10,30m 1010 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
151 12:35 10,72m 1051
152 12:40 10,89m 1068
153 12:45 11,11m 1090
154 12:50 11,15m 1093
155 12:55 11,10m 1089
156 13:00 11,18m 1096 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
157 13:05 11,31m 1109
158 13:10 11,43m 1121
159 13:15 11,45m 1123
160 13:20 11,58m 1136
161 13:25 11,69m 1146
162 13:30 11,69m 1146 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
163 13:35 11,61m 1139
164 13:40 11,54m 1132
165 13:45 11,44m 1122
166 13:50 11,39m 1117
167 13:55 11,54m 1132
168 14:00 12,01m 1178 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
169 14:05 12,21m 1197
170 14:10 12,36m 1212
171 14:15 12,43m 1219
172 14:20 12,54m 1230
173 14:25 12,30m 1206
174 14:30 12,05m 1182 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
175 14:35 11,90m 1167
176 14:40 11,60m 1138
177 14:45 10,86m 1065
178 14:50 9,93m 974
179 14:55 9,94m 975
180 15:00 9,98m 979 , Temperature 36, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
181 15:05 10,11m 991
182 15:10 10,12m 992
183 15:15 10,00m 981
184 15:20 9,31m 913
185 15:25 8,85m 868
186 15:30 7,48m 734 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
187 15:35 7,14m 700
188 15:40 7,29m 715
189 15:45 6,86m 673
190 15:50 6,90m 677
191 15:55 7,00m 686
192 16:00 7,13m 699 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
193 16:05 6,91m 678
194 16:10 6,79m 666
195 16:15 6,93m 680
196 16:20 7,14m 700
197 16:25 6,55m 642
198 16:30 6,60m 647 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
199 16:35 6,62m 649
200 16:40 6,66m 653
201 16:45 6,79m 666
202 16:50 6,86m 673
203 16:55 7,06m 692
204 17:00 7,00m 686 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
205 17:05 6,79m 666
206 17:10 6,61m 648
207 17:15 6,52m 639
208 17:20 6,42m 630
209 17:25 6,23m 611
210 17:30 6,54m 641 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
211 17:35 6,95m 682
212 17:40 7,11m 697
213 17:45 7,29m 715
214 17:50 7,09m 695
215 17:55 6,95m 682
216 18:00 6,87m 674 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
217 18:05 6,73m 660
218 18:10 6,84m 671
219 18:15 6,72m 659
220 18:20 6,41m 629
221 18:25 6,21m 609
222 18:30 6,32m 620 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
223 18:35 6,36m 624
224 18:40 6,20m 608
225 18:45 6,33m 621
226 18:50 6,40m 628
227 18:55 6,44m 632
228 19:00 6,52m 639 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
229 19:05 6,58m 645
230 19:10 6,53m 640
231 19:15 6,66m 653
232 19:20 6,58m 645
233 19:25 6,70m 657
234 19:30 6,62m 649 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
235 19:35 6,51m 638
236 19:40 6,41m 629
237 19:45 6,20m 608
238 19:50 6,27m 615
239 19:55 6,38m 626
240 20:00 6,07m 595 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
241 20:05 5,81m 570
242 20:10 6,10m 598
243 20:15 6,38m 626
244 20:20 6,42m 630
245 20:25 6,76m 663
246 20:30 6,87m 674 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
247 20:35 7,08m 694
248 20:40 7,07m 693
249 20:45 7,13m 699
250 20:50 7,13m 699
251 20:55 7,17m 703
252 21:00 7,10m 696 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
253 21:05 7,06m 692
254 21:10 7,16m 702
255 21:15 7,31m 717
256 21:20 7,30m 716
257 21:25 7,38m 724
258 21:30 7,48m 734 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
259 21:35 7,23m 709
260 21:40 7,21m 707
261 21:45 7,08m 694
262 21:50 6,88m 675
263 21:55 6,90m 677
264 22:00 6,82m 669 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
265 22:05 6,70m 657
266 22:10 6,52m 639
267 22:15 6,28m 616
268 22:20 6,32m 620
269 22:25 6,42m 630
270 22:30 6,39m 627 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
271 22:35 6,32m 620
272 22:40 6,32m 620
273 22:45 6,35m 623
274 22:50 6,51m 638
275 22:55 6,63m 650
276 23:00 6,80m 667 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
277 23:05 7,10m 696
278 23:10 7,44m 730
279 23:15 7,87m 772
280 23:20 8,44m 828
281 23:25 8,80m 863
282 23:30 8,93m 876 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
283 23:35 9,01m 884
284 23:40 9,16m 898
285 23:45 9,23m 905
286 23:50 9,12m 894
287 23:55 8,96m 879
288 24:00 8,79m 862 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
289 24:05 8,66m 849
290 24:10 8,65m 848
291 24:15 8,66m 849
292 24:20 8,57m 840
293 24:25 8,35m 819
294 24:30 8,15m 799 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
295 24:35 8,20m 804
296 24:40 8,25m 809
297 24:45 8,24m 808
298 24:50 8,66m 849
299 24:55 8,98m 881
300 25:00 9,07m 889 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
301 25:05 9,12m 894
302 25:10 9,25m 907
303 25:15 9,35m 917
304 25:20 9,33m 915
305 25:25 9,16m 898
306 25:30 9,02m 885 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
307 25:35 9,16m 898
308 25:40 9,30m 912
309 25:45 9,24m 906
310 25:50 9,12m 894
311 25:55 8,98m 881
312 26:00 9,06m 888 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
313 26:05 8,99m 882
314 26:10 8,94m 877
315 26:15 8,77m 860
316 26:20 8,59m 842
317 26:25 8,61m 844
318 26:30 8,80m 863 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
319 26:35 8,99m 882
320 26:40 8,90m 873
321 26:45 8,85m 868
322 26:50 8,72m 855
323 26:55 8,81m 864
324 27:00 8,82m 865 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
325 27:05 8,76m 859
326 27:10 8,77m 860
327 27:15 8,78m 861
328 27:20 8,81m 864
329 27:25 8,76m 859
330 27:30 8,87m 870 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
331 27:35 8,90m 873
332 27:40 9,07m 889
333 27:45 9,20m 902
334 27:50 9,26m 908
335 27:55 9,31m 913
336 28:00 9,65m 946 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
337 28:05 9,69m 950
338 28:10 9,77m 958
339 28:15 9,91m 972
340 28:20 10,19m 999
341 28:25 10,42m 1022
342 28:30 11,23m 1101 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
343 28:35 12,28m 1204
344 28:40 13,72m 1345
345 28:45 14,64m 1436
346 28:50 15,01m 1472
347 28:55 15,60m 1530
348 29:00 17,10m 1677 , Temperature 34, Non Deko Limit 110min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
349 29:05 18,55m 1819
350 29:10 20,24m 1985
351 29:15 21,81m 2139
352 29:20 23,32m 2287
353 29:25 22,84m 2240
354 29:30 22,90m 2246 , Non Deko Limit 51min, Gradient factor 0, Deco Debug
355 29:35 22,81m 2237
356 29:40 22,95m 2251
357 29:45 23,15m 2270
358 29:50 23,74m 2328
359 29:55 24,45m 2398
360 30:00 25,22m 2473 , Temperature 35, Non Deko Limit 40min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
361 30:05 25,72m 2522
362 30:10 26,44m 2593
363 30:15 27,02m 2650
364 30:20 27,74m 2720
365 30:25 28,63m 2808
366 30:30 29,33m 2876 , Non Deko Limit 26min, Gradient factor 0, Deco Debug
367 30:35 29,91m 2933
368 30:40 30,40m 2981
369 30:45 30,66m 3007
370 30:50 31,22m 3062
371 30:55 31,36m 3075
372 31:00 31,43m 3082 , Temperature 37, Non Deko Limit 21min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
373 31:05 31,78m 3117
374 31:10 32,26m 3164
375 31:15 32,70m 3207
376 31:20 32,97m 3233
377 31:25 33,25m 3261
378 31:30 33,78m 3313 , Non Deko Limit 18min, Gradient factor 0, Deco Debug
379 31:35 34,22m 3356
380 31:40 34,59m 3392
381 31:45 34,98m 3430
382 31:50 35,24m 3456
383 31:55 35,27m 3459
384 32:00 35,40m 3472 , Temperature 39, Non Deko Limit 16min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 4
385 32:05 35,39m 3471 , SetPoint set to 130
386 32:10 35,41m 3473
387 32:15 35,53m 3484
388 32:20 35,66m 3497
389 32:25 35,63m 3494
390 32:30 35,41m 3473 , Non Deko Limit 15min, Gradient factor 0, Deco Debug
391 32:35 35,44m 3475
392 32:40 35,93m 3524
393 32:45 35,53m 3484
394 32:50 35,52m 3483
395 32:55 35,66m 3497
396 33:00 35,41m 3473 , Temperature 43, Non Deko Limit 15min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 4
397 33:05 35,17m 3449
398 33:10 35,23m 3455
399 33:15 34,93m 3425
400 33:20 34,94m 3426
401 33:25 35,11m 3443
402 33:30 35,36m 3468 , Non Deko Limit 15min, Gradient factor 0, Deco Debug
403 33:35 35,41m 3473
404 33:40 35,33m 3465
405 33:45 35,33m 3465
406 33:50 35,33m 3465
407 33:55 35,57m 3488
408 34:00 35,78m 3509 , Temperature 45, Non Deko Limit 15min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 5
409 34:05 35,69m 3500
410 34:10 35,81m 3512
411 34:15 35,84m 3515
412 34:20 35,87m 3518
413 34:25 35,91m 3522
414 34:30 35,98m 3528 , Non Deko Limit 14min, Gradient factor 0, Deco Debug
415 34:35 36,32m 3562
416 34:40 36,72m 3601
417 34:45 36,97m 3626
418 34:50 36,84m 3613
419 34:55 36,55m 3584
420 35:00 36,80m 3609 , Temperature 47, Non Deko Limit 14min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 5
421 35:05 37,87m 3714
422 35:10 38,50m 3776
423 35:15 38,85m 3810
424 35:20 39,39m 3863
425 35:25 39,85m 3908
426 35:30 40,46m 3968 , Non Deko Limit 10min, Gradient factor 0, Deco Debug
427 35:35 40,75m 3996
428 35:40 40,97m 4018
429 35:45 41,36m 4056
430 35:50 41,73m 4092
431 35:55 42,00m 4119
432 36:00 42,19m 4137 , Temperature 48, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 6
433 36:05 42,36m 4154
434 36:10 42,48m 4166
435 36:15 42,22m 4140
436 36:20 42,17m 4135
437 36:25 42,19m 4137
438 36:30 41,88m 4107 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
439 36:35 42,13m 4132
440 36:40 41,73m 4092
441 36:45 41,57m 4077
442 36:50 41,36m 4056
443 36:55 41,51m 4071
444 37:00 41,88m 4107 , Temperature 50, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 6
445 37:05 42,13m 4132
446 37:10 42,23m 4141
447 37:15 42,26m 4144
448 37:20 42,26m 4144
449 37:25 42,20m 4138
450 37:30 42,11m 4130 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
451 37:35 42,23m 4141
452 37:40 42,31m 4149
453 37:45 42,45m 4163
454 37:50 42,18m 4136
455 37:55 42,07m 4126
456 38:00 42,12m 4131 , Temperature 50, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 7
457 38:05 42,41m 4159
458 38:10 42,96m 4213
459 38:15 43,37m 4253
460 38:20 43,73m 4288
461 38:25 43,98m 4313
462 38:30 44,14m 4329 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
463 38:35 44,18m 4333
464 38:40 44,29m 4343
465 38:45 44,40m 4354
466 38:50 44,18m 4333
467 38:55 44,47m 4361
468 39:00 44,58m 4372 , Temperature 51, Decostop at 3m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 3m 1min, CNS 7
469 39:05 44,88m 4401
470 39:10 45,05m 4418
471 39:15 45,10m 4423
472 39:20 45,19m 4432
473 39:25 45,30m 4442
474 39:30 45,50m 4462 , Decostop at 3m 1min, Gradient factor 0, Deco Debug 3m 1min
475 39:35 45,53m 4465
476 39:40 45,57m 4469
477 39:45 45,54m 4466
478 39:50 45,44m 4456
479 39:55 45,26m 4438
480 40:00 45,15m 4428 , Temperature 52, Decostop at 6m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 6m 1min, 3m 1min, CNS 8
DiveFileversion: 100
LogBookProfileVersion: 33
DiveNumber: 832
Gas 1: 12/65
Gas 2: 10/70
Gas 3: 15/55
Gas 4: 21/35
Gas 5: 20/20
Gas 6: 17/45
Maximum CNS (%): 69
Gradient Factor Low: 30%
Decotype: ZH-L16-GF CC
Last decostep: 3m
Firmware version: 270
Salinity: 1
Sampling divisor deco/NDL: 6 information size 2
Sampling divisor gradientfactor: 6 information size 1
Sampling divisor CNS: 12 information size 1
Profile data
ProfileOffset: 258
Entry Time Depth mBar , Additional Info
2 0:10 1,61m 158
3 0:15 1,53m 150
4 0:20 1,57m 154
5 0:25 1,63m 160
7 0:35 1,70m 167
8 0:40 2,06m 202
9 0:45 2,50m 245
10 0:50 3,49m 342
11 0:55 4,03m 395
13 1:05 4,65m 456
14 1:10 4,80m 471
15 1:15 4,70m 461
16 1:20 4,52m 443
17 1:25 4,32m 424
19 1:35 4,61m 452
20 1:40 5,03m 493
21 1:45 4,93m 483
22 1:50 4,96m 486
23 1:55 4,92m 482
25 2:05 5,05m 495
26 2:10 5,09m 499
27 2:15 5,17m 507
28 2:20 5,25m 515
29 2:25 5,35m 525
31 2:35 5,52m 541
32 2:40 5,21m 511
33 2:45 5,21m 511
34 2:50 5,07m 497
35 2:55 4,90m 481
37 3:05 5,49m 538
38 3:10 5,29m 519
39 3:15 5,34m 524
40 3:20 4,92m 482
41 3:25 4,52m 443
43 3:35 4,34m 426
44 3:40 4,36m 428
45 3:45 4,46m 437
46 3:50 4,94m 484
47 3:55 5,20m 510
49 4:05 5,08m 498
50 4:10 5,09m 499
51 4:15 5,28m 518
52 4:20 5,30m 520
53 4:25 5,23m 513
55 4:35 4,94m 484
56 4:40 5,23m 513
57 4:45 5,24m 514
58 4:50 5,25m 515
59 4:55 5,18m 508
61 5:05 5,41m 531
62 5:10 5,32m 522
63 5:15 5,20m 510
64 5:20 5,21m 511
65 5:25 5,31m 521
67 5:35 5,63m 552
68 5:40 5,72m 561
69 5:45 6,02m 590
70 5:50 6,25m 613
71 5:55 6,36m 624
73 6:05 6,17m 605
74 6:10 6,00m 588
75 6:15 5,91m 580
76 6:20 5,76m 565
77 6:25 5,57m 546
79 6:35 4,99m 489
80 6:40 4,99m 489
81 6:45 5,09m 499
82 6:50 5,62m 551
83 6:55 6,34m 622
85 7:05 7,60m 745
86 7:10 8,03m 787
87 7:15 8,43m 827
88 7:20 9,15m 897
89 7:25 9,49m 931
91 7:35 10,40m 1020
92 7:40 10,77m 1056
93 7:45 11,31m 1109
94 7:50 12,04m 1181
95 7:55 12,22m 1198
97 8:05 12,25m 1201
98 8:10 12,01m 1178
99 8:15 11,78m 1155
105 8:45 10,19m 999
106 8:50 9,23m 905
107 8:55 9,17m 899
109 9:05 9,09m 891
110 9:10 9,51m 933
111 9:15 9,31m 913
112 9:20 9,76m 957
125 10:25 9,97m 978
137 11:25 9,70m 951
139 11:35 9,64m 945
140 11:40 9,55m 937
141 11:45 9,42m 924
142 11:50 9,24m 906
143 11:55 9,18m 900
145 12:05 9,40m 922
146 12:10 9,41m 923
147 12:15 9,28m 910
148 12:20 9,26m 908
149 12:25 9,73m 954
178 14:50 9,93m 974
179 14:55 9,94m 975
184 15:20 9,31m 913
185 15:25 8,85m 868
187 15:35 7,14m 700
188 15:40 7,29m 715
189 15:45 6,86m 673
190 15:50 6,90m 677
191 15:55 7,00m 686
193 16:05 6,91m 678
194 16:10 6,79m 666
195 16:15 6,93m 680
196 16:20 7,14m 700
197 16:25 6,55m 642
199 16:35 6,62m 649
200 16:40 6,66m 653
201 16:45 6,79m 666
202 16:50 6,86m 673
203 16:55 7,06m 692
205 17:05 6,79m 666
206 17:10 6,61m 648
207 17:15 6,52m 639
208 17:20 6,42m 630
209 17:25 6,23m 611
211 17:35 6,95m 682
212 17:40 7,11m 697
213 17:45 7,29m 715
214 17:50 7,09m 695
215 17:55 6,95m 682
217 18:05 6,73m 660
218 18:10 6,84m 671
219 18:15 6,72m 659
220 18:20 6,41m 629
221 18:25 6,21m 609
223 18:35 6,36m 624
224 18:40 6,20m 608
225 18:45 6,33m 621
226 18:50 6,40m 628
227 18:55 6,44m 632
229 19:05 6,58m 645
230 19:10 6,53m 640
231 19:15 6,66m 653
232 19:20 6,58m 645
233 19:25 6,70m 657
235 19:35 6,51m 638
236 19:40 6,41m 629
237 19:45 6,20m 608
238 19:50 6,27m 615
239 19:55 6,38m 626
241 20:05 5,81m 570
242 20:10 6,10m 598
243 20:15 6,38m 626
244 20:20 6,42m 630
245 20:25 6,76m 663
247 20:35 7,08m 694
248 20:40 7,07m 693
249 20:45 7,13m 699
250 20:50 7,13m 699
251 20:55 7,17m 703
253 21:05 7,06m 692
254 21:10 7,16m 702
255 21:15 7,31m 717
256 21:20 7,30m 716
257 21:25 7,38m 724
259 21:35 7,23m 709
260 21:40 7,21m 707
261 21:45 7,08m 694
262 21:50 6,88m 675
263 21:55 6,90m 677
265 22:05 6,70m 657
266 22:10 6,52m 639
267 22:15 6,28m 616
268 22:20 6,32m 620
269 22:25 6,42m 630
271 22:35 6,32m 620
272 22:40 6,32m 620
273 22:45 6,35m 623
274 22:50 6,51m 638
275 22:55 6,63m 650
277 23:05 7,10m 696
278 23:10 7,44m 730
279 23:15 7,87m 772
280 23:20 8,44m 828
281 23:25 8,80m 863
283 23:35 9,01m 884
284 23:40 9,16m 898
285 23:45 9,23m 905
286 23:50 9,12m 894
287 23:55 8,96m 879
289 24:05 8,66m 849
290 24:10 8,65m 848
291 24:15 8,66m 849
292 24:20 8,57m 840
293 24:25 8,35m 819
295 24:35 8,20m 804
296 24:40 8,25m 809
297 24:45 8,24m 808
298 24:50 8,66m 849
299 24:55 8,98m 881
301 25:05 9,12m 894
302 25:10 9,25m 907
303 25:15 9,35m 917
304 25:20 9,33m 915
305 25:25 9,16m 898
307 25:35 9,16m 898
308 25:40 9,30m 912
309 25:45 9,24m 906
310 25:50 9,12m 894
311 25:55 8,98m 881
313 26:05 8,99m 882
314 26:10 8,94m 877
315 26:15 8,77m 860
316 26:20 8,59m 842
317 26:25 8,61m 844
319 26:35 8,99m 882
320 26:40 8,90m 873
321 26:45 8,85m 868
322 26:50 8,72m 855
323 26:55 8,81m 864
325 27:05 8,76m 859
326 27:10 8,77m 860
327 27:15 8,78m 861
328 27:20 8,81m 864
329 27:25 8,76m 859
331 27:35 8,90m 873
332 27:40 9,07m 889
333 27:45 9,20m 902
334 27:50 9,26m 908
335 27:55 9,31m 913
337 28:05 9,69m 950
338 28:10 9,77m 958
339 28:15 9,91m 972
[DF]
Re: Strange NDL on 2 dives today V2.70
Second Dive
Filename: 00833_08-08-2013_054m_160min
DiveNumber: 833
Date of dive: 2013-08-08
Time at begin of dive: 19:14:00
Time at end of dive: 21:55:00
Maximum depth (mbar): 5393
Maximum depth (bar): 5,393
Divetime: 160min 52sec
Selected Gas at begin of dive (3): 15/55
Gas 1: 12/65
Gas 2: 10/70
Gas 3: 15/55
Gas 4: 21/35
Gas 5: 20/20
Gas 6: 17/45
Minimum water temperature: 3,2
Maximum water temperature from profile:11
Minimum water temperature from profile:3,3
Surface air pressure (mBar): 1025
Desaturation time after dive (min): 773
Maximum CNS (%): 82
Average depth: 2136 mbar
Total divetime: 9965 sec
Last decostep: 3m
Battery voltage in mV after dive: 4,057
Salinity: 1
Profile data
ProfileOffset: 258
Number of ProfileEntries: 1992
1 0:05 1,54m 151 , SetPoint set to 50
2 0:10 1,40m 137
3 0:15 1,52m 149
4 0:20 1,61m 158
5 0:25 1,57m 154
6 0:30 1,67m 164 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
7 0:35 2,01m 197
8 0:40 1,75m 172
9 0:45 1,95m 191
10 0:50 2,01m 197
11 0:55 2,16m 212
12 1:00 2,27m 223 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
13 1:05 2,19m 215
14 1:10 2,23m 219
15 1:15 2,16m 212
16 1:20 2,18m 214
17 1:25 2,21m 217
18 1:30 1,87m 183 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
19 1:35 1,39m 136
20 1:40 1,14m 112
21 1:45 1,32m 129
22 1:50 1,44m 141
23 1:55 1,31m 128
24 2:00 0,93m 91 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
25 2:05 0,71m 70
26 2:10 1,08m 106
27 2:15 1,02m 100
28 2:20 0,95m 93
29 2:25 0,61m 60
30 2:30 0,82m 80 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
31 2:35 1,49m 146
32 2:40 2,23m 219
33 2:45 2,47m 242
34 2:50 3,18m 312
35 2:55 4,45m 436
36 3:00 5,14m 504 , Temperature 33, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
37 3:05 4,99m 489
38 3:10 5,08m 498
39 3:15 5,00m 490
40 3:20 4,90m 481
41 3:25 4,97m 487
42 3:30 4,96m 486 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
43 3:35 4,93m 483
44 3:40 4,83m 474
45 3:45 5,16m 506
46 3:50 5,18m 508
47 3:55 4,95m 485
48 4:00 4,97m 487 , Temperature 33, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 0
49 4:05 5,05m 495
50 4:10 5,03m 493
51 4:15 5,06m 496
52 4:20 5,09m 499
53 4:25 4,88m 479
54 4:30 5,00m 490 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
55 4:35 5,23m 513
56 4:40 5,03m 493
57 4:45 5,13m 503
58 4:50 5,11m 501
59 4:55 5,18m 508
60 5:00 5,62m 551 , Temperature 33, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
61 5:05 5,68m 557
62 5:10 5,85m 574
63 5:15 5,78m 567
64 5:20 5,68m 557
65 5:25 5,62m 551
66 5:30 5,60m 549 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
67 5:35 5,66m 555
68 5:40 5,82m 571
69 5:45 5,72m 561
70 5:50 5,70m 559
71 5:55 5,60m 549
72 6:00 5,11m 501 , Temperature 33, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
73 6:05 5,13m 503
74 6:10 5,20m 510
75 6:15 5,00m 490
76 6:20 5,12m 502
77 6:25 5,15m 505
78 6:30 5,27m 517 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
79 6:35 5,48m 537
80 6:40 5,57m 546
81 6:45 5,96m 584
82 6:50 6,71m 658
83 6:55 7,47m 733
84 7:00 8,01m 786 , Temperature 33, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
85 7:05 8,13m 797
86 7:10 8,65m 848
87 7:15 9,38m 920
88 7:20 9,94m 975
89 7:25 10,15m 995
90 7:30 10,42m 1022 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
91 7:35 10,54m 1034
92 7:40 10,93m 1072
93 7:45 11,19m 1097
94 7:50 11,60m 1138
95 7:55 11,52m 1130
96 8:00 11,55m 1133 , Temperature 33, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
97 8:05 11,47m 1125
98 8:10 10,95m 1074
99 8:15 10,57m 1037
100 8:20 10,79m 1058
101 8:25 10,78m 1057
102 8:30 10,68m 1047 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
103 8:35 10,40m 1020
104 8:40 10,01m 982
105 8:45 9,74m 955
106 8:50 9,72m 953
107 8:55 9,50m 932
108 9:00 9,31m 913 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
109 9:05 8,81m 864
110 9:10 8,82m 865
111 9:15 8,94m 877
112 9:20 8,85m 868
113 9:25 8,76m 859
114 9:30 8,77m 860 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
115 9:35 8,76m 859
116 9:40 8,77m 860
117 9:45 8,77m 860
118 9:50 8,76m 859
119 9:55 8,77m 860
120 10:00 8,76m 859 , Temperature 34, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
121 10:05 8,77m 860
122 10:10 8,76m 859
123 10:15 8,77m 860
124 10:20 8,77m 860
125 10:25 8,76m 859
126 10:30 8,76m 859 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
127 10:35 8,78m 861
128 10:40 8,76m 859
129 10:45 8,77m 860
130 10:50 8,77m 860
131 10:55 9,45m 927
132 11:00 10,61m 1040 , Temperature 35, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
133 11:05 11,32m 1110
134 11:10 11,50m 1128
135 11:15 11,91m 1168
136 11:20 12,21m 1197
137 11:25 12,36m 1212
138 11:30 12,47m 1223 , Non Deko Limit 240min, Gradient factor 0, Deco Debug
139 11:35 12,65m 1241
140 11:40 13,24m 1298
141 11:45 13,53m 1327
142 11:50 13,45m 1319
143 11:55 13,52m 1326
144 12:00 13,80m 1353 , Temperature 36, Non Deko Limit 240min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
145 12:05 14,08m 1381
146 12:10 14,49m 1421
147 12:15 15,12m 1483
148 12:20 15,80m 1549
149 12:25 16,47m 1615
150 12:30 17,08m 1675 , Non Deko Limit 107min, Gradient factor 0, Deco Debug
151 12:35 17,75m 1741
152 12:40 18,59m 1823
153 12:45 19,52m 1914
154 12:50 20,42m 2003
155 12:55 21,25m 2084
156 13:00 22,11m 2168 , Temperature 35, Non Deko Limit 55min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 1
157 13:05 22,16m 2173
158 13:10 22,03m 2160
159 13:15 22,23m 2180
160 13:20 21,87m 2145
161 13:25 22,06m 2163
162 13:30 21,97m 2155 , Non Deko Limit 54min, Gradient factor 0, Deco Debug
163 13:35 22,07m 2164
164 13:40 22,23m 2180
165 13:45 22,14m 2171
166 13:50 22,76m 2232
167 13:55 23,52m 2307
168 14:00 24,26m 2379 , Temperature 36, Non Deko Limit 42min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
169 14:05 24,83m 2435
170 14:10 25,12m 2463
171 14:15 25,44m 2495
172 14:20 25,91m 2541
173 14:25 26,01m 2551
174 14:30 26,14m 2563 , Non Deko Limit 34min, Gradient factor 0, Deco Debug
175 14:35 26,40m 2589
176 14:40 26,72m 2620
177 14:45 26,81m 2629
178 14:50 26,92m 2640
179 14:55 27,28m 2675
180 15:00 27,63m 2710 , Temperature 36, Non Deko Limit 29min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
181 15:05 28,01m 2747
182 15:10 28,42m 2787
183 15:15 28,95m 2839
184 15:20 29,32m 2875
185 15:25 29,39m 2882
186 15:30 29,53m 2896 , Non Deko Limit 24min, Gradient factor 0, Deco Debug
187 15:35 29,80m 2922
188 15:40 29,86m 2928 , SetPoint set to 130
189 15:45 30,25m 2967
190 15:50 30,47m 2988
191 15:55 30,62m 3003
192 16:00 30,68m 3009 , Temperature 36, Non Deko Limit 22min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 2
193 16:05 30,80m 3020
194 16:10 31,05m 3045
195 16:15 31,32m 3071
196 16:20 31,17m 3057
197 16:25 31,07m 3047
198 16:30 31,12m 3052 , Non Deko Limit 21min, Gradient factor 0, Deco Debug
199 16:35 31,08m 3048
200 16:40 31,05m 3045
201 16:45 30,91m 3031
202 16:50 30,95m 3035
203 16:55 30,88m 3028
204 17:00 30,83m 3023 , Temperature 37, Non Deko Limit 21min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
205 17:05 30,75m 3016
206 17:10 30,91m 3031
207 17:15 31,00m 3040
208 17:20 31,16m 3056
209 17:25 31,09m 3049
210 17:30 31,22m 3062 , Non Deko Limit 21min, Gradient factor 0, Deco Debug
211 17:35 31,20m 3060
212 17:40 31,34m 3073
213 17:45 31,30m 3069
214 17:50 31,19m 3059
215 17:55 31,05m 3045
216 18:00 30,52m 2993 , Temperature 38, Non Deko Limit 22min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 3
217 18:05 30,93m 3033
218 18:10 31,21m 3061
219 18:15 31,30m 3069
220 18:20 30,96m 3036
221 18:25 30,50m 2991
222 18:30 30,48m 2989 , Non Deko Limit 22min, Gradient factor 0, Deco Debug
223 18:35 30,50m 2991
224 18:40 30,66m 3007
225 18:45 30,87m 3027
226 18:50 30,83m 3023
227 18:55 30,82m 3022
228 19:00 30,81m 3021 , Temperature 39, Non Deko Limit 21min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 4
229 19:05 30,74m 3015
230 19:10 30,79m 3019
231 19:15 31,12m 3052
232 19:20 31,97m 3135
233 19:25 32,11m 3149
234 19:30 32,11m 3149 , Non Deko Limit 18min, Gradient factor 0, Deco Debug
235 19:35 32,05m 3143
236 19:40 32,03m 3141
237 19:45 32,00m 3138
238 19:50 32,00m 3138
239 19:55 32,63m 3200
240 20:00 33,28m 3264 , Temperature 39, Non Deko Limit 17min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 4
241 20:05 33,87m 3322
242 20:10 34,00m 3334
243 20:15 34,06m 3340
244 20:20 34,15m 3349
245 20:25 34,04m 3338
246 20:30 34,40m 3373 , Non Deko Limit 15min, Gradient factor 0, Deco Debug
247 20:35 34,60m 3393
248 20:40 34,64m 3397
249 20:45 34,76m 3409
250 20:50 34,77m 3410
251 20:55 34,79m 3412
252 21:00 34,76m 3409 , Temperature 41, Non Deko Limit 14min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 5
253 21:05 34,61m 3394
254 21:10 34,74m 3407
255 21:15 34,66m 3399
256 21:20 34,75m 3408
257 21:25 34,82m 3415
258 21:30 34,81m 3414 , Non Deko Limit 14min, Gradient factor 0, Deco Debug
259 21:35 34,76m 3409
260 21:40 34,57m 3390
261 21:45 34,32m 3366
262 21:50 34,68m 3401
263 21:55 34,60m 3393
264 22:00 34,59m 3392 , Temperature 44, Non Deko Limit 14min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 5
265 22:05 34,65m 3398
266 22:10 34,38m 3372
267 22:15 34,43m 3376
268 22:20 34,52m 3385
269 22:25 34,97m 3429
270 22:30 35,30m 3462 , Non Deko Limit 14min, Gradient factor 0, Deco Debug
271 22:35 35,70m 3501
272 22:40 36,05m 3535
273 22:45 36,55m 3584
274 22:50 36,87m 3616
275 22:55 37,30m 3658
276 23:00 37,62m 3689 , Temperature 46, Non Deko Limit 11min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 6
277 23:05 38,05m 3731
278 23:10 38,47m 3773
279 23:15 38,80m 3805
280 23:20 39,28m 3852
281 23:25 39,66m 3889
282 23:30 40,10m 3932 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
283 23:35 40,80m 4001
284 23:40 41,42m 4062
285 23:45 42,14m 4133
286 23:50 42,62m 4180
287 23:55 42,92m 4209
288 24:00 43,13m 4230 , Temperature 47, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 6
289 24:05 43,20m 4236
290 24:10 43,12m 4229
291 24:15 43,32m 4248
292 24:20 43,39m 4255
293 24:25 43,24m 4240
294 24:30 43,44m 4260 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
295 24:35 43,48m 4264
296 24:40 43,49m 4265
297 24:45 43,61m 4277
298 24:50 43,50m 4266
299 24:55 43,63m 4279
300 25:00 44,18m 4333 , Temperature 49, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 7
301 25:05 44,94m 4407
302 25:10 45,34m 4446
303 25:15 46,05m 4516
304 25:20 46,77m 4587
305 25:25 47,76m 4684
306 25:30 48,64m 4770 , Non Deko Limit 0min, Gradient factor 0, Deco Debug
307 25:35 49,41m 4845
308 25:40 49,70m 4874
309 25:45 50,05m 4908
310 25:50 50,33m 4936
311 25:55 50,32m 4935
312 26:00 50,54m 4956 , Temperature 49, Non Deko Limit 0min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug , CNS 7
313 26:05 50,63m 4965
314 26:10 50,62m 4964
315 26:15 50,66m 4968
316 26:20 50,83m 4985
317 26:25 50,83m 4985
318 26:30 50,89m 4991 , Decostop at 3m 1min, Gradient factor 0, Deco Debug 3m 1min
319 26:35 50,96m 4997
320 26:40 51,01m 5002
321 26:45 50,90m 4992
322 26:50 51,05m 5006
323 26:55 51,06m 5007
324 27:00 51,38m 5039 , Temperature 50, Decostop at 3m 2min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 3m 2min, CNS 8
325 27:05 51,49m 5049
326 27:10 51,80m 5080
327 27:15 51,85m 5085
328 27:20 51,92m 5092
329 27:25 51,99m 5098
330 27:30 51,88m 5088 , Decostop at 3m 2min, Gradient factor 0, Deco Debug 3m 2min
331 27:35 52,11m 5110
332 27:40 52,25m 5124
333 27:45 52,47m 5146
334 27:50 52,66m 5164
335 27:55 52,85m 5183
336 28:00 52,96m 5194 , Temperature 51, Decostop at 3m 3min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 3m 3min, CNS 8
337 28:05 52,80m 5178
338 28:10 52,80m 5178
339 28:15 52,70m 5168
340 28:20 52,73m 5171
341 28:25 52,75m 5173
342 28:30 52,88m 5186 , Decostop at 6m 1min, Gradient factor 0, Deco Debug 6m 1min, 3m 3min
343 28:35 52,97m 5195
344 28:40 53,08m 5205
345 28:45 52,81m 5179
346 28:50 52,82m 5180
347 28:55 52,80m 5178
348 29:00 52,57m 5155 , Temperature 51, Decostop at 6m 1min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 6m 1min, 3m 3min, CNS 9
349 29:05 52,43m 5142
350 29:10 52,48m 5147
351 29:15 52,38m 5137
352 29:20 52,35m 5134
353 29:25 52,64m 5162
354 29:30 53,03m 5200 , Decostop at 6m 2min, Gradient factor 0, Deco Debug 6m 2min, 3m 3min
355 29:35 53,32m 5229
356 29:40 53,39m 5236
357 29:45 53,50m 5247
358 29:50 53,50m 5247
359 29:55 53,66m 5262
360 30:00 53,78m 5274 , Temperature 52, Decostop at 6m 2min, Gradient factor 0, ppO2 Sensor Value 0, Deco Debug 6m 2min, 3m 4min, CNS 10
This showes all the NDL:s in both dives and a little bit of the deco when the computer got it right again.
Hope this helps!
DiveNumber: 833
Gas 1: 12/65
Gas 2: 10/70
Gas 3: 15/55
Gas 4: 21/35
Gas 5: 20/20
Gas 6: 17/45
Maximum CNS (%): 82
Last decostep: 3m
Salinity: 1
Profile data
ProfileOffset: 258
2 0:10 1,40m 137
3 0:15 1,52m 149
4 0:20 1,61m 158
5 0:25 1,57m 154
7 0:35 2,01m 197
8 0:40 1,75m 172
9 0:45 1,95m 191
10 0:50 2,01m 197
11 0:55 2,16m 212
13 1:05 2,19m 215
14 1:10 2,23m 219
15 1:15 2,16m 212
16 1:20 2,18m 214
17 1:25 2,21m 217
19 1:35 1,39m 136
20 1:40 1,14m 112
21 1:45 1,32m 129
22 1:50 1,44m 141
23 1:55 1,31m 128
25 2:05 0,71m 70
26 2:10 1,08m 106
27 2:15 1,02m 100
28 2:20 0,95m 93
29 2:25 0,61m 60
31 2:35 1,49m 146
32 2:40 2,23m 219
33 2:45 2,47m 242
34 2:50 3,18m 312
35 2:55 4,45m 436
37 3:05 4,99m 489
38 3:10 5,08m 498
39 3:15 5,00m 490
40 3:20 4,90m 481
41 3:25 4,97m 487
43 3:35 4,93m 483
44 3:40 4,83m 474
45 3:45 5,16m 506
46 3:50 5,18m 508
47 3:55 4,95m 485
49 4:05 5,05m 495
50 4:10 5,03m 493
51 4:15 5,06m 496
52 4:20 5,09m 499
53 4:25 4,88m 479
55 4:35 5,23m 513
56 4:40 5,03m 493
57 4:45 5,13m 503
58 4:50 5,11m 501
59 4:55 5,18m 508
61 5:05 5,68m 557
62 5:10 5,85m 574
63 5:15 5,78m 567
64 5:20 5,68m 557
65 5:25 5,62m 551
67 5:35 5,66m 555
68 5:40 5,82m 571
69 5:45 5,72m 561
70 5:50 5,70m 559
71 5:55 5,60m 549
73 6:05 5,13m 503
74 6:10 5,20m 510
75 6:15 5,00m 490
76 6:20 5,12m 502
77 6:25 5,15m 505
79 6:35 5,48m 537
80 6:40 5,57m 546
81 6:45 5,96m 584
82 6:50 6,71m 658
83 6:55 7,47m 733
85 7:05 8,13m 797
86 7:10 8,65m 848
87 7:15 9,38m 920
88 7:20 9,94m 975
89 7:25 10,15m 995
91 7:35 10,54m 1034
92 7:40 10,93m 1072
93 7:45 11,19m 1097
94 7:50 11,60m 1138
95 7:55 11,52m 1130
97 8:05 11,47m 1125
98 8:10 10,95m 1074
99 8:15 10,57m 1037
104 8:40 10,01m 982
105 8:45 9,74m 955
106 8:50 9,72m 953
107 8:55 9,50m 932
109 9:05 8,81m 864
110 9:10 8,82m 865
111 9:15 8,94m 877
112 9:20 8,85m 868
113 9:25 8,76m 859
115 9:35 8,76m 859
116 9:40 8,77m 860
117 9:45 8,77m 860
118 9:50 8,76m 859
119 9:55 8,77m 860
121 10:05 8,77m 860
122 10:10 8,76m 859
123 10:15 8,77m 860
124 10:20 8,77m 860
125 10:25 8,76m 859
127 10:35 8,78m 861
128 10:40 8,76m 859
129 10:45 8,77m 860
130 10:50 8,77m 860
131 10:55 9,45m 927
Hope this helps!
daviesjez
Well another dive on Saturday 33mtr for just under 60 total dive time and again the NDL was out until deco ( by about 8 minutes ) and then starting match no problem. TTS + 5 was on and this again was out showing NDL when the Predator would be in deco.
@HW, i can post the profile data for this one of it helps
Jez
Jez
[DF]
Are you sure the FTTS was showing NDL?
As I understand it FTTS never shows NDL and if there is no deco even if you stay the extra minutes it just shows how long it would take to ascend given the preset ascent speed. For a 33m dive it would always show 4min until it actually came in to deco.
I have not had the opportunity to dive since my last posted logs but I ran a simulation to 30m instead
Diluent: Tx15/55, SetPoint: 0.5
There I can see that the NDL is frozen on 20 minutes until after 7min 21sec where it drops to 18 min NDL. At 10 seconds later it drops down to 0min and stay at zero from 7m,32s to 11m,21s.
The FTTS however is not frozen and keeps counting upwards realizing that, in my case 10 minutes more bottom time, I will have to decompress. It does however seem to give increasingly lower predictions as the dive continues. For example at 5 min the @+10 TTS shows 7min of FTTS and that is pretty accurate. But at 10 minutes the FTTS is 12 min and that is too low.
I videotaped the simulation but I can’t post the video. If you are interested, HW, I can mail it to you so you can see what it is we are talking about in a more visual way.
FTTS always shows TTS. Even during the NDL phase (10m/min+1min between 3 and zero), rounded up to the next full minute.
daviesjez
Did you managed to replicate any of these issues over the weekend?
I'm a trifle concerned now about using this open circut next week as a primary computer... as i really don't know if these issues persist just when running in CC mode
Jez
Jez
[DF]
> Regards,
Yep, that is what i thougt. Thanks for verifying!
But what can we do to help you resolve this? As i said i can mail you the sim video but would you like the config file instead/also? Is there something else that would help?
> Regards,
None of the above could be reproduced here over the weekend. Having the integration of the simulator in mind I absolutely can't see why this should NOT happen in simulator mode, too.
