Menu change suggestion
danou
Post by danou »
Hi all,
In another thread (OSTC 2N V 2.7 updated with a problem) I suggested a change for the OSTC menus, but I admit I should have opened another thred, that's what I do finally ;)
I find the "CCR Setup" a bit hidden inside the "More" menu.
I would suggest to move the "CCR Setup" menu one level up, i.e. swap "CCR Setup" and "Reset Menu" to have
Menu:
=> Logbook
=> Gas Setup (renamed as "OC gas Setup"?)
=> CCR Setup (includind Diluent and Setpoints setup)
=> Setup (Decotype and Custom Functions)
=> More:
====> Reset Menu
====> Set Time
====> Battery Info
====> Simulator
====> Altimeter
This way, we would have at the first menu level all Dive Setup (OC and CC gas configuration and General Setup (Decotype and Custom functions) together with "Logbook"…
Are there drawbacks, unwanted side effects, or are most users satisfied with the current menu layout? Please let me know what you think of my proposal…
Best wishes,
Daniel Flipo
OSTC 2N 6131
[DF]
Re: Menu change suggestion
Post by [DF] »
I support this! Excellent suggestion :)
Only I would like:
=> Logbook
=> CCR Setup (including Diluent and Set Points setup)
=> More:
====> Simulator
====> Set Time
====> Battery Info
====> Altimeter
====> Reset Menu
As you say, all dive menus in one place, then simulator as first choice in “More” and the “Reset” way back where you won’t accidentally activate anything. :)
buk@nero
Post by buk@nero »
danou Wrote:
> Hi all,
> "More" menu.
> to have
> Menu:
> => Logbook
> setup)
> => More:
> ====> Reset Menu
> ====> Set Time
> ====> Battery Info
> ====> Simulator
> ====> Altimeter
> proposal…
> Best wishes,
> Daniel Flipo
> OSTC 2N 6131
+1
