OSTC3 - Deco gases not used for deco calculation
hploch
Post by hploch »
Hi!
I have experienced the following problem with my OSTC3: Since version 0.99 the deco gases are not considered for deco calculation any more. Neither in deco planner nor in the simulator nor in dive mode. It makes no differnce if I enable or disable the gases, I get always the same TTS in deko planner. I also experienced the same problem in an actual dive. I reverted to version 0.97 and it worked. I already reset the computer and removed the battery upgraded to version 1.00. It makes no difference. Has anybody experienced similar problems?
Thx,
Harald
Re: Deco gases not used for deco calculation
did you set a change depth for the deco gases?
If the Change depth is set to "0", the deco gases are not included in the deco calculation.
Additional note:
This statement is true for the OSTC 2 series.
If you are using Firmware 1.0 your Computer is an OSTC 3.
I don't know if my Statement applies to the OSTC3 as well.
hploch
Post by hploch »
Yes I set the change depth!
Harald
Re: OSTC3 - Deco gases not used for deco calculation
thanks to Harald who contacted us via mail as well, we have fixed this issue in the 1.01.
It's now available for download here: http://www.heinrichsweikamp.com/?id=162
P.S.: http://www.heinrichsweikamp.com/?id=162&version=en English version
hploch
Post by hploch »
Just downloaded the update and installed it on my OSTC3. Everything works fine again. Thanx a lot for the quick fix!!!!
Harald
